1999 dodge 2500 abs light problem - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 13 Old 07-19-2008, 01:57 AM Thread Starter
burton9010
I just bought this truck and the abs light and the red parking brake light are one. I took it to a shop to scan and he told me the controller was bad and told me it was $650 for a new one. Well I went on ebay and found a used one for $50. I put it in but it didnt change anything. Sometimes you start the truck and the lights are off and stay off, other times the lights are off then come on while your driving and other times the lights are on as soon as you start it. Has anyone has any problems like this. Is it possible the guy who scanned it was wrong and its not a abs contoller. Should I just bit the bullet and take it to dodge and have them scan it? Thanks
burton9010 is offline
post #2 of 13 Old 07-19-2008, 08:43 PM
Clunk
Clunk's Avatar
Quoted: 19 Post(s)
If the brakes are operating normal, you might get a free scan at the local chain type auto parts store then we can discuss the trouble code(s)..
'01.5 2500 4x4 Red QC Sport HO SWB, 6spd.,cowl hood, 4" ex., Edge Drag Comp, Banks boost & pyro pillar mount, single black Holley 140gph lift pump...13psi WOT, US Gage & 4 grease gun lines for fuel pressure monitor, 2% Biodiesel in the tank, Amsoil in the trans and Valvoline in the pan. Vulcan Big Line kit, Napa #2790 BHAF, cheapo fuel cooler, Jammer 100's, Cat C300 turbo 3.55 gears jes' like Ram3500Dually sez..., ARP studs,
Take time to turn so's you don't burn.
Clunk is offline
post #3 of 13 Old 07-19-2008, 09:31 PM Thread Starter
burton9010
abs light
Do you know of any places that will lend the abs scanner out. I just called auto zone and kragen and neither one lends out scanners anymore.
post #4 of 13 Old 07-20-2008, 08:20 PM
Clunk
Clunk's Avatar
Quoted: 19 Post(s)
They'll scan it at the store if it's safe to drive.
Clunk is offline
post #5 of 13 Old 07-20-2008, 10:44 PM
Red Sleeper
Blowin n' Goin
Red Sleeper's Avatar
I would check your speed sensors going to the hub bearing. I rubbed through one of mine and it trippped the lights. Just a thought.
Nick J
05 Cummins QCSB. TransGo Smarty H2O/CH4O
13 Jetta TDI 6spd auto
91 Cummins Dedicated water hauling vehicle
94 Z28 LT1 355ci 6spd Lots of Tubing
RockCrawling Dakota
Red Sleeper is offline
post #6 of 13 Old 08-18-2008, 12:19 AM
ram-stang
Check and see if your blower motor and reverse lights are working or not. I had a similar problem with the lights you are talking about and did not have reverse lights or blower motor. Problem ended up being my ignition switch was bad and the Dodge replacement switch included a wiring harness that had a relay for the blower motor.
ram-stang is offline
post #7 of 13 Old 08-18-2008, 10:19 AM Thread Starter
burton9010
nope my reverse lights and blower motor are working. I am planning on getting it scaned I just dont have any money right now. Thanks for the help.
post #8 of 13 Old 09-03-2008, 09:07 AM
jslash
jslash's Avatar
My ABS and Brake light are on ALL the time. I figure one of the sensors is bad but not sure how to diagnose which one. When I had the tranny replaced they looked for codes related to the tranny but found no codes. Are the codes for the tranny stored seperately from the rest of the truck? My assumption is no. So if there were no codes for the tranny, there are no codes for the ABS sensors either.
Jim
1997 Grand Caravan 3.3l automatic overdrive
1999 RAM 2500 4X4 SLT Quad Cab 24 Valve Cummins Turbo Diesel
Oconomowoc, WI
jslash is offline
post #9 of 13 Old 09-03-2008, 09:41 AM
Clunk
Clunk's Avatar
Quoted: 19 Post(s)
There are codes for both, it takes an auto trans & ABS capable scanner to read them.
I found a broken ABS wire on the passenger side front hub on my Olds Bravada...replaced it (wire & wheel speed sensor is one assembly) with a used one with great success.
Clunk is offline
post #10 of 13 Old 09-03-2008, 09:56 AM
jslash
jslash's Avatar
Okay, so the scanner the tranny guy was using probably only worried about the tranny codes so no codes read ment no "tranny codes" read. I'll hit Autozone in the next couple of days and see what they show. Or, does the ignition switch trick work on a '99?
Jim
Oconomowoc, WI
jslash is offline
post #11 of 13 Old 09-04-2008, 09:50 AM
Clunk
Clunk's Avatar
Quoted: 19 Post(s)
The ignition switch scan started with the 2000 model year but you can't hurt anything by trying in case yours is a very late '99. Turn the keyswitch On-Off-On-Off-On then look at the odometer.
Clunk is offline
post #12 of 13 Old 09-04-2008, 04:09 PM
crazys182003
Quoted: 5 Post(s)
Most likely it is a bad speed sensor in your rear axle. And when it is off it proabably stays off until you hit about 50 mph or so? Had similar problem and it was just my rear sensor along with a few parts I broke while on a construction site.
crazys182003 is offline
post #13 of 13 Old 10-19-2008, 10:54 PM
dyessme
Had ABS light problem and replacement of rear axle sensor fixed it for about 60.00. Saved morh than 100.00
Dyessme
1998 Ram 2500 2WD 376,000 miles, orginal auto tanny.
dyessme is offline
    Factory Stock 1/4 mile and 0-60 times. dodgeneonACR98 Street and Strip Talk 8 05-05-2009 08:53 PM
    2008 Dodge Nitro Continues to Set Mid-size SUV Segment Ablaze RAM MAN Rumor Mill & Gossip Talk 0 09-12-2007 02:54 PM
    Dodge Announces 2008 Dodge Dakota Pricing RAM MAN Rumor Mill & Gossip Talk 0 07-11-2007 07:14 AM
    Dodge Reveals New 2006 Ram 1500 FreeLantz Rumor Mill & Gossip Talk 60 06-08-2006 09:58 PM
    Legendary Dodge Ram Power Wagon Returns RAM MAN Rumor Mill & Gossip Talk 4 10-02-2004 06:44 PM
