Thread Tools |
trouble code P0545
- Posted: 07-14-2008, 04:24 PM
Post #1
SO I got an P0545 trouble code from autozone using their scanner..
AC clutch relay circuit? |
| Sponsored Links | |
Advertisement |
Posted: 07-21-2008, 02:53 AM
Post #2
some places list that code as:
Exhaust gas temperature sensor circuit low, bank 1, sensor 1. Is this the 02 sensor? there's 1 before and after the cat right? Where would I find it? I want to get this CEL off ![]() guess i'll have to climb up under the van.. and can expect it to be a PITA to get out? darn. |
Posted: 07-21-2008, 11:16 PM
Post #3
Do you have A/C and does it work properly?
Posted: 07-22-2008, 12:22 AM
Post #4
Yes. except i have the infamous fan blower switch only works in OFF and HIGH position 4.
Posted: 07-22-2008, 10:30 AM
Post #5
Replace the blower motor resistor. It goes for about $10-$15 and can be changed in under 5 minutes.
Posted: 07-22-2008, 10:36 AM
Post #6
will that fix the CEL ? or only the switch?
Posted: 07-22-2008, 05:34 PM
Post #7
Uh sorry, that was to fix the speed switch problem.
Posted: 07-22-2008, 05:43 PM
Post #8
The p0545 code is strictly about the A/C clutch control circuit and has nothing to do with the O2 sensor. Time to start tracing wires for signs of corrosion.
| Thread Tools | |
| 98 Caravan 3.3L "Haunted" - Electrical problems | daberguson | Dodge Caravan/Grand Caravan Talk | 11 | 12-22-2007 02:48 AM |
| 2001 Neon Torque Converter Electrical trouble code | jimi_po | Dodge Neon - Performance Talk | 1 | 10-24-2007 08:56 PM |
| 5.2 / 318 horrible MPG: Trouble code P0171; Causes / Ideas ? | RamVanMan | 1G Dodge Durango - Drivetrain Talk | 1 | 07-04-2006 02:29 PM |
| Trouble Codes for 96-97 Caravans | Jmw132001 | Dodge Caravan/Grand Caravan Talk | 0 | 05-18-2006 09:54 PM |
| How to decode the VIN | flattop | 3G Dodge RAM Diesel Talk | 9 | 03-23-2005 09:25 PM |
Privacy Statement | |
