What controls the blend door actuator 99 Ram 1500 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 18 Old 07-07-2008, 06:28 PM Thread Starter
MeenGreen5.2
i'm blue :D
MeenGreen5.2's Avatar
Quoted: 1 Post(s)
What controls the blend door actuator? (do the controls on the dash send a signal somewhere, then to the actuator?) I went to the junkyard, bought a Perfect Actuator plugged it in, and it does the same thing.
Please help, i know its not the actuator now.
2010 dodge ram 5.7 sport
deep water blue pearl
BLUE
24"verde rims
stock
BLUE TRUCK CLUB MEMBER #249
Trucks and Guns member #164
MeenGreen5.2 is offline
post #2 of 18 Old 07-08-2008, 02:56 PM Thread Starter
MeenGreen5.2
i'm blue :D
Quoted: 1 Post(s)
Anyone?
BLUE
24"verde rims
stock
post #3 of 18 Old 07-12-2008, 05:20 PM Thread Starter
MeenGreen5.2
i'm blue :D
Quoted: 1 Post(s)
thanks for your help guys! i fixed it haha it was a plastic key piece that connects the actuator to the blend door... simple fix! And i got the part for free at the junk yard (just paid 25 to get it installed)
You DO NOT have to remove the dash to take the actuator off.
BLUE
24"verde rims
stock
post #4 of 18 Old 07-15-2008, 02:51 PM
ragedracer1977
Please share.. I need to replace my blend door actuator and I've been putting it off because I don't want to pull the dash out....
rr
Current vehicles
2001 Ram 1500 5.9l 2WD
Stock, with work boxes.
(Hey ma, no cracked dash!!)
2002 Ram 1500 5.9l Sport 2WD
All stock
(of course, the dash crack curse skipped to my '02)
ragedracer1977 is offline
post #5 of 18 Old 07-15-2008, 02:55 PM Thread Starter
MeenGreen5.2
i'm blue :D
Quoted: 1 Post(s)
What's it doing? Tell me the symptoms and ill try to help ya.
btw i have a spare actuator...
BLUE
24"verde rims
stock
post #6 of 18 Old 07-15-2008, 06:43 PM
ragedracer1977
I'll be cruising down the street, AC blowing ice cold, then I hear a little "whump" and it starts blowing hot air. If I turn the AC fan down to the first position, it slowly cools down after about 30 seconds and then I can crank it again. I think the actuator is just getting "tired" and will only hold the door open for so long before it gives up.
rr
Current vehicles
All stock
post #7 of 18 Old 07-15-2008, 10:51 PM
medtech1
PLEASE SHARE!!
Mine has been cooking my freakin a@# for almost a year now. Been putting off fixing it, cause I did not want to remove the dash.
1999 Ram1500 5.2 A/T
Flowmaster Catback si/do
Gutted cat with O2 simulator
Relocated IAT sensor
Fiberglass rollpan with cutouts for custom tips
Accel supertune kit
Tinted windows
2inch lowering shackles in rear
Euro corner lights
Altezza taillights
Completely debadged and tailgate black plastic removed
Dakota airhat with large k&n cone filter
And counting!!!!
medtech1 is offline
post #8 of 18 Old 07-16-2008, 03:56 AM Thread Starter
MeenGreen5.2
i'm blue :D
Quoted: 1 Post(s)
Well, Theres a little black plastic piece that "adapts" the actuator to the blend door. That little POS BROKE on my ram.... IT DID THE EXACT THING YOU ARE SAYING. Anyways, i replaced my perfectly good blend door actuator with one from a junkyard and the piece i'm talking about....
How to replace the actuator:
Step one, Put the temp knob to 12'oclock position
Step two, Unplug actuator & Remove 2 screws Holding the actuator in place (one is hard to get to, Be patient... can be removed with a L Shaped Screwdriver)
Step#3, Remove actuator from the housing.
Step#4 Remove plastic adapter
step#5 install new plastic adapter
Step#6 Install new actuator.
STep#7 Test it! (you should now be able to control the temp you want it at.)
If you need these parts, ill try to find them at the local junk yard. Ill sell you my old actuator for $40 shipped if you want it.
I also replaced the controller on the dash, i have a spare one in my garage. It does not have the heated mirror option. $40 shipped. It works great. I just wanted to replace all the parts that control the actuator equally.
BLUE
24"verde rims
stock
post #9 of 18 Old 07-16-2008, 09:40 PM
medtech1
If I am looking at the right part. I don't see any way to get to the screws. Would you happen to have any pictures? Or a drawing or something??? Looks like I might be able to get to it if I pull the carpet out. Just not sure.
Accel supertune kit
Tinted windows
Euro corner lights
Altezza taillights
And counting!!!!
medtech1 is offline
post #10 of 18 Old 07-16-2008, 09:51 PM Thread Starter
MeenGreen5.2
i'm blue :D
Quoted: 1 Post(s)
The actuator is To the RIght of the transmission hump
sit in the passenger seat, kick with your left leg, thats where it is.....
and yes, you have to lift the carpet to get to the screw thats behind the actuator.
BLUE
24"verde rims
stock
post #11 of 18 Old 07-16-2008, 09:54 PM
joeuc23
joeuc23's Avatar
I have been having the same issues. Typically the blend door will close (go to heat) when I let off the throttle. I thought it might be the vacuum check valves, but I changed both and I am still having problems. I'm going to have to check the piece you refer to.
Where is the blend door located?
Thanks for the help MeenGreen.
Joe
joeuc23 is offline
post #12 of 18 Old 07-16-2008, 09:57 PM Thread Starter
MeenGreen5.2
i'm blue :D
Quoted: 1 Post(s)
Ima go get some pics for you guys, brb DONT GET OFF! ILL BEE RIGHT BACK!
BLUE
24"verde rims
stock
post #13 of 18 Old 07-16-2008, 10:12 PM Thread Starter
MeenGreen5.2
i'm blue :D
Quoted: 1 Post(s)
Here's the pics... Read the pics... How ever, if that plastic peice doesent solve your problem, blend door may be broken... removal of dash is required.
Theres only one way to find out!
BLUE
24"verde rims
stock
post #14 of 18 Old 07-16-2008, 10:23 PM
joeuc23
joeuc23's Avatar
Thanks again MeenGreen!!!
Those pictures help a ton...I had no idea where to look. Hopefully I'll be able to take a look this weekend. It's 90 degree weather here and having the air blow heat really sux.
joeuc23 is offline
post #15 of 18 Old 07-19-2008, 12:55 AM
medtech1
AMEN to that!!!!
Mine has been stuck for a while and I am driving 100 miles a day like that.
Thanks again for being so much help MeenGreen.
Accel supertune kit
Tinted windows
Euro corner lights
Altezza taillights
And counting!!!!
medtech1 is offline
post #16 of 18 Old 07-19-2008, 06:37 AM Thread Starter
MeenGreen5.2
i'm blue :D
Quoted: 1 Post(s)
no prob man, my name is German, I accept any form of donations! lol
BLUE
24"verde rims
stock
post #17 of 18 Old 07-20-2008, 12:48 AM
99sliverram
99sliverram's Avatar
Anyone had a problem when trying to turn the temp dial a little warmer from full cold and only getting either full cold or full hot? No in between?
Formerly 2000redram
FORMER Member #93 of "The Red Truck Club"
I no longer have the truck. Time for new name
1999 Dodge Ram 1500 SLT 4x4 quad cab Driftwood/(sliver) metallic, leather int Member #180 Sliver truck club
3:92 gears
3" lift
285/75/16 all terrains
Randy Ellis light bar with 4 KC daylighters
94 -96 NEW in box Mopar Ram electronic ignition switch for sale $20 shipped to the lower 48.
Future mods
Exhaust
315/75/16 tires
Trucks and guns member #47
69 Charger R/T "General Lee replica"
440 .030 over
ported heads
10 to 1 comp
flowmaster exh
727 torqueflite w/ 2500 stall
4:10 geared Dana 60 with detroit locker
Not track tested yet. "weekend driver"
99sliverram is offline
post #18 of 18 Old 07-20-2008, 04:18 AM Thread Starter
MeenGreen5.2
i'm blue :D
Quoted: 1 Post(s)
I had this problem, Replaced temp Controller on dash and that plastic peice under the dash, Prob solved.
if anyone needs a controller, i have one for sale... $40 shipped it works FINE.
I also have The Blend door actuator... 75 shipped for both.
BLUE
24"verde rims
stock
    2007 Dodge Ram 1500 RAM MAN Rumor Mill & Gossip Talk 1 11-29-2007 09:54 AM
    2007 Dodge Ram Heavy Duty RAM MAN Rumor Mill & Gossip Talk 0 09-02-2006 07:14 AM
    Dodge Reveals New 2006 Ram 1500 FreeLantz Rumor Mill & Gossip Talk 60 06-08-2006 09:58 PM
    Starting at $21,700, New Dodge Ram Offers Truckload of Value HankL Rumor Mill & Gossip Talk 0 09-01-2005 11:13 AM
    2004 and Select 2005 New Vehicle Pricing RAM MAN Rumor Mill & Gossip Talk 1 01-14-2004 11:29 AM
