Tranny stuck in 2nd or 3rd gear randomly - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 07-03-2008, 08:36 AM Thread Starter
thrustidle74
Hi,
I got a 2001 Durango SLT+.
Once in a while (once every 3 months) for a week long I have this problem.
I searched the database but I couldn't find an answer.
Here's the situation;
When I start the truck and drive in D everything is fine until I come to a complete stop.Then it gets stuck in 2nd or 3rd...If I pull over and stop the car and start again it's back to normal.
The dealer couldn't tell me anything cause this thing happens randomly.They offered me to start changing all the sensors one by one starting from the cheapest one until we find the faulty one which didn't make sense to me.
I had 2 fault codes before this problem which I wrote down but I can't find it now.As far as I remember one was Governor Pressure Sensor.
I apperaciate any suggessions.
By the way I live in Dubai,UAE which is basicaly a desert,can this be dirty(sand,dust etc) sensor, selonoid problem?
Thanx
Thrustidle74
thrustidle74 is offline
post #2 of 7 Old 07-03-2008, 09:37 AM
Neil F.
Neil F.'s Avatar
The Governor pressor sensor and solenoid are internal to the trans. You have to drop the pan to get to them so no dust/dirt should not be the issue. It is not uncommon for thos parts to have issues. Do a search.
99 Durango 5.9, FT 4x4, IP stage III w/ K&N air hat, M1, MOPAR PCM, Fastman TB, 1.7 RR, JBA headers, Borla cat back, Martin Saine valve body, Hotchkis swaybars, Blistein shocks, lowered 2" Black Rhino Kenya wheels, 246. 7 RWHP, 319 TQ
Neil F. is offline
post #3 of 7 Old 07-06-2008, 04:31 AM Thread Starter
thrustidle74
Thanks for that,
As you said dirt,sand and dust out of question then,
I found the codes that I wrote down, P1757,P1762,both related to governor pressure sensor and selonoid. But what I don't understand is after I erased the fault codes,they never appeared again although I'm still having the problem once in a while.
I think I'll go for the Governor Pressure sensor and selonoid first.
I'll be in Texas end of July,It should be cheaper than Middle East where I live.
Thanks
post #4 of 7 Old 07-07-2008, 12:44 PM
tactransman
Transmission Man!
tactransman's Avatar
Terry aka tactransman
'99 Ram 1500 4X4 5.9 Automatic #110 in the White Truck Club
Aren't you tired of getting your parts for your Super Bee from a kid that thinks a Civic is a "hot rod"!
Mods:
MSD Blaster 3 Coil
Magna Flow Cat and "Y" pipe
46RE Built to the Hilt
Transgo TF OD JR Shift Kit (With Mods)
Billet Cover Converter
Upgraded to five direct clutch drum
Five Overdrive Brake Clutch pack
47RE STEEL front planetary
Sonnax Reverse servo parts
HD Kevlar Lined Rigid Int Band
Deep Pan w/cooling tubes
3.8 ratio Int lever
billet Int servo struts
tactransman is offline
post #5 of 7 Old 07-09-2008, 09:16 PM
blkdur98
Shifting problems
I have a '98 D and a similar problem just started with the tranny. It will not downshift when coming to a stop and wants to pull out in 2nd or 3rd. It doesn't drop into passing gear either.
If I pull the shifter into L (1st) before stopping it will downshift...it's kinda operating in semi-auto mode. I got the check engine light about 2 days after the problem started...don't have any codes yet...don't know how to get. I plan to have a shop to a diagnostic, then repair myself.
I'll take any suggestions anyone has.
blkdur98 is offline
post #6 of 7 Old 08-15-2008, 12:40 AM
Tony V Durango
I am no expert so take my thoughts for what they are worth. I have a 5.9 that had what I thought was a similar problem. The engine would randomly bog down when I braked and even stalled once or twice. Took it to a few different mechanics who gave me a few different solutions. The last mechanic I took it to said to change the Trans fluid. I did that and it solved the problem for about 12k miles. I now change Trans fluid every 12k miles or when/if it starts again.
2001 Durango 4x4
5.9L
SLT Plus
Tony V Durango is offline
post #7 of 7 Old 08-17-2008, 11:46 AM Thread Starter
thrustidle74
Ok...I think I sorted it out...At least for the last 10 days it seems to behave.
I bought brand new vehicle speed sensor,governor pressure sensor,governor pressure solenoid and replaced all with the usual transmission fluid and filter.
At the end it costed me something around 300 USD in Middle East.
Thanks for all the replies that I got....
Cheers
Thrustidle74
    3rd gear only operation transmission jkenneyjr 2G Dodge RAM - Drivetrain Talk 2 05-18-2007 11:48 PM
    Can someone explain gear ratio's to me? Black07-4x4Quad 3G Dodge RAM - Drivetrain Talk 8 05-16-2007 11:12 AM
    Found a way to lock 3rd gear (and reach max. speed) Dutch Hemi 3G Dodge RAM - General Talk 49 02-28-2006 05:59 PM
    2002 Durango R/T 2nd to 3rd gear shift SCOTT02RT 1G Dodge Durango General Talk 10 05-19-2005 05:46 AM
    Stuck in 2nd Gear... HELP! Dodgespirit3.0 Dodge Caravan General Talk 0 10-07-2004 11:13 PM
