2000 Plymouth Neon wont start HELP! - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 10 Old 06-08-2008, 05:16 PM Thread Starter
JennyWrd
Exclamation 2000 Plymouth Neon wont start HELP!
My 2000 plymouth neon stalled one day while I was driving it. When it stalled there were no noises or anything. A couple days before it stalled the check engine light came on. After researching we checked the codes and they read out....1684,0340,0703,1391. The car will try to start but will never turn over. We checked the spark plugs and noticed we werent getting fire or getting a very weak fire on a couple. We changed the coil pack out and still nothing. We changed the crankshaft sensor out..still nothing. All the fuses are okay. Anyone have any ideas?
JennyWrd is offline
post #2 of 10 Old 06-08-2008, 05:25 PM Thread Starter
JennyWrd
Oh and on the odometer is flashes FUSE but all the fuses are fine???!!
JennyWrd is offline
post #3 of 10 Old 06-09-2008, 05:30 PM
sohc98
Neon bug bites again
sohc98's Avatar
you could try the camshaft sensor
2001 Sebring Sedan 2.4 Auto
A new 1gn will be mine soon!
sohc98 is offline
post #4 of 10 Old 06-09-2008, 07:06 PM Thread Starter
JennyWrd
Thanks
Ill try that thanks! Ill write back in to let everyone know if it works.
JennyWrd is offline
post #5 of 10 Old 06-09-2008, 10:03 PM
sohc98
sohc98's Avatar
another thing is try pulling the fuelpump fuse (under the hood) and leave it out for a minute or two this will reset the computer, thats what i did to my 95 after a new cam and crank sensor and it worked.
In ur first post it says the car will try and start but wont turn over.
Did you mean that it turns over but wont fire or dose it not even turn over, because if it dosnt turn over at all you should check all battery and styarter connections first and if still nothing its gunna most likly be a bad starter.
sohc98 is offline
post #6 of 10 Old 06-10-2008, 12:00 PM Thread Starter
JennyWrd
It turns over but it wont fire up. Im gonna try that fuse to reset too. thanks!
JennyWrd is offline
post #7 of 10 Old 06-10-2008, 04:54 PM Thread Starter
JennyWrd
Okay replaced the camshaft sensor and reset the computer, still nothing?! It took the codes off except for the 1684. Anybody?
JennyWrd is offline
post #8 of 10 Old 06-10-2008, 05:10 PM
sohc98
sohc98's Avatar
P1684 Battery Loss in the Last 50 Starts The battery has been disconnected within the last 50 starts
thats what that code is for,and i cant think of anything else at the moment sorry.
sohc98 is offline
post #9 of 10 Old 06-10-2008, 10:09 PM
frank27
non start
I don't know about the code for this vehicle, but did you check the camshaft position sensor. I have a '96 Neon (uses different codes) that wouldn't start - turned over but wouldn't catch. The sensor is mounted on the end of the head. Also check the wiring to the crank sensor as it is subject to a lot of abuse from road salt, water, mud etc.
frank27 is offline
post #10 of 10 Old 06-13-2008, 09:29 PM Thread Starter
JennyWrd
I changed the camshaft sensor and still nothing. It did take the codes off, but the dash still flashes fuse. I checked all the fuses and they are all fine. This is really confusing?
JennyWrd is offline
    2000 Dodge Neon SuperRam03 For Sale - Dodge Cars 2 04-04-2007 06:29 PM
    2000 Intrepid Won't Start SRWinters 2G Dodge Intrepid - General Talk 1 03-16-2007 03:31 AM
    2000 Neon overheated want start tabbytabbycakes Dodge Neon - General Talk 9 09-09-2006 10:15 PM
    Neon is dead and won't start mleader Dodge Neon - General Talk 13 08-07-2006 08:13 PM
    2000 Neon Electrical Trouble self104 Dodge Neon - General Talk 1 07-08-2006 09:45 AM
