4x4 grinding noise...need help please - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 05-27-2008, 11:42 AM Thread Starter
savage99ss
savage99ss's Avatar
Quoted: 1 Post(s)
I have a '01 1500 4X4 with the off road package with 130k on it. When 4 wheel is engaged (high or low), I get a grinding/knocking sound under acceleration which is accompanied by a pretty noticible vibration. This has been an ongoing sound, if I shift into 4x4. The truck has good upper/lower ball joints, wheel joints, shocks, new tires, etc. The truck has the 360 with 46RE trans. . Does anyone have any suggestions? There is no noise or vibration in 2 wheel drive or while coasting with the t-case in neutral. Found out the hard way and got stuck in mud!!!!!!!
Any ideas???
2012 Ram 2500 Longhorn - Diesel, 4x4
1999 Camaro SS - SLP Headers, 3" LM1 exhaust, 3" Y-pipe, high flow cats, SLP Lid
2009 GMC Yukon Denali XL - loaded, awd
2004 Dodge Ram 2500
- Hemi - added *Mopar step bars, JBA catback, Tow Mirrors, 285/70/17 BFG AT's, Weathertech's front and rear, Bilstein HD's, Cab Lights, Dually Tailgate, Luke's bushings, Maxx end links. -sold
2004 Dodge Ram - with Off Road Package - 285/70/17 BFG AT's - Ranch Extreme topper - Hella's behind the grille. - sold
2001 Dodge Ram - 4x4 Off Road Package - sold
savage99ss is offline
post #2 of 9 Old 05-27-2008, 01:49 PM
dodgensince74
Quoted: 11 Post(s)
have you checked your front drive shaft?
01 1500 5.9, Q/C, L/B, 4X4
Tanue cover
Super chips
Magnaflow S/i-D/o
K&N cai
Eagle alloy 102's
BFG LT285/75r16 A/T's
dodgensince74 is offline
post #3 of 9 Old 05-27-2008, 02:28 PM Thread Starter
savage99ss
savage99ss's Avatar
Quoted: 1 Post(s)
no i havent....what exactly should i be looking for? Any tips?
2004 Dodge Ram 2500
post #4 of 9 Old 05-27-2008, 02:45 PM
MoparRam
Addicted to Smilies
Sounds like the Front driveshaft needs new u-joints
MoparRam is offline
post #5 of 9 Old 05-27-2008, 04:49 PM
Ram Pwnage
Ram Pwnage
Ram Pwnage's Avatar
Check the ujoints in the front drive shaft and the axle shafts, and if there's grinding might want to check the front diff and CAD unit in the front axle for any damage to the gears.
2007 Dodge Ram 1500 Quad Cab Big Horn 4x4
Yeah, it's got a HEMI!
Pretty much stock for now, still way better than my 98
Ram Pwnage is offline
post #6 of 9 Old 05-28-2008, 01:43 AM
YkDave
i had the same issue with mine, even before i bought it (haha, its an old company bush beater)
The CAD vac solenoid had been smashed on a rock bending the shaft and only allowing it to partially engage the axle. It ended up skipping and chewing up the axles and coupler!
YkDave is offline
post #7 of 9 Old 05-28-2008, 09:15 AM Thread Starter
savage99ss
savage99ss's Avatar
Quoted: 1 Post(s)
looked underneath the truck today.....u joints look great. I tried the 4x4 and it worked great, except when i started to make a u-turn, then the wheel hopping began with a grinding sound.....
2004 Dodge Ram 2500
post #8 of 9 Old 05-28-2008, 09:52 AM
92d150lwb
92d150lwb's Avatar
it kinda sounds like some thing inside the axle housing like ykdave was saying , make sure its engaging the axles fully when locked into 4wd , other than that man , im not sure what to tell you , that trucks a bit too new for my blood.
Pretty much stock 92 D-150 318,auto,LONG BED
, and paid for
*DodgeTalk.com 318 Enthusiast Member # 94
92d150lwb is offline
post #9 of 9 Old 05-30-2008, 08:29 PM
Ram Pwnage
Ram Pwnage
Ram Pwnage's Avatar
Were you using the 4x4 on paved road and turning? b/c if you did, that's bad for it b/c the wheels can't slip and you can damage stuff. Dodge dealer told me that wheel hopping is normal for the truck and just part of the 4x4, mine does it when you crank hard over even in the snow, but there's no grinding and my gears are in good shape. It's pretty easy to open the CAD housing and check it out to see if the gear teeth are damaged. Just be really careful with the bolts that hold the CAD housing on, they're way too small and snap way too easily if they get gummed up with corrosion (esp in salt belt states). I broke 2 when i took it off to replace the axle shaft seal with very little effort.
    Grinding Noise in 4 Wheel Hi Hemi2500 3G Dodge RAM - 4X4 Talk 6 12-15-2007 08:47 AM
    constant clunk noise from ds front 2500 4x4 03cumminsmtz 3G Dodge RAM - 4X4 Talk 0 04-10-2007 03:28 PM
    Horrible noise...4x4 randomly engaging iceram4x4 2G Dodge RAM - General Talk 7 05-27-2006 02:00 AM
    Grinding noise on startup? ramGurl 2G Dodge RAM - General Talk 1 09-13-2004 09:03 PM
    2004 and Select 2005 New Vehicle Pricing RAM MAN Rumor Mill & Gossip Talk 0 03-21-2004 10:42 AM
