Transmission Shifts Late at High RPM - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 10 Old 05-10-2008, 12:02 AM Thread Starter
MagnumVP
Angry Transmission Shifts Late at High RPM
1999 Dodge Ram Quad
5.9L V8
Automatic Transmission
When I start from a complete stop the transmission doesn't shift into 2nd until about 3000 RPM's. At that point the trucks shifts and the "Check Engine" light turns on. It still shifts smooth (well at least for this truck). I dropped the pan, replaced the filter and 5 Qts of ATF+4 fluid. Removed the Negative from the battery (resetting the computer) and try it again. Same thing (bummer, I was hoping for a $45 fix) and even drove it around 10 miles to let the fluid heat up but same thing. I also notice that it shifts from 3rd to 4th rather high as well.
What could be the issue? I am going to take it down to get the diagnostic code read to see what could possible be the issue, but wanted to go into the mechanic with an idea of what it could be.
Thanks
Magnum
MagnumVP is offline
post #2 of 10 Old 05-10-2008, 09:30 PM
itate
No Agenda Producer
itate's Avatar
It's the output sensor, its on the side of the transmission tailshaft. They run about $17 at Advance Auto. I went through this a couple months ago and it was a bear to figure out.
98 Dodge Ram SS/T Black-Silver Stripes - 5.9L, Hughes Plenum Pan & Gasket, Open element air cleaner,
Harland Sharp 1.7 rockers, shorty headers, 3.91 gears, poor man's throttle body mod, and Hellas behind the grill.
98 Dodge Neon Sport DOHC (262,000 miles)
68 Plymouth Barracuda - May 2009 VOTM
62 Chrysler Newport
itate is offline
post #3 of 10 Old 05-11-2008, 12:14 AM
greenriverboy
Green river boy is here!
greenriverboy's Avatar
MIne is doing this but it is the govener sensor or something like that and its a $150 peice.
greenriverboy is offline
post #4 of 10 Old 05-11-2008, 01:01 PM Thread Starter
MagnumVP
Just some more information about it. Perhaps this will help diagnose what the issue is.
From the truck being turned off. I start the truck and take off. The first time that the transmission attempts to shifts it goes to 3000 RPM's and the shifts. From then on, it shifts normally. Every once in a while it acts up but never as bad as the first time. It never shifts hard, it has no problem down shifting...at least yet and it sometimes takes a while to shift from 3rd to 4th, but never at really high RPM's.
If I disconnect the neg from the battery and reset the computer, the "Check Engine" light turns on when the truck shifts from 1st to 2nd during the initial startup and high RPM's.
MagnumVP is offline
post #5 of 10 Old 05-12-2008, 04:34 PM
chizzle1
REDNECK SPACESTATION
chizzle1's Avatar
Quoted: 18 Post(s)
just a dumb question, but have you adjusted the TV cable at all?
If the line pressure is set too high (TV cable too tight) then you will get the late shifting & gear hunting you are referring to.
01 Ram 5.9 Sport QC 4x4 - 175k, current build project - SCT Stage1 custom tune via Hemifever, Harland Sharp 1.7:1 roller rockers, Modded Kegger, Edelbrock ProFlow,52mm TB,180* t-stat,e-fans, pacesetter long tube headers, true duals with spun cats, Jones full-boar mufflers, 34x11 Falken ATs on 3rd gen Dodge 20"s, 3"TC lift, rebuilt 46RE w/HD internals, PML Deep Pan,SunPro Tranny Temp gauge,Rebuilt 231D,TSC Diamond Box, Sony head unit
10 Dodge Challenger R/T in Brilliant black - 392 cam,AFR shaker, MyGig 730N w/ navi,dvd,HD,u-connect & rear cam, 6 spd, Track Pak, SRT8 shorties & mids, home HP tuned, Jet 180*, BBK 85mm tb, SLP line locks, de-badged, resonators removed, DRL enabled, skip shift eliminator, mopar hood struts, functional hood vents, 392 chin spoiler
09 Suzuki 1255S Bandit Metallic Blue on black, 1255cc I-4, 6 spd, Yoshi can, Givi screen, K&N, Bags Connection tank bag, TPX fuzz buster, Techmount GPS holder, Suzuki center stand, World Performance Seat
2013 Dart Limited Pitch black, fully loaded, hers
SOLD 06 Hemi Durango 4x4 Limited in Atlantic Blue Pearl
SOLD 97 Ram 1500 SLT Laramie in DuPont Frost White Pearl
chizzle1 is offline
post #6 of 10 Old 05-12-2008, 10:33 PM Thread Starter
MagnumVP
It was putting out a P0720 code (courtesy of a Free error check from AutoZone. Replaced the Output Speed Sensor and it fixed it. Thanks for everything.
Here is that part that it needed.
http://www.partsamerica.com/productd...e=1179&PTSet=A
MagnumVP is offline
post #7 of 10 Old 05-13-2008, 08:34 AM
chizzle1
chizzle1's Avatar
Quoted: 18 Post(s)
glad you got her running right for cheap
chizzle1 is offline
post #8 of 10 Old 09-25-2008, 05:39 PM
Rico6161
Hey guys, I got a 95 with the same problem..
My 95 has the same issues with shifting.. Tranys was rebuilt about two yrs ago, but only put 2000 miles on her sense.. I looked for this speed sensor and mine doesn't look like this at all.. Mine has a 3 wire sensor that looks like it's part of the old cable speedo.. Has 1 bolt that holds it in.. Would my sensor do the samething / Shifting late? Whats the TV cable I read on here? Someone said it might need adjusted?
Thanks for any help..
Rico6161 is offline
post #9 of 10 Old 09-25-2008, 10:09 PM
chizzle1
chizzle1's Avatar
Quoted: 18 Post(s)
the TV (throttle valve I think) basically controls line pressure. More throttle = more line pressure for firmer shifts. It has a certain amount of control over kick down points as well.
It connects to your throttle cable assy at the throttle body, and can be adjusted near the firewall via a bracket assembly.
You should only adjust this a SMALL amount and I would advise you to mark the TV cable in such a way as to be able to set it back to were it was if you fook it up.
I adjusted mine shorter a while back (about 5 years) to increase line pressure in an endeavor to extend the service life of the tranny. It shifts a little too firm but I don't mind as I haven't needed a rebuild yet.
IMO the #1 way to make sure your 46RE tranny lasts is to keep it cool (180*) - deep pan, tranny cooler w/ dedicated fan, and temp gage.
edit: also check that the return spring for the TV cable is present at the tranny end of the cable.
chizzle1 is offline
post #10 of 10 Old 09-26-2008, 11:08 AM
89smurf
Urban Wheeler
89smurf's Avatar
Troof!
Chrome don't get ya home, but it'll sure get ya laid.
98 Ram 1500 QC SB, 318, SCT Tuner, CAI, high flow cat, headers, Electric fan, 8.5mm wires, 220L Aux. fuel transfer tank, 1500W Circulating block heater, DIY dual batteries with self boost ability.
89smurf is offline
    Plenum gasket procedure gunmetalgolfer 2G Dodge RAM - Drivetrain Talk 37 01-25-2008 03:25 AM
    Generic Chrysler Diagnostic Trouble Code List tactransman 1G Dodge Durango General Talk 0 10-18-2007 02:27 PM
    Generic Chrysler Diagnostic Trouble Code List tactransman 2G Dodge Durango General Talk 0 10-18-2007 02:27 PM
    Trans shifts at 3,900 RPM @ WOT. 98QuadCabV10 2G Dodge RAM - Drivetrain Talk 7 08-04-2005 09:11 PM
    Key Sequence for Codes on 04s scapegoat047 3G Dodge RAM - General Talk 10 03-05-2005 09:29 PM
