how much R134a psi to put in A/C system - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 3rd Gen (02 – 08) Forums > 3G Dodge RAM - General Talk
Hust
  how much R134a psi to put in A/C system - Posted: 05-06-2008, 08:20 PM
Post #1
I am relplacing the compressor on my 03 1500. How much pressure should be on the high and low side when I put refrigerant in the system after I draw a vacuum. I have high and low side guages.
ShortBus
 Posted: 05-06-2008, 08:25 PM
ShortBus's Avatar
Large consumer of rice
City: Jacksonville, FL
State: FL
Post #2
just put in the recommended amout of r134a.. there is a sticker under the hood that tells u the correct amount. but low side should be around 30-40 psi and high side around 320-340 IIRC..
i tried looking on dealer connect and all it says is
Refrigerant Charge Capacity Refer to the A/C Underhood Specification Label located in the engine compartment. R134a refrigerant
what if its missing the label? smart job chrysler.. dumbasses.
Zack
2003 1500 Ram RCSB HEMI 4x2 Atlantic Blue
DodgeVideos.com
Hawg Wild Truck Club
Exterior: Black Headlights w/ clear reflectors, DEPO LED tail lights, Custom Gator bed stripe, KC daylighters behind the grille, Black painted wheels. Painted misc. items in engine bay.
Performance: IAT resistor mod, TMR wire mod, Flowmaster 50 SI/DO (no tips), Air Raid air filter and heat shield (wouldn't call this a CAI.....).
Blue Truck Club Member #155
Regular Cab Truck Club Member #9
piper18
 Posted: 05-06-2008, 09:38 PM
piper18's Avatar
Great View
City: Fond du Lac
State: WI
Post #3
about 2 pounds is normal on most vehicals.
2008 Dodge Ram 1500 4x4 SLT, 5.7 Hemi MDS, Regular Cab, Long Box, 3.55 LS rear end ,17" cast wheels, Flame Red
Member of the Red Truck Club #231
Switch installed in chime circuit to turn off chime Click to learn How To add a switch to the chime circuit
Installed MDS indicator light on dash ---Click to learn How To install a MDS light
Tools Box w/ lights inside tided to cargo light
Custom made deer guard 2" pipe
Sportsmaster Tonneau cover w/top gun fabric
Mopar rear wheel liners
Iron Cross stainless 3" step bars
Tailgate open indicator light
9005 fog light bulbs
darell_n
 Posted: 05-06-2008, 10:03 PM
darell_n's Avatar
Boost, you say!?
City: Cochrane, AB
State: OTHER
Post #4
Weigh it in exactly, that's the only sure way. Ounces can make the difference between go and no-go. The high side will depend entirely on the ambient temperature and load on the system. 320-340 psi would blow sh*t up fast on the industrial stuff I work on, but vehicles are different (160 normal for me). In the 300s would be reasonable, but seriously, weigh it in for your own safety.
Cheap. Fast. Reliable. (Pick 2)
piper18
 Posted: 05-06-2008, 10:22 PM
piper18's Avatar
Great View
City: Fond du Lac
State: WI
Post #5
I charged systems using those 1 pound can and would just throw a whole can in at a time, when it didn't cool good enough. you don't have to worry about over pressure since you have a high pressure cut off switch.
ShortBus
 Posted: 05-07-2008, 12:21 AM
ShortBus's Avatar
State: FL
Post #6
most dodges use less than 2 lbs. and overcharging it will NOT cool better, contrary to popular belief..
Zack
DodgeVideos.com
piper18
 Posted: 05-07-2008, 09:45 PM
piper18's Avatar
Great View
City: Fond du Lac
State: WI
Post #7
My 95 used 2 pounds on the head, my 08 uses 1 pound 11 Oz. The 95 I had in several times and they never could find the leak so I just kept recharging it with 1 pounders. On all vehicles there is a accumulator on the firewall which acts like a reservoir for the freon so as the freon quantity changes the A/C keeps working at the same level.
darell_n
 Posted: 05-07-2008, 09:56 PM
darell_n's Avatar
Boost, you say!?
City: Cochrane, AB
State: OTHER
Post #8
Technically, the accumulator is a safety device to stop liquid refrigerant from smashing the compressor (located on suction side of the system). The drier will stack with excess liquid.
Error code P 0308 Ironhorce 3G Dodge RAM - General Talk 15 11-22-2008 04:41 AM
Generic Chrysler Diagnostic Trouble Code List tactransman 2G Dodge RAM - Drivetrain Talk 0 10-18-2007 01:27 PM
2007 Dodge Magnum is a Bold Blend of Packaging RAM MAN Rumor Mill & Gossip Talk 0 09-02-2006 06:00 AM
2004 Dodge Truck Highlights RAM MAN Rumor Mill & Gossip Talk 0 09-03-2003 04:27 PM
Press Kit: 2004 Chrysler Pacifica RAM MAN Rumor Mill & Gossip Talk 4 08-01-2003 02:24 PM
