Coolant Bleeding - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 2 Old 04-27-2008, 04:55 PM Thread Starter
racefan
racefan's Avatar
Coolant Bleeding
I flushed the cooling system on my 01 4.7 today.My Haynes manual said to refill it, run the engine @ 3000 rpm for 10 seconds then top off coolant. I know your supposed to bleed the cooling system on a 4.7 but what's the correct procedure? I just turned the heater controls to high, ran it at an idle & cracked the bleeder screw open,but I did not feel any air or anything from the bleeder screw.(I accidentally posted on drive train talk first)
2001 Durango
4.7
racefan is offline
post #2 of 2 Old 04-27-2008, 08:48 PM
Don Fox
Don Fox's Avatar
Racefan:
You are headed the right direction. I removed the bleed screw all together, and let the D idle while you continue to top off the level through the open filler neck. Make sure to manually run the rpms up a bit several times to help move the air out.
The process will take 20-30 minutes to complete. When you get nothing but pure coolant out of the bleed port, reinstall the screw and go for a short 1-2 mile drive.
You can also squeeze the top and bottom hose a bit during the process to get air out. Just be careful of the fan blades.
Don
2004 SLT Hemi Durango AWD Flame Red
w/ 3.55 gears. Mine since 03.26.10.
2011 Hyundai Santa Fe GLS AWD V6
Mineral Gray. Hers since 8.21.14
Don Fox is offline
    Coolant System bleeding racefan 1G Dodge Durango - Drivetrain Talk 1 05-05-2008 09:13 PM
    2004 Grand Caravan Right coolant question notacargirl Dodge Caravan General Talk 3 02-08-2008 02:22 PM
    Coolant in Cylinders bkoz Dodge Ram Truck 1st Gen (88 - 93) Forum 3 11-03-2007 07:03 PM
    Coolant recovery system and radiator cap rating vstanford 1G Dodge Durango General Talk 0 06-02-2007 12:22 AM
    Bleeding coolant system dirtmover Dodge Caravan General Talk 1 08-14-2006 11:56 AM
