headlights won't work, all others do - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 13 Old 03-30-2008, 08:01 PM Thread Starter
rebeldodge304
rebeldodge304
Question headlights won't work, all others do
I have a 99 dodge 2500, the headlights at low beam will not work, but the high beams will if I hold the switch just right. I have replaced both switches, but it doesn't help. (The headlight switch was listed as a 2000 switch).
Someone told me about a "ground control module" that may need to be replaced??? It has been 5 months. Does anyone have any ideas ?????
HELP
rebeldodge304 is offline
post #2 of 13 Old 03-30-2008, 08:22 PM
TORQUE THIS
You have a bad bulb. Same thing happened to me a few years back. Do you have driving lights? If I recall, it was one of them for me that was no good. If you don't turn on the driving lights, everything should work fine.
~Mark~
01 Quad Cab 3500 4x2 Cummins
96 Single Cab 1500 4x4 5.9 360 / Factory Plow
06 VW Jetta TDI
TORQUE THIS is offline
post #3 of 13 Old 03-30-2008, 11:08 PM
Red Sleeper
Blowin n' Goin
Red Sleeper's Avatar
Same thing happened to me just last night. I had a high but no low. Long storie short, went to napa got a set of brite lite lights and they light up so much better than the others. Ran me $25
Nick J
05 Cummins QCSB. TransGo Smarty H2O/CH4O
13 Jetta TDI 6spd auto
91 Cummins Dedicated water hauling vehicle
94 Z28 LT1 355ci 6spd Lots of Tubing
RockCrawling Dakota
Red Sleeper is offline
post #4 of 13 Old 04-08-2008, 11:06 PM
KKRRSS
Learning Grasshopper
KKRRSS's Avatar
Pull the switch (remove dash bezel with 4 screws), remove the switch knob and shaft (pull to "on" position and then push the little plunger on the side of the switch assembly), and then spray some contact/switch cleaner down into it (aerosol can at radio shack).
It should clean up and lubricate the switch.
KKRRSS
1996 Dodge Ram 2500 HD
4x4 Club Cab Laramie SLT
5.9 Cummins Turbo
BD Performance Torq/UnLoc Convertor Control
PacBrake Exhaust Brake
Fuel Slide
60lb springs
Pyro, Boost, and Tranny Temp in a pillar gauge pod
4" exhaust system
Yaesu dual band ham radio
Diamond dual band antenna
KKRRSS is offline
post #5 of 13 Old 04-09-2008, 08:32 AM
Davcruz
I disgaree...:)
Davcruz's Avatar
Different switch all together from a 96 model, his is a rotate knob. Not sure that will work for him.
David
2001.5 - 2500 HD CTD 4x4 Sport SLT Quad Cab
Fabtech 5.5 Long Arm Performance lift
Toyo Open Country M/T 315/75-16's
AFE Stage II Intake
BD XMonitor pyro, trans, boost digital pillar gauge
Westach fuel pressure gauge
Edge Comp w/wire tap
Magnaflow 4" Exhaust
Airdog FP100 and big line kit
Davcruz is offline
post #6 of 13 Old 04-25-2008, 11:44 AM
Meierznutz
Older, but no wiser.
Meierznutz's Avatar
Watch those early switches... D/C had a recall on them because they ran full power through the switch and they were prone to overheating and fires! The fix was a new switch design and a lay over wire harness. I dont think there is a deadline on a warranty repair but D/C should have the vin in their records to tell you if the update applied to your truck and if/when it was done.
'02 2500 Quad Short Box, HO Cummins, 6 speed,Fast Cooler and filter kits, Con-OFE clutch, 3:55 limited slip, Banks exhaust and Brake, K&N, Autometer Lunar series gauges, Air Dog 100gph, Adrenaline chip SOLD :-(
Current ride: 95 2500 2wd with a P-pump
90 Miata LS-1, 6 speed, 8.8 Cobra IRS
5-21-93 married, cost $15k
4-29-02 bought my Ram, cost $28k
3-15-99, 8-8-05 sons are born PRICELESS!
Meierznutz is offline
post #7 of 13 Old 07-03-2008, 11:53 AM
1baddak
1baddak
headlights wont work
this may sound dumb but a friend of mine has a 95 ram and the headlights quit. still have other lights. He said there wasnt any fuse for the headlights. There has to be .where is it.I havnt looked at it yet.
1baddak is offline
post #8 of 13 Old 07-03-2008, 12:49 PM
Red Sleeper
Blowin n' Goin
There are relays for low to high. Try to find and test the relays to se of your getting voletage through them. And I would have to think ther is a fuse for te headlights somewhere...
Nick J
RockCrawling Dakota
post #9 of 13 Old 07-03-2008, 01:28 PM
triplej1954
triplej1954's Avatar
Quoted: 2 Post(s)
What about the recall. Have a 96 that burnt the switch and wiring harness. They replaced it with the exact same switch.
triplej1954 is offline
post #10 of 13 Old 07-03-2008, 01:37 PM
Red Sleeper
Blowin n' Goin
Not sure, the dealer said my buddie coule but a switch when his fried in his 96 and they would instakk it for like $100. So we went off to used parts and picked ne up for $20 and did soem serious soldering.
Nick J
RockCrawling Dakota
post #11 of 13 Old 07-07-2008, 11:06 AM
Meierznutz
Meierznutz's Avatar
IF all they wanted was $100 I would have let them do it, then if the dash burns later it's on them for faulty repair. This is a known issue on the 94-98.5 trucks with the push/pull headlight switch. The fix is a new switch (may be the same switch) but an extra harness that bypasses the switch itself with the full voltage. I believe there is a relay that uses the switch to activate power direct to the lights. The Dually's with roof lights, fender lights, and tail gate lights were most prone to issues, but others have had fires too.
post #12 of 13 Old 07-07-2008, 06:37 PM
Red Sleeper
Blowin n' Goin
Yea his would start smoking, kinda scarry. But we fixed it and no problems since. Knock on wood.
Nick J
RockCrawling Dakota
post #13 of 13 Old 07-21-2008, 12:58 AM
Dodge2500
DodgeRamOhio
Dodge2500's Avatar
I had the same problem with my 98 after i started adding lights the switch got hot enough that it melted the wireing harness plug and the inside of the switch i went to the junk yard and got a headlight switch plug and 12 inches of the wiring and replaced my plug but while doing the wiring i notice that the worst part of the melting on the factory plug was around the hot wire and parking light wire, so i installed a relay with direct power from the battery and its setup so the all the headlight switch does is trips the relay ive had no problems sence i did this and its been almost 3 years ago.
DODGE MAKES IT CUMMINS SHAKES IT
1998 Dodge Ram 2500 4x4 with a 12 valve Cummins turbo diesel.
AFC housing, torque plate, and star wheel full forward.
BHAF installed.
KDP done.
5 spd trans.
4 inch turbo down pipe from Jardine. $ 75.00 on ebay
5 inch exhaust from the down pipe to the transfer box thats 6x6 steel to a pair of 5 inch stacks, turnouts,miter cuts,or flat tops with flappers just depends on which ones i want to run.
8 LED lights in lower air dam, LED lights in tool box 18 total in box. installed Cab lights with LEDs. nexlight LEd on pinch mold. LED light bar under tailgate.
custom sub boxes joined with an amprack and green neons two 12 inch audiobahn subs. 1000 watt lanzar vibe amp.
Gauges ISSPRO Pyrometer, Boost, fuel pressure.
wish list
cb in overhead console, bigger turbo, bigger injectors, new clutch, step bars, air horns, diamond plate bed cover, and more.....
Green Truck Club Member #8
Dodge2500 is offline
    Headlights are not working Please Help yedi015 2G Dodge RAM - General Talk 17 04-27-2007 11:07 AM
    Turn Singals DO NOT WORK budman5555 1G Dodge Durango General Talk 6 08-31-2005 07:37 PM
    No Headlights! b150vanman Dodge Ram Truck 1st Gen (88 - 93) Forum 2 11-03-2004 08:21 PM
