1997 Dodge intrepid will not start - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 3 Old 03-28-2008, 11:05 PM Thread Starter
Lestafur
Angry 1997 Dodge intrepid will not start
Ok I have a (or my daughter has) a 1997 Dodge Intrepid with the 3.3 engine. It wont start but, turns over very well. I have tried to get the codes buy turning the key on and off over and over. No codes. I have no spark, No power at the coil. don't know where to turn now. Please let me know something.
Thanks
les
Lestafur is offline
Quote Quick Reply
post #2 of 3 Old 03-31-2008, 01:41 PM
RT2NV
Intrepid Madness!
RT2NV's Avatar
You should have codes of some kind showing up. It's sounds like it may be a cam or crank sensor.
Be sure you check for codes this way :
Cycle the ignition key to ON, OFF, ON, OFF, ON within 5 seconds.
Count the number of times the MIL (check engine light) on the instrument panel flashes on and off. The number of flashes represents the trouble code. There is a slight pause between the flashes representing the first and second digits of the code. Longer pauses separate the individual two digit trouble code.
An example of a flashed DTC is as follows:
Lamp flashes 4 times, pauses, and then flashes 6 more times. This indicates a DTC code of 46.
Lamp flashes 5 times, pauses, then flashes 5 more times. This indicates a DTC code of 55. A DTC of 55 will always be the last code to be displayed. This indicates the end of all.
RT2NV is offline
post #3 of 3 Old 03-31-2008, 08:40 PM Thread Starter
Lestafur
Thanks,
I just had it towed to the dealer. Their computer will be able to tell me what is going on.
Lestafur is offline
    Factory Stock 1/4 mile and 0-60 times. dodgeneonACR98 Street and Strip Talk 8 05-05-2009 07:53 PM
    I never knew these EXSISTED!?!?!?! CRMRAM 3G Dodge Dakota General Talk 23 10-19-2007 06:36 PM
    Dodge Announces 2008 Dodge Dakota Pricing RAM MAN Rumor Mill & Gossip Talk 0 07-11-2007 06:14 AM
    2006 Dodge Ram 1500 Information RAJ 3G Dodge RAM - General Talk 20 06-18-2005 12:18 AM
    2004 Dodge Truck Highlights RAM MAN Rumor Mill & Gossip Talk 0 09-03-2003 04:27 PM
