engine serial numbers - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 2 Old 03-16-2008, 06:58 PM Thread Starter
c0zgrove
c0zgrove's Avatar
does anyone know how to decode engine serial numbers to find the year of the motor i did a search and came up with nothing my block has the numbers 53006714 318 27 i need to know the year of the motor if anyone can help thanks
97 ram 2500
12v cummins
auto trans
and hummer wheels
c0zgrove is offline
post #2 of 2 Old 03-16-2008, 11:59 PM
slambony
slambony's Avatar
Are those numbers stamped on the machine pad on the front left corner of the cylinder block? Should be stamped right below the cylinder head if your looking at the front of the engine it will be on the right, just below the head. Might have to use sand paper to see it. Hope this helps you. Think the ones you gave are casting#'s on the side of the block? Whole nother ball game?
X M AAA YYYY OOOO
X= last digit of year
M= Plant-M= Mound Rd.
S= Saltillo
T= Trenton
K= Toluca
AAA= Engine Displacement (CID)
YYYY= Month/Day
OOOO= Engine Serial Code
On the eighth day god created the"426 Hemi"
2000,2500 ext-cab 5.9 4/4
5-speed 4:10's
Brass cap and rotor
Hughes plenum pan
Modified TPS
Center Force II clutch
JBA 8mm wires (w/ horizontal wire looms)
New Viton valve seals
stainless steel shorties
180* T-Stat
AIS Ram Air Box (dual snorkel)
Ram side exhaust 3" in 2 1/2 outs magna flow
next harland sharp rockers, and TB
slambony is offline
    New look for 07 Durango RAM MAN Rumor Mill & Gossip Talk 4 03-19-2007 04:11 PM
    Introduces Cleaner, Quieter and More Powerful 6.7-liter Cummins Turbo-Diesel Engine RAM MAN Rumor Mill & Gossip Talk 13 11-29-2006 03:28 PM
    Avenger Timing Belt ? avengerboi2950 Vintage Dodge Car Forum 12 07-22-2006 07:15 PM
    5.9 pinging jmcdona 1G Dodge Durango General Talk 11 05-01-2004 09:33 AM
    Dirty Looking Oil dodgehemi345hp 3G Dodge RAM - General Talk 12 09-26-2003 06:37 PM
