How do I change the bypass hose? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 12 Old 03-09-2008, 09:38 AM Thread Starter
anthdale
Question How do I change the bypass hose?
I have a 97 Dodge Ram 1500, 5.9L. I just put the 3rd water pump on in 2 days until I realized it's the bypass hose. Looks like it is going to be difficult to get to and change. Can someone tell me the best method for doing this? Thanks!
anthdale is offline
post #2 of 12 Old 03-09-2008, 10:02 AM
sony224422
sony224422's Avatar
Quoted: 9 Post(s)
i think this is a common problem on our trucks.. i have a small leak too and i think its from there.
2004 QCSB 2500 hemi with 4.10s Laramie
Back rack with whelen freedom 2 light bar (custom made by me with extras)
Whelen Par 36 aircraft landing lights behind the grill, Whelen par 36 spot lights for reverse lights, Whelen strip lights in the bed (6 in total), Whelen cencom to control everything
In bed tool box with lights and extra battery with isolator and also a solenoid to connect both batteries together if i need to
Color matched grill,
Fox box with 2 diamond d3 12's with Diamond d3 600.1 amp
SRT-10 a pillar with trans temp gauge
Mag-tec trans pan
Superchips 3865 with trans tuning
Nitto trail grapplers
POWER WAGON WINCH SET UP
Alpine ina-w900bt with reverse camera
Alpine type r 2 ways in the doors powered by alpine pdx-f4
steering box brace
sound deading
Big 3 done with 4 gauge
E-fan
POR-15 the frame and under body
Jimmy jammers
sony224422 is offline
post #3 of 12 Old 03-09-2008, 10:51 AM
chizzle1
REDNECK SPACESTATION
chizzle1's Avatar
Quoted: 20 Post(s)
you might be able to get to it another way, but the way I do it is by removning the water pump.
I usually change the bypass hose every time I have the pump off for this very reason.
01 Ram 5.9 Sport QC 4x4 - 180k+, current project - SCT Stage1 custom tune via Hemifever, Harland Sharp 1.7:1 roller rockers, Modded Kegger, Edelbrock ProFlow,52mm TB,180* t-stat,e-fans, pacesetter long tube headers, true duals with spun cats, Jones full-boar mufflers, 4.56s front & rear, LSD, 34x11 Falken ATs on 3rd gen Dodge 20"s, 3"TC lift, rebuilt 46RE w/HD internals, PML Deep Pan,SunPro Tranny Temp gauge,Rebuilt 231D,TSC Diamond Box, Sony head unit
10 Dodge Challenger R/T in Brilliant black - Barton STS, 392 cam,AFR shaker, MyGig 730N w/ navi,dvd,HD,u-connect & rear cam, 6 spd, Track Pak, SRT8 shorties & mids, home HP tuned, Jet 180*, BBK 85mm tb, SLP line locks, de-badged, resonators removed, DRL enabled, skip shift eliminator, mopar hood struts, functional hood vents, 392 chin spoiler
09 Suzuki 1255S Bandit Metallic Blue on black, 1255cc I-4, 6 spd, Yoshi can, Givi screen, K&N, Bags Connection tank bag, TPX fuzz buster, Techmount GPS holder, Suzuki center stand, World Performance Seat
2013 Dart Limited Pitch black, fully loaded, hers
SOLD 06 Hemi Durango 4x4 Limited in Atlantic Blue Pearl
SOLD 97 Ram 1500 SLT Laramie in DuPont Frost White Pearl
chizzle1 is offline
post #4 of 12 Old 03-09-2008, 06:19 PM Thread Starter
anthdale
Thanks for the replies. It's not the water pump that looks difficult with changing it. The upper part of the bypass hose looks to go under a bracket and disappears. I am hoping I can easily remove the bracket to get to the hose but not sure if there is going to be some hidden obstacles in the way. If anyone has done this on my model, I sure would like to hear some advise before I start tomorrow?
anthdale is offline
post #5 of 12 Old 03-09-2008, 06:44 PM
bigkuntry72
bigkuntry72
i believe if you unbolt the a/c compressor(4 bolts) and lift it up, theres a slot in the bracket to get at the hose clamp. but the bracjet itself is only 4 bolts too i think. pick your poison. only time i did mine was puttin engine back together so its all kind of a blur.
1997 ram 2500 4x4- 2inch leveling kit & 3inch body lift. 305/70/16 goodyear ats.
engine specs-360 bored & stroked to 408ci. eagle crank and rods, ross racing forged pistons( 10 to 1 cr), all arp hardware, ported heads, custom grind cam, melling high volume oil pump, moroso 7 qt oil pan, M1, F&B 55mm tb,FMS 30lbs matched injectors,14x5 open air filter, msd ignition, Doug Thorley tri-y headers to true duals, 2800 stall converter.SCT tuned by hemifever!!
to do list- new paint, redo interior, bigger meats when i finish burnin up the 33's.
bigkuntry72 is offline
post #6 of 12 Old 03-10-2008, 05:56 AM
chizzle1
chizzle1's Avatar
Quoted: 20 Post(s)
you can get to the bypass hose without removing anything except the water pump.
The bypass hose is only about 3-5" long, it's basically just an molded elbow.
chizzle1 is offline
post #7 of 12 Old 03-10-2008, 08:55 AM Thread Starter
anthdale
I know what the bypass hose is... Looking at it, there is no way to get to the back clamp by removing the water pump. I have had the water pump off three times and would have changed the hose if it was that simple. Thanks for your replies...
anthdale is offline
post #8 of 12 Old 03-11-2008, 01:07 PM
DodgeOkie
On my truck, you can get to it by removing the bracket. Removing the pump only leaves the other end of the hose under the bracket. Plus, you then have to put a new seal on the pump. Your setup may be different but I'd try the bracket first.
'00 Ram 1500 SLT 5.9 4x4
My Cheap Mods:
Dashmat
Vent Shades
Door Window Tint
10 CD Changer
DodgeOkie is offline
post #9 of 12 Old 03-11-2008, 10:26 PM
Jmw132001
Jmw132001's Avatar
Quoted: 2 Post(s)
remove the a/c compressor and alternator, then remove bracket to get to the bypass hose clearly.
Justin
Resigned July 19th 2011
COIN HOLDERS ASSOCIATION MEMBER # 88
Beta tester for online games.
1998 Dodge Ram 1500 qc sport 360 4x4
208,300 original miles (as of 9-25-10)
new transfer case, brakes, shocks, radiator, water pump(twice cause of faulty parts), front balls joints, trak bar, front u-joints, tires, heater core.
Jmw132001 is offline
post #10 of 12 Old 03-14-2008, 08:57 AM
Silver_DodgeRam
Mmmmmmmmm, beer.
Silver_DodgeRam's Avatar
Quoted: 2 Post(s)
Just remove the alternator, the ac compressor, and the accessory bracket. Then you'll be staring straight at the bypass hose. Piece of cake. There is no need to remove the water pump.
2009 Dodge Ram 1500 4x4, 5.7 Hemi, Crew - work in progress
2008 Chrysler Aspen 4x4, 5.7 Hemi, Loaded
Silver_DodgeRam is offline
post #11 of 12 Old 03-17-2008, 10:49 AM
w0rm
Another suggestion, cut the old one in half to remove it, or else it's a real pain to twist it free since it's an elbow.
1998 Ram 5.2L 1500 Sport
-Hughes Plenum Pan & Gasket
-Ported TB & Intake Manifold
w0rm is offline
post #12 of 12 Old 03-19-2008, 06:03 PM Thread Starter
anthdale
You guys were right on with your suggestions. I unbolted the a/c and moved it out of the way (did not decompress it!). I unbolted the alternator and moved it out of the way. I removed the bracket (middle pulley holds a bracket bolt) and the bypass hose was easily accessible. Also, it was a pain to twist off but I finally got it. Job took about 2 to 3 hours. Water pump was never removed. I appreciate all of your comments... Thank you!
anthdale is offline
    Water Pump vs. Bypass Hose 1994RamGearhead Dodge B-Series Vans 1971 - 2003 4 05-17-2007 09:35 PM
    Researching the lean burn igntion system 87Dodgeman 1972-1987 Dodge Ram Trucks (D, W-series) 22 05-17-2007 08:33 AM
    Help with hose removal. Weird metal fitting. DuoWing Dodge Caravan General Talk 1 04-14-2007 09:46 PM
