'99 ram steering box - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 8 Old 03-04-2008, 02:01 PM Thread Starter
slt91
Exclamation '99 ram steering box
Ok went out ot carquest and bought a "rebuilt" steering gear box and installed it in the truck. Where the steering shaft and pitman arm go on it is "idiot proofed" you can only put it on one way. (and yes I double checked it) Now if I hold my steering wheel straight I go to the left.. I have to hold the wheel at a 45 degeree angle on order to drive straight.. Is there a adjustment on this? Or did I get a defective gear box.. And no I didn't have this proplem before with the old gear box. I replaced it because there was a ton of slop.
Thanks!!
BTW this is on a '99 Dodge Ram, 2500, 4x4.
1999 2500 Dodge Ram Ext. Cab. 4x4
slt91 is offline
post #2 of 8 Old 03-04-2008, 04:43 PM
BigDodge99
BigDodge99's Avatar
The rod that goes from the pitman arm down to the axle has a sleeve adjustment just a few inches from the pitman arm. Loosen the two nuts on the sleeve and turn it. Thats what is used to straighten your wheel.
1999 Ram 1500, 4x4, 408, 6 inch Dick Cepek lift, 2.5" King shocks, 35" BFG MT , Weld Stone Crushers, SSBC Billet Twin Piston Calipers, EGR Braided Stainless Steel Lines, Mopar tow hooks, 4.56 gears, Rockkrawler kwick disconnects, DT trac bar, True Trac in front, KB headers, True Duels w/Suppertrapp Mufflers, 47 RE, Stereo: Zapco amps, Focal componant set, 2 Kicker CompVR subs, Alpine head, and still going.
BigDodge99 is offline
post #3 of 8 Old 03-04-2008, 05:48 PM
BigGreenV10
Big Green
BigGreenV10's Avatar
WHen you put the shaft on the top you probably got it twisted and not put on the same but what ^^^^^^^^ said you can adjust it that way.
POWDER COAT CLUB MEMBER #1
DON'T TOUCH OUR TRUCK CLUB #2
GREEN TRUCK CLUB MEMBER #31
V10 RAM CLUB MEMBER # 35
MILITARY TRUCK CLUB #147
CRACKED DASH CLUB # 32
2000 2500 V10 4x4 Ext. cab 6" suspension 37 x 12.5 x 16.5 with 4.88 gears.
SCT tuner, Cold air and custom exhaust.
Tail lights, fuel filler door and tail gate handle shaved. Body color fiberglass bed cover and fender flares. Custom all steel 4" cowl hood, custom front bumper.
100% Xtreme Kreations Club President looking for members
BigGreenV10 is offline
post #4 of 8 Old 03-04-2008, 05:49 PM
BigGreenV10
Big Green
By the way how much was it
post #5 of 8 Old 03-04-2008, 05:54 PM Thread Starter
slt91
Thanks Big Dodge.. I'll try that later... Makes sense...
slt91 is offline
post #6 of 8 Old 03-04-2008, 06:02 PM Thread Starter
slt91
elliottecarlose... They Idiot proofed this item... There is no way that you can just make an adjustment of 1 click to the left or the right... It was really easy except for the plow bracket in my way.. It cost me $195.00 rebuilt and lifetime warranty on it. The only thing that sucked was the $250.00 core charge.. They REALLY want it back!!
Are you going to have to replace yours?
slt91 is offline
post #7 of 8 Old 03-05-2008, 02:52 AM
nhlbill
Ram x2
nhlbill's Avatar
You cannot install the pitman arm onto the steering gear any other way than the way it goes on, and on that issue you are correct. However, you could have accidently turned your steering wheel while slightly while the steering gear was off and that would have had an effect on how straight the wheel was even though the pitman arm goes on only one way.
You can easily adjust the drag link to straighten out the steering wheel though without effecting any suspension alignment.
99 Ram Sport -318, 5spd,
JB Conversions NV231HD with SYE and CV rear driveshaft/7" SJ coils/RK long arms/RS9000XL/Thuren TB/1-Ton steering/ 3" PA Body Lift/38.5-14.50-17 Xtreme AT's/D60's/ARB's/5.13's/ EMS Off Road Hub Conversion/One peice passenger axle/chromolly's
Rockcrusher Covers/BDS Shackle flip/ U-Bolt flip/Zero Rates/Mopar Perf. Air Cleaner/ Mopar Perf. 7.5mm wires/Coverlay dash/Alien Patrol Bumper/Sony & Alpine system with single 12" behind seat
nhlbill is offline
post #8 of 8 Old 03-05-2008, 07:21 AM
BigGreenV10
Big Green
Ok I was just saying I put a new steering shaft on my truck but it was a borgerson and it was not straight after installed pulled it back off and put it on again and was straight. By the way nhlbil I got those parts installed you recomended the steering brace and it tightened things up allot. Found my play was in the stock steering shaft was allot in it but sure the brace will help. Looks cool also.
    All-new 2009 Dodge Ram Breaks From the Herd — Literally RAM MAN Rumor Mill & Gossip Talk 4 01-17-2008 09:46 AM
    2007 Dodge Ram Heavy Duty RAM MAN Rumor Mill & Gossip Talk 0 09-02-2006 07:14 AM
    Dodge Delivers Mega Value with All-New 2006 Dodge Ram Mega Cab FreeLantz Rumor Mill & Gossip Talk 0 09-02-2005 11:59 PM
    2006 Dodge Ram 1500, What's New for '06 RAM MAN Rumor Mill & Gossip Talk 4 07-19-2005 10:31 AM
