Go Back   Dodge Talk Community Forum > Dodge Vehicle Forums > Stratus Talk > Stratus 2nd Gen (01 - 06) > 2G Stratus - Performance Talk
Scott17
  Question Engine runs rough-need ideas - Posted: 02-13-2004, 08:38 AM
State: ON
Post #1
I'm looking for some ideas. I have a 95 Cirrus, 2.5L V-6, 180,000 Miles. I have been experiencing problems accelerating from a start (especially when the engine is cold). It dies out and stumbles very bad with an occasional backfire. If I feather the throttle up to about 5 MPH it runs fine. The other symptom is that when cruising at about 70 MPH, it will occasionally stumble (almost like it is starving for gas) then run fine. Twice now, it would not start. A day later it starts fine. So far I have replaced both O2 sensors, idle air bypass motor, MAP sensor, plugs and wires, EGR valve and timing belt. The problem has greatly improved with these changes, but still exist and seems to be getting worse. Fuel pressure is 47 PSI and stable (checked in garage not while driving). Three things I can think of are fuel pump, Coil, or Cam position sensor. I can't scan the car because it is a transition year and is not supported by most hand held scanners. Any ideas?
Registered users do not see this ad or IntelliTXT ads. Please Register today! Its quick, easy and free!
LB3711
 Posted: 02-13-2004, 04:36 PM
LB3711's Avatar
>> Moose <<
City: Trumbull
State: CT
Post #2
180,000 miles your engine might just be dieing. Have you checked compression? What about the TPS (throttle position sensor)
2001 Dodge Stratus ES 4Dr. 2.7L Magnum DOHC V6.
http://pages.cthome.net/lb3711 :: http://www.cardomain.com/id/lb3711 :: http://www.msnusers.com/LB3711Stratus
2002 Dodge Durango SLT 4Dr. 4.7L Magnum V8.
http://www.cardomain.com/id/lb3712
http://www.myspace.com/lb3711
Proud Member of The Original WCPW
HID CLUB #13
Click HERE to view the complete signature...
Car of the Month Award!:  - Issue reason: Dec 03 Car of the Month Winner!Car of the Month Award!:  - Issue reason: Sep 05 Car of the Month Winner!
rkfsm
 Posted: 04-23-2004, 08:18 AM
rkfsm's Avatar
City: Charleston, SC
State: SC
Post #3
I would also suspect the throttle position sensor. Get an analog multimeter. Not a digital because they don't respond fast enough. Disconnect the TPS from the harness, set the meter to read resistance, connect the meter to the TPS and slowly sweep the throttle and watch the meter needle for jerking.
If you want to do a quick check, you can do this next one as well. I now this works on a Ford, but I've never tried it on a Dodge. With the engine running, tap on the TPS very gently with a metalic object. Listen to the injectors, not the engine. If the TPS is bad, you'll hear the timing of the injectors change.
Russ
LB3711
 Posted: 04-23-2004, 03:37 PM
LB3711's Avatar
>> Moose <<
City: Trumbull
State: CT
Post #4
Russ
Cool idea never thought of that. I would also check for a plugged injector too. I've had to replace 2 on a neon already.
HID CLUB #13
rkfsm
 Posted: 04-26-2004, 08:36 AM
rkfsm's Avatar
State: SC
Post #5
One other thing too...... On some of the Dodges, particularly the newer ones, the TPS has to be calibrated after installation. Don't know how to do it, but my maint manual says it needs to be done.
Russ
SANDMAN6G73T
 Posted: 05-24-2004, 05:08 PM
Post #6
Check the EGR valve, common problem on the 6g73.
Also check the O2 sensors.
1995 Dodge Avenger ES V6 Turbo Stage II
1991 Jeep Cherokee Sport 2dr 4.0 Liter HO
1998 Dodge Intrepid Base 2.7
