PCM Reset? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 25 Old 02-16-2008, 11:51 PM Thread Starter
1fgmtnbyker
PCM Reset?
Whats the correct way to reset your PCM? When and how often should we reset the PCM?
2002 Dodge Ram 1500 Quad Cab 2wd 5.9L/360
Gibson Exhaust,K&N FIPK system,Superchips Programmer,50mm trottle body,Auburn LSD,4.56 Motive gears,B&M Aluminum Deep Transmission Pan,Hypertech 180 degree PowerStat, Firestone Ride air-bags, Air Ram Jet Scoop, Drilled and Slotted rotors
1fgmtnbyker is offline
post #2 of 25 Old 02-17-2008, 12:54 AM
dmcelhannon
Admin - David Mack
dmcelhannon's Avatar
Quoted: 235 Post(s)
1) With the key out of the ignition
2) Disconnect the Negative battery Cable.
3) Put the key in the ignition and turn it as if you where trying to the START it.
4) Release the key and leave it in the “ON” position and let it sit for 10- 15 min
5) Remove key from the ignition.
6) Re-attach the negative battery cable.
7) DO NOT TOUCH THE THROTTLE when starting the truck for the first TWO times!!!
8) Start truck and let idle till it reaches operating temperature.
9) Turn truck off for 5-10 seconds.
10) RE-START the truck but DO NOT TOUCH THE THROTTLE!
11) Let the truck return to normal idle (500-600 RPM’s)
12) Turn truck off, and then start her up and take her for a LIGHT test drive… NO WOT testing yet.
13) After driving around the block letting your computer LEARN the new air flow turn her off one last time…
14) Fire her up and drive her the way you want.
The second way:
1) Pull fuse #19 or #23 or #31 (vehicle year dependent)
2) Close door and buckle seatbelt (technically you don't have to buckle the seatbelt, but it helps to stop all unnecessary chimes)
3) Put key in ignition and turn to "on" and wait until all chimes stop (on...not start!)
4) Turn key to start and hold until you hear 2 chimes (I think it was about 15 seconds or so)
5) Turn key off
6) Re-install fuse
7) You're good to go
dmcelhannon is offline
post #3 of 25 Old 02-17-2008, 02:40 AM
hemi-dad
hemi-dad's Avatar
how do you know which fuse for your particular year model ?
SLOWEST QC HEMI TRUCK ON DT
hemi-dad is offline
post #4 of 25 Old 02-17-2008, 07:52 AM
pfifty
pfifty's Avatar
It should be listed on the underside of the cover
2004 dodge ram quad 5.7 Hemi
Blue Truck Club member # 105
mcgauphys 2/4 drop,Pacesetter LT's,Viper efan,Spectre CAI,Magnaflow high flow cats,belltech sway bar,precision 4.10's,Auburn lsd
pfifty is offline
post #5 of 25 Old 02-17-2008, 12:56 PM
dmcelhannon
Admin - David Mack
Quoted: 235 Post(s)
I need to add the battery disconnect to the end of the list. You simply remove the NEG battery cable for about five minutes, When you replace the NEG cable and start the truck, you need to leave the throttle pedal along until the computer picks-up the RMP’s up and it settle into a normal RMP level. It’s one of the favorites but I don’t believe it a complete reset of the computer.
So if I were to write-up the battery disconnect description; how long do I need put down for the total time? Is five minutes OK? Or should I leave it off the list?
post #6 of 25 Old 02-17-2008, 01:28 PM
04oklaram
04oklaram's Avatar
how often should you reset the PCM?
Red 2004 dodge ram 287
current mods: SOLD THE RAM
cowl hood
20's w/falken
double din dvd
headrest screens
flows
led tails
fire and ice
iggee covers
roll up ton
billet grill
fogs
04oklaram is offline
post #7 of 25 Old 02-17-2008, 01:40 PM
dmcelhannon
Admin - David Mack
Quoted: 235 Post(s)
I do a reset any time I change something on the truck or when it seems to be running odd.
post #8 of 25 Old 02-17-2008, 02:32 PM
KB112
KB112's Avatar
Quoted: 1 Post(s)
The fuse is labeled pcm/skim on it I believe. Mine is a 23 as stated above. 06 and up are the 31 I think.
KB
2004 5.7L Quad Cab
1/8: 9.113@70.814 --- 1/4: 14.365@95.470
Exterior: Blacked Out 06-20"s, 295/50-20 Falkens, 2/4 Drop - Hotchkis coils/DJM Flip, Sport Conversion, Mopar Air Dam, Good Hood, ARE Cover, Rollpan, Mopar fuel door, LED 3rd Brakelight, Black Headlights, HID Fogs, Powdercoated Black SS Grille, Homebrew Powdercoated bumper grill with smoked turn signals
Interior: Infinity pkg, Slammed1 Bezel, BedRug, SRT Pillar
Performance: Hotchkis F/R SwayBars, Bilsteins, MIT tube, AEM Wideband, Comp 260, 6.1L Pushrods, 6.1L Exhaust Springs, QTP Cutout, Super Chips, NGK 4306s, Taylor Wires, TransGo Shift Kit, AT3030, CalTracs.
Awaiting Install:Thorley Mid's
KB112 is offline
post #9 of 25 Old 02-17-2008, 04:09 PM
projnostic
Kaos AD
projnostic's Avatar
Purpose of reset?
GOD SQUAD #68 1972-Eternity !!
Trucks & Guns Club Member #? 41 ?
White truck club member #132
2005 2500 Heavy Duty 4x4 5.7 Hemi Auto
4:10 gears
285/75/17 Toyo Open Country AT on Power Wagon Wheels for summer
35/12.5/17 BFG MT KR Projects on Hummer Wheels for winter
Superchips 3815
CAI
Taylor shorty's
20% Tint to match factory rear
Kore anti sway/ end links
Carli Coils
Tire Gate
Custom Made Control Arms ( Thanks Frank )
Bilstiens
09 steering upgrade
Champion 10k Winch
Front Receiver Hitch
Fogs with 9005 10k Jap bulbs and toggle switch in cab to allow running with Brights or not
Behind grill Lights
Under rear bumper Reverse lighting (100 watt each) Relayed with rev for trigger
Bed rails
Clifford Auto Start
CB w/ lil wil ant.
projnostic is offline
post #10 of 25 Old 02-17-2008, 05:04 PM
brangus1111
Brangus1111
brangus1111's Avatar
The purpose is to give your pcm the opportunity to reset itself(calculate air-fuel for one)for any new modifications made I.E. exhaust or intake. Also for those of you who are always making mods I would recommend installing a battery cut-off. This will make the process alot easier and it also acts as an ati-theft device if installed correctly.
Truck Got Jacked at Demo Show in Dallas and Under Const. Once Again
2005 Ram 1500 Quad Cab SLT 4x4
Custom Paint, 22" Vigare Rims, Shaved Tailgate, SRT-10 Hood(Old) Twin-Scoop GoodHood(New), Speed Grille Inserts,SS Gen II Bumper Cover(New), FBI Steel Roll Pan(New), Color Matched Two-Tone Leather(New), Brake Kit Upgrade(New), Custom Bed-Liner(New)
Complete De-Badging, Door Handle Covers,
Brute Force CAI, Flowmaster Ser. 40 Td's,
LED Tail-lights, Recon 3rd Brake light, Street-Sceen Mirrors, Halo Headlights, and it's 4WD!
Coming Soon:
Came and Got Jacked
JVC KD-ADV49 Head-Unit, 7" JVC Head Monitors, Hifonics Brutus BXi 1606D Super Class-D Amp, (2) Hifonics Brutus BX10D2 subs, Custom Fiberglass Sealed Enclosure,
Goin Bigger and Better This Time
brangus1111 is offline
post #11 of 25 Old 02-17-2008, 05:08 PM Thread Starter
1fgmtnbyker
Should you reset it after you change the fuel from 87 octane to 91?
post #12 of 25 Old 02-17-2008, 05:14 PM
brangus1111
Brangus1111
No, your truck is set-up to run 91 octane and you really shouldn't be running anything else. Matter of fact, running 89 can void your warranty man if you have any left.
Coming Soon:
Came and Got Jacked
post #13 of 25 Old 02-17-2008, 05:17 PM
brangus1111
Brangus1111
exuse me I meant running 87 can void it
Coming Soon:
Came and Got Jacked
post #14 of 25 Old 02-17-2008, 06:06 PM
KB112
KB112's Avatar
Quoted: 1 Post(s)
Running 87 is not gonna void your warranty. The 5.7L is made to run optimally on 89 octane, but can run on 87 just fine. The other models 3.7, 4.7 and 5.9 all were designed for 87 from what I recall. Since 1fgmtnbkr has a 5.9 he is fine.
KB
2004 5.7L Quad Cab
KB112 is offline
post #15 of 25 Old 02-17-2008, 06:29 PM
brangus1111
Brangus1111
guess i missed the part where he was runnin a 5.9, but if that's correct about the warranty that's good to know, i was misinformed by the dealership then.
Coming Soon:
Came and Got Jacked
post #16 of 25 Old 02-17-2008, 06:36 PM
kenihemi
kenihemi's Avatar
Most years have different versions of the pcm. The resetting varies in some of them.
The disc of the battery does not work for most.
The correct fuse trick works for most. I'll put that at the end.
You do not have to reset it unless there is something drastic going on.
You can reset it to temporarily clear a code, things like that.
To reset it for minor changes doesn't do squat and will hurt mileage because the pcm has to learn again to set the proper parameters (adaptives), to make the best mileage and performance.
My 04 hemi manual says a minimum of 87 octane but they recommend 89. And, without any big mods, higher octane will only hurt mileage and performance.
Resetting the pcm and using high octane is just a feel good thing and can actually hurt you.
To reset the pcm in the 04 hemi
Leave battery CONNECTED, DO NOT DISCONNECT IT.
Buckle the driver seat belt to that it won't cause chimes that will be confusing.
Remove the PCM/SKIM fuse from the fuse box. Its marked on the bottom of the fuse box lid.
Insert key and turn all the way to START and hold it there until you hear 2 chimes. The truck will not turn over.
Remove key, unbuckle seatbelt, replace fuse, done.
The first time you go to start it, there may be a delay for cranking for a second or two. This is normal.
'04 Hemi Ram 1500 QC, 4X4, 4.56 gears, STS turbo = 450+RWHP, SCT Tuner, B&M MegaShifter.
kenihemi is offline
post #17 of 25 Old 02-17-2008, 06:37 PM
KB112
KB112's Avatar
Quoted: 1 Post(s)
Tell your dealership they are Tards. lol Straight from the owners manual.
KB
2004 5.7L Quad Cab
KB112 is offline
post #18 of 25 Old 02-17-2008, 07:31 PM
brangus1111
Brangus1111
Do ya really think they need to be told that!!??
Coming Soon:
Came and Got Jacked
post #19 of 25 Old 02-18-2008, 02:02 PM
kenihemi
kenihemi's Avatar
Brang... who are you asking?
kenihemi is offline
post #20 of 25 Old 02-18-2008, 02:11 PM
brangus1111
Brangus1111
Was askin KB if he really thought I needed to tell them that. It was meant to be sarcastic in sayin that they probably already know. You guys all probably know that you can call a dealership, ask a q and get an answer, then call the other dealership accross town and get a totally different answer.
Coming Soon:
Came and Got Jacked
    reset the pcm Wolfman707 3G Dodge Ram Performance Talk 15 04-22-2006 11:32 AM
    '98 Durango, changed plugs, reset PCM, bad move? johnDurango 1G Dodge Durango General Talk 5 03-02-2006 01:12 AM
    PCM Reset - Question fischputza 3G Dodge Ram Performance Talk 12 01-30-2006 05:11 PM
    Doing some mods, help me out guys. racerX_244 2G Dodge Dakota Performance Talk 27 02-28-2004 12:37 AM
