Anyone put rhino line the under carriage? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 15 Old 02-15-2008, 03:02 PM Thread Starter
xyberz
Any suggestions on this? There's already rust on the rear end and all over the stock exhuast. Good thing I'm gonna replace the exhuast in a little bit so I could care less about the rust on it. Actually I'm happy it has rust so it shows how crappy it really is. All exhuast should be stainless steel.
xyberz is offline
post #2 of 15 Old 02-16-2008, 12:30 PM
Hemi4wheeling
Hemi4wheeling's Avatar
It's normal for any vehicle.
2005 Dodge Durango Limited Hemi 4x4
MODS
Mopar Safari Rack, Westin Nerf Bars, Mopar Tow Hooks, BFG AT KO 285/70/17's, Custom 3in Flowmaster Exhaust, K&N CAI
Hemi4wheeling is offline
post #3 of 15 Old 02-16-2008, 12:34 PM
sca
sca's Avatar
Big 3 vehicles are rusting before they leave the factory! Wouldn't say that about a European or Japanese vehicle but within the first year you will see rust on any vehicle.
sca is offline
post #4 of 15 Old 02-16-2008, 12:38 PM
Hemi4wheeling
Thats because they put that putty goop on everything on the bottom that washes off after a year of use.
MODS
post #5 of 15 Old 02-16-2008, 12:40 PM
sca
sca's Avatar
Still helps preventing rust! I looked at a Jeep CJ a while ago at the showroom of my dealer....what a rust bucket!
sca is offline
post #6 of 15 Old 02-16-2008, 12:44 PM
Hemi4wheeling
That rust is only surface and does not do anything. Don't hate cause the Domestics are not afraid to show flaw. HAHAHA!!!!
MODS
post #7 of 15 Old 02-17-2008, 03:36 AM Thread Starter
xyberz
Surface rust isn't that bad but eventually it does out to full blown war on your truck rust. I'd rather be safe and line the bottom to prevent as much rust as possible. Even if it's not that pretty, it doesn't matter to me cause my face isn't under there all day long to notice.
xyberz is offline
post #8 of 15 Old 02-17-2008, 08:15 AM
Hemi4wheeling
Look people, these vehicles today are not made of the same metal they used to be. I used ot own an 83 GMC Sierra Classic Jimmy 4x4 (you know the BIG blazers). THat had so much rust from the "normal" GM rust that the seatbelt pulled out of the floor boards on day along with about a 6 in circle of floor attached to the bolt. LOL!!!! You don't see that now a days. And that vehicle was only 15 years old! COuld be too that I used that vehicle to surf fish with.
MODS
post #9 of 15 Old 02-18-2008, 07:18 AM
HEMI5PNTSVN
Chief's Pride!!!
HEMI5PNTSVN's Avatar
You can always buy the spray under coating in a piss can for couple of bucks at your local advance auto or pep boys and knock out the rust prone areas. I used the same stuff when I had a sound system in my old Ford Ranger, I pulled all the panels out and the factory speakers out and sprayed a coat of under coating to deaden the sound, it worked great and was very inexpensive. Also sprayed the inside of my speaker box to make it air tight.
2005 Unlimited Silvered-Out HEMI-D
Mods:
Flowmaster Series 40 Delta Flow, Chopped Resonator
#1 "Black Mamba" DIY CAI Club Member
DIABLO PREDATOR 93/TRANS TUNED
De-Trimmed and De-Badged
TB Lift
DOWNLOAD 04-06 SERVICE MANUAL
SILVER TRUCK CLUB MEMBER #172
MILITARY TRUCK CLUB MEMBER #36
HEMI OWNER'S CLUB MEMBER #13
HEMI5PNTSVN is offline
post #10 of 15 Old 02-18-2008, 07:36 AM
Ram3500Dually
Ram3500Dually's Avatar
Quoted: 38 Post(s)
Only problem with spraying that Rhino stuff on the undercarriage is having to do work on it down the road. Brake lines, wiring and bolts will be impossible to take off.
2013 Ram 3500 CTD 6.7L 6 Speed Aisin, 4:10 LSD
2005 Jeep Liberty Sport
1991 Shadow ES Turbo Convertible
1984 Mini-Ram Van (Show Van) **TOTM April 2007** In museum now
73 Pro Street Duster.**VOTM July 2008/ April 2011**
1951 Dodge 3 Window Business Coupe **VOTM Feb 2011**
1992 Custom Built Harley FXSTC Show Bike
2008 Harley FLHTCU Ultra Classic
DodgeTalk Administrator
Names Carl, if you cut me I bleed Mopar Blue
Past Trucks: 90 CC Dually CTD, 94 RC LB CTD, 95 CC SB 5.2L gas, 98 QC Dually CTD, 00 QC Dually CTD, 01 QC Off Road, 03 QC Dually CTD, 05 QC Dually CTD, 08 Dually CTD **ROTM April 2008**,10 CC Dually CTD,
Ram3500Dually is offline
post #11 of 15 Old 02-19-2008, 01:59 AM Thread Starter
xyberz
Only if you don't do a good job at prepping the areas to be covered. Just remove the bolt holding anything to the under carriage and then cover the whole bolt head with masking tape. When everything is done and dry, remove the tape and you'll have a clean area free of the under coating. Afterwards just put silicone to cover the bolt and seal it from water.
I put silicone on my friends dent on his car on the outside, and it's been years since I've done it and absolutely no rust. You can still see the bare metal underneath the silicone like it just happened yesterday. The silicone also cleans up too so it won't hold dirt like some may think.
xyberz is offline
post #12 of 15 Old 02-19-2008, 07:22 AM
Ram3500Dually
Quoted: 38 Post(s)
Do you have any idea how many bolts are on the undercarriage?
post #13 of 15 Old 02-19-2008, 09:24 AM
Hemi4wheeling
I was just thinking the same thing. LOL!!!!
MODS
post #14 of 15 Old 02-19-2008, 02:40 PM
Ram3500Dually
Quoted: 38 Post(s)
Not to mention any bolt on the INSIDE that the threads go thru the floor like a seat bolt. You would never get any of these bolts out after putting rhino on it.
post #15 of 15 Old 02-20-2008, 03:05 AM Thread Starter
xyberz
I figure there would probably be a lot of bolts. But like you guys mentioned, there is paint it yourself kits available even at Walmart. So it'd be easy to control what gets covered. And you only need to do it once so it'd be worth the effort after it's all said and done.
xyberz is offline
    fuel line length and replacment tips Megunticook 1972-1987 Dodge Ram Trucks (D, W-series) 12 12-29-2007 10:29 AM
    Brake Line Source MrAbody 2G Dodge RAM - General Talk 7 09-17-2007 01:08 PM
    rust-proof replacement fuel line Megunticook 1972-1987 Dodge Ram Trucks (D, W-series) 9 08-04-2007 02:50 PM
    which tranny line for temp sensor. DannyMK2 3G Dodge RAM - Drivetrain Talk 3 07-04-2007 02:30 PM
    Stainless steel brake upgrade RAM MAN 2G Dodge RAM - General Talk 4 03-25-2002 05:37 PM
