2001 Caravan display trouble code? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 11 Old 02-14-2008, 06:57 AM Thread Starter
silversong
Unhappy 2001 Caravan display trouble code?
My 2001 Caravan's engine light is on in the Information Console. I have searched for the method to display the error code on the trip/odometer (and I DID find this once before) but what I am finding online does not seem to apply to my van since I only have the trip reset switch. Would anyone have the method I need to read these codes for my van's year?
silversong is offline
post #2 of 11 Old 02-14-2008, 07:34 AM
XDGT03
Autozone, Advance Auto, Murrays, Napa all should have code readers and test for free.
1998 Dodge Grand Caravan Sport 3.3L Flex
1994 Jeep Wrangler 2.5L
1991 Honda Prelude 2.0L si
2003 Hyundai Elantra Sedan 2.0L
1968 Ford Mustang Convertable 289 Hypo
XDGT03 is offline
post #3 of 11 Old 02-14-2008, 07:38 AM Thread Starter
silversong
Thanks for trying, but I live in a remote area and do not have access to the above. There IS a way to do this, I found it before, but this time round I'm just not finding the right method :-(
post #4 of 11 Old 02-14-2008, 06:09 PM
mfahey
Quoted: 1 Post(s)
From alldata
OBTAINING DTC'S USING IGNITION KEY
Cycle the ignition key ON - OFF - ON - OFF - ON within 5 seconds .
The odometer will show the P-code for the DTC code number. Refer to the DTC chart for a detailed explanation of the DTC codes.
If no DTC's are present, the cluster will display one of two texts: "P1684" and "done" or only "done".
"P1684" is only a status and indicates that the PCM memory has been cleared within the last 50 ignition cycles and does not indicate a problem.
"done" indicates that NO DTCs are present and the procedure is complete.
2001 GC ES 207,000 miles
2015 Volvo V-60
2012 Camry Hybrid
1970 Camaro, original owner
mfahey is offline
post #5 of 11 Old 02-15-2008, 05:02 AM Thread Starter
silversong
Thanks, that worked. I did get code 1684 as well as 0455. Will go look it up now!
post #6 of 11 Old 02-15-2008, 06:04 AM
XDGT03
the 1684 is no problem
0455
POSSIBLE CAUSES
* Confirmed leak in the EVAP system
* Intermittent LDP monitor failure
XDGT03 is offline
post #7 of 11 Old 03-03-2008, 06:15 PM
derrickcurry
How can I reset the codes and get the engine light to go out without taking it to the dealer to have it done?
derrickcurry is offline
post #8 of 11 Old 03-03-2008, 07:48 PM
mfahey
Quoted: 1 Post(s)
My understanding is that if the evap system passes the test procedure 3 consecutive times, the code will reset on its own. If it isn't resetting, you haven't fixed the problem.
2015 Volvo V-60
2012 Camry Hybrid
mfahey is offline
post #9 of 11 Old 03-03-2008, 08:11 PM
derrickcurry
The dealer replaced the leak detection pump and purge solenoid on my 2001 Grand Caravan 3.3 and the light came back on the very next day.
I already have over $300 into the first set of repairs. What should I check for next? I'm getting codes P0300 and P0455 and the van runs very rough and almost sounds like it has an exhaust leak but I've looked at the exhaust and there aren't any apparent defects.
post #10 of 11 Old 03-03-2008, 08:16 PM
Rick99
The forum has a search function you can use to search your code and the term "evap leak" and you'll find lots of threads on this.
2003 Durango SLT
AWD, 4.7l
Mods: Remote Start
Just got a new set of BFG All-Terrains
Planning retrofit to 4WABS
1999 Durango SLT+
4x4, 5.2l
Mods: B&M Supercooler, Ford OEM Remote Start/Keyless Entry/Alarm, Heated Seats
01 T&C Limited 3.8l
Rick99 is offline
post #11 of 11 Old 03-03-2008, 08:26 PM
protegechris
Should the odo display the code even on a 96, or should I have to read the CEL blinks?
Originally Posted by mfahey
From alldata
protegechris is offline
    2001 dakota trouble code p1762 shingaling88 2G Dodge Dakota General Talk 7 03-04-2008 07:22 AM
    Trouble codes for neons 95-99 dodgeneonACR98 Dodge Neon - General Talk 87 02-25-2008 12:15 PM
    Code P0353 Trouble Puppetmaster 1G Dodge Durango General Talk 18 03-22-2006 09:29 AM
    2001 Grand Caravan Blinking Dash lights rickymon66 Dodge Caravan General Talk 2 09-19-2005 11:47 PM
    trouble code PO455 bob sinram 2G Dodge RAM - Drivetrain Talk 5 02-17-2005 08:50 PM
