Spun a Rod Bearing! - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 18 Old 02-12-2008, 09:10 PM Thread Starter
HoodooGuru
HoodooGuru
Spun a Rod Bearing!
As it says above.
I saw my mechanic today and he told me $3000 to fix it by removing the motor, crank ground, resize bearings etc.
Forget that I said! lol
I will be removing the engine now with some mates and have it bored out to a 2.2 litre! The machine shop will fit bearings etc and guarantee the motor for $1500!
I will then mount my race spec head back on. As well as have them fit some higher comp pistons for me!
Bit of a bugger but I been walking for 3 weeks now so another few months wont hurt me! lol
Good reason to upgrade. I looked at the 2.4 swap but we only have pt cruisers here in Aus with that size block and they are still very new here. Too pricey!
Oh well, its gonna be even faster then when its done! Woohoo
2001 Chrysler Neon SE.
Performance Mods:
Pedders Sports Ryder Lowered springs, CSA "Velocity" 15 inch alloy wheels & Toyo T1R-D low profile tyres, 2.5 inch cat back Lukey Turboflow exhaust, Highflow cat, Comp 200 Grind Camshaft, Race Spec P & P Cylinder Head with 3 Angle Valve Job & Decked 20 thou, Universal Polished Chrome Oil Catch Can connected to pcv valve, MPX 60mm polished aluminium throttlebody, Cold air intake, Cquence Motorsport Cross Drilled / Slotted Front Brake Rotors, Racing pod air filter, Quick / short shifter, Custom mid / long tube headers, Megan Racing underdrive pulley, Top Gun 8.0 high temp spark plug cables, NGK spark plugs, SPW Billet aluminium front strut brace, over bored 40 thou with 10:5.1 high comp pistons, lightened machined crankshaft, new conrods, ACL race spec bearing / rings kit, Fuelstar Fuel Catalyst, Nolathane front control arm bushes, Gripforce Sach Stage.1 racing clutch, Sparco fuel pressure gauge under the hood, Bendix "Ultimate" brake pads, dyno tuned with a Unichip piggyback ecu.
Future Mods:
Custom Box Style Intake Manifold & a Crane 14 camshaft / magnum valve springs.
External / Internal Mods:
Full viper body kit (As sold in Australia), Chrome mesh intake grille inserts, Sirius Plus 2000 55 watt driving lights, SCA Shift 55 watt spot lights, Boschmann 550 watt 6x9s, Roar RX-8 250 watt sub / amp cannon, Crack Hi / Low RCA Converter, Full tint, Autotechnica "Monza" leather gear shift, Isotta Taladega Race / Sports seats, 2x SRT4 turbo gauge pods with Splitfire oil pressure & air / fuel gauges, Splitfire volts & oil temp gauges mounted under the radio, Gold painted calipers, And a mighty MOPAR sticker!!
HoodooGuru is offline
post #2 of 18 Old 02-12-2008, 09:33 PM
sleeperrt
well I dont know to say wow that sucks or right on more power is always better.. so ill say both lol
2002 Dodge Neon R/T
Go parts- AEM CAI, Pacesetter header, Flowmaster duels, PCM, UDPs, Short Throw, rearend lowered 1", plugs&wires.
Show parts- momo sideskirts, falken 17" rims and tires, z3 fenders, euro tails,painted calipers,clear side markers and white underlight kit.
sleeperrt is offline
post #3 of 18 Old 02-12-2008, 09:46 PM
dodgeneonACR98
So whats UR excuse?
That sucks! But you were looking for a reason to upgrade anyhow werent you! LOL
Squad member #53 [/url]
04 Neon SRT-4
98 Neon ACR-2.4 swaped with goodies
dodgeneonACR98 is offline
post #4 of 18 Old 02-12-2008, 10:55 PM Thread Starter
HoodooGuru
HoodooGuru
Yeah!
But not like this! lol
Tip of the day:
When u get what u think is a valve train tick it COULD be a bad rod bearing! After replacing my whole valve train thats what it was. Only took afew days of normal city driving to score the crank that bad it needed machining!
Performance Mods:
Future Mods:
post #5 of 18 Old 02-13-2008, 06:17 PM Thread Starter
HoodooGuru
HoodooGuru
Well, heres the delio!
I am having my current short block re-machined. New flat top pistons, new rods, new bearings, lightened machined crank (rev, rev!), new rings and the biggie.....................................having the cylinders bored to approx. 2.2 litre capacity (machine shop said just under 2.2 litre).
Now thats gonna up the torque!
Cost is $2200! But I remove the motor and take it to the mechanic and he works it and builds it and gives it back to me as a long block with my race spec head etc installed. I then dump the motor back in. Atleast setting the timing will be dead easy with the motor out! lol
Won't take long at all to remove and re-install the motor surely.
Performance Mods:
Future Mods:
post #6 of 18 Old 02-14-2008, 01:58 AM
sohc98
Neon bug bites again
sohc98's Avatar
that sucks dude. But in the end it will be well worth it. You seem to have a lot of problems with your car tho.
2001 Sebring Sedan 2.4 Auto
A new 1gn will be mine soon!
sohc98 is offline
post #7 of 18 Old 02-14-2008, 08:19 AM
dodgeneonACR98
So whats UR excuse?
Sweet!!!!!!! Have fun bro!!! If I was in Aussie land you know id be there to help yo! I gotta get back out there on mine soon. Almost got it back up yesterday!!! YAY!
04 Neon SRT-4
post #8 of 18 Old 02-14-2008, 07:31 PM Thread Starter
HoodooGuru
HoodooGuru
Was quite funny actually when the mechanic looked at it. He said, you push this pretty hard don't u? lol I'm like...um.no...........well..........maybe! lol
He said ok then, lets build the ass outa it! lol
Sweet
I don't have many problems with my car at all sohc98. This is the first time that the car has broken down on its own accord, that is without my stupid help! Seeing as its done 138,000 klms thats pretty good really.
Performance Mods:
Future Mods:
post #9 of 18 Old 02-14-2008, 08:18 PM
sohc98
sohc98's Avatar
i remember about 2 months ago you said something broke was this it?
sohc98 is offline
post #10 of 18 Old 02-14-2008, 09:29 PM Thread Starter
HoodooGuru
HoodooGuru
Yep
Performance Mods:
Future Mods:
post #11 of 18 Old 02-15-2008, 11:48 PM Thread Starter
HoodooGuru
HoodooGuru
Update.......I'm installing 10:5.1 high comp pistons as its being bored out 60 thou!
Brum brum!
Performance Mods:
Future Mods:
post #12 of 18 Old 02-15-2008, 11:53 PM Thread Starter
HoodooGuru
HoodooGuru
If I don't go close to 190 crank hp after this there is a problem!
Installing 60 mm tb and box intake manifold at the same time.
Dyno time soon to follow! I can't wait!
My neon is starting to get an appetite for ALOT of rice! lol
Performance Mods:
Future Mods:
post #13 of 18 Old 02-16-2008, 02:26 AM
sohc98
sohc98's Avatar
i read on the .org that a 57mm is the biggest you should go and anything bigger is just goin to hurt your power.(dont know if its true but just puttin it out their)
sohc98 is offline
post #14 of 18 Old 02-16-2008, 07:36 PM Thread Starter
HoodooGuru
HoodooGuru
Can only get a 60 mm for 2 gens.
Performance Mods:
Future Mods:
post #15 of 18 Old 02-16-2008, 08:51 PM
sohc98
sohc98's Avatar
oh and i think what i was reading was for 1st gen anyway.
sohc98 is offline
post #16 of 18 Old 03-05-2008, 11:23 PM Thread Starter
HoodooGuru
HoodooGuru
Well, heres the update on my build. YES its still not completed, have another near month to wait! Argh.
I went to the machine shop today doing the work for me.
The have removed the motor and started to dismantle it.
They discovered afew problems that have been like that FROM THE FACTORY!
Firstly the bottom end bearings have totally delaminated from the backing metal! A bad set from the factory the head fuy said! Then next he said whats the oil consumption been like? I said its gotten worse lately and told him I was told new valve stem seals would fix it. He then tells me that they have measured the bore of each cylinder to find that cylinders 1 & 2 are fine but that 3 & 4 are BIGGER bores with the same size pistons and rings in it! lol
He said there is no sign at all of the motor being torn down before and machined. Everything still had the original factory seals and torqued up right. In cylinders 3 & 4 there was 50 thou play between the cylinder walls and the rings! And, the funny thing is there was NO smoke from the exhaust!!!!
It seems the factory did two different bore sizes on the motor half way thru the production! lol (What tha????)
So now anyway they have started to clean and machine the block.
Its getting dipped soon and bored 40 thou over. The block is also being decked 30 thou to up the compression. Then they are respraying the block bright red for me. They are going to do a compresssion calculation for me then to determine what pistons we want to install. 9:8.1 is standard for a 2001. Mine is closer to 10:1.1 with my decked head. Another 30 thou off the block I should be close to 10:4.1 overall compression.
The crank is also being cleaned and machined for oversize race bearings and then lightened a tad.
He said its gonna be a weapon when its installed. Apparently it will rev up like a 1.6 litre Jap motor but still have good low down torque. With the overbore and higher compression he thinks I should gain about 18 crank hp on 98 octane fuel. (standard premium fuel here in Aus). I am half shafting my throttlebody this weekend too and gonna start my box style intake manifold. This is gonna be a totally different car me thinks. Look out standard wrx's! Normal n/a ricers are not gonna stand a chance! lol.
I can't wait to do afew pulls on the dyno and take it for afew runs at the local drag strip. Video to come in the next month or so!
Performance Mods:
Future Mods:
post #17 of 18 Old 03-07-2008, 01:02 AM
sohc98
sohc98's Avatar
glad to hear its getting on its way, sounds like it should be pretty mean once its done. but im thinkin we need some pictures, everybody loves pictures
and keep us updated.
sohc98 is offline
post #18 of 18 Old 03-07-2008, 07:38 AM
dodgeneonACR98
So whats UR excuse?
Good luck with it Hoodoo!
04 Neon SRT-4
    Its a very sad day I think I spun a rod bearing.. demon217 1972-1987 Dodge Ram Trucks (D, W-series) 34 06-06-2007 12:10 PM
    Spun Crank Bearing in my 3.3L RE2 Dodge Caravan General Talk 10 05-04-2007 10:12 PM
    Failed Inspection - Wheel Bearing & tie Rod? golf4dj 1G Dodge Durango General Talk 3 10-09-2006 08:57 PM
    need some rod bearing help here!! coocoobird Dodge Neon - General Talk 1 04-26-2006 01:49 PM
    Con rod bearing replacement garyK 2G Dodge Intrepid - General Talk 3 01-17-2005 04:31 PM
