318 to 413 swap - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 23 Old 02-12-2008, 09:19 AM Thread Starter
POOLinstaller
POOLinstaller's Avatar
318 to 413 swap
I have a 4x4 89 ramcharger With a 318..I just pulled a great running 413 HT (27,000 org miles ) from a 71 RV and i would love to put it in my ramcharger..will it fit ? and would I have to change tranny's.
I picked this up for $1200 and got the RV for $400 ..I really Hope This motor will fit..Anybody That Knows if it will Please let me Know..Thanks
I have completely rebuilt the dash with fiberglass and diamond plate..installed a 17" screen connected to a computer mounted in a custom speaker enclosure located in the rear with two 1600 what Jbl 12" subs and the speakerbox slides with remote to see the 2 1400 watt amps capaciter and crossovers located under the rear floor. (thanks to installing a BMW sliding sunroof in the floor) Brand new carpet and 2 bomz Racing seats are going in soon as they get hear (any day now)
POOLinstaller is offline
post #2 of 23 Old 02-12-2008, 04:27 PM
threetwos
AirFuelEddie
Nice RC! Sure it will fit! That chassis had a factory 440 available back in the late 70's so yeah. A big help on this project will be www.bpeusa.com they carry conversion LA/Magnum 318/360 to B/RB, motor mounts, bellhousing, exhaust products ect...The only 'problem' I see is the huge cooling pump casting those engines had but a standard 440 pump could be fit in place of it. Another great source for B/RB parts and info is www.440source.com Good Luck keep us posted,,,.. maybe bouchillion performance is having trouble with their site. Their # is 843-744-6559
threetwos is offline
post #3 of 23 Old 02-15-2008, 09:09 AM Thread Starter
POOLinstaller
cooling pump?
not to sound stupid (although im sure i do) when you say the cooling pump housing ..is this the same as the water pump?
post #4 of 23 Old 02-15-2008, 02:50 PM
threetwos
AirFuelEddie
No stupid questions when it comes to auto tech. On the big block MoPar the water pump resides or fits into the water pump housing, this then bolts onto the front of the engine. Some housings had a discharge on the right side some on the left side. Just make sure the radiator inlet/outlet are compatible with the housing's inlet/outlet, thats all.
post #5 of 23 Old 02-17-2008, 12:56 AM
Brian_RO
Brian_RO's Avatar
as Eddie said there isn't any problem getting the engine in there but with out seeing the 413 engine and trans combo there might be some details that will need to be worked out before just bolting the engine in there.
some of the RV trans had a parking brake drum on the rear of the trans that no other trucks used and would make for some problems of getting the driveshaft to fit and also some of the RV engines used a huge water pump housing that feed water straight into the heads first instead of the block like the stock passenger car engines did.
Brian_RO is offline
post #6 of 23 Old 02-21-2008, 09:07 PM Thread Starter
POOLinstaller
413 water pump
thanks for the info ..here is a few pictures of stuff i have done to my ruck sence the last pictures..i got new rims on sence theses pictures..
post #7 of 23 Old 02-21-2008, 09:37 PM Thread Starter
POOLinstaller
grr here is some pictures
post #8 of 23 Old 02-22-2008, 07:59 AM
threetwos
AirFuelEddie
Very nice. Did you do all that custom interior work? What is the running gear? Dana44F, Auto/ N.P. 231/241? 9.25 rear?
post #9 of 23 Old 02-22-2008, 10:49 PM Thread Starter
POOLinstaller
thanks.. yea i did it all myself out in the yard..Im not sure of the running gear.. it has a 318 engine and auto trans..I I will be posting pictures as I pull the motor out and replace it with a 413 I got from a 1971 executive rv.. i just pulled the grill out of the rv..I'm using the aluminum to build a custom grill for the ramcharger. I been working on this for about a year in my spear time i hope to have the motor balenced and shined up near the end of the summer..Im not sure of any problems i will run into Im hoping the motor will go in with out no trouble with the tranny or transfercase. The inside is almost done im still needing a couple more amps, The two 1400 watt amps iIhave now are bridged 1 amp for each of the 1600 whatt jbl subs located in the rear speaker box that also holds my computer loadede with videos to display on the 17 inch screen in the dash and is equiped with full screen GPS with a locater (very cool) ..advanced video card enables me to have multiple screens(not installed yet but i have them). a slimline flexable keyboard is built into the driverside sunviser (couldnt figure out anywhere else to put it) two 12 inch compition kicker reside on each side of the rear seat (not hooked up yet as i need more amps) four 200 watt tweeters located in the four corners of the truck and four 400 what pyle drivers connected with four three way crossovers located with the amps under the rear speaker box..Which slides back in and out thanks to a power sun roof frame I got from a bmw. and so I can watch movies with out having to get out and place them in the computer there is a dvd player built in the dash above the glove box. all the electronics are controled via voice command (like the new fords) thanks to the computer and a lot of late nights tinkering with different programs. I have to shave the door handles still ..they are not functional i just havent taken them off yet..the doors open with remote thanks to a kit I got off e-bay.The diamond plate stuff is all hand fabricated except the floormats..I saw them and just had to get em..lol I have a few rust spots that need fixing (werent there a year ago) and I am going to airbrush some killer graphics on the truck later as I have Gotten really good by Painting flames and skulls and stuff on all my friends guitars why not do the truck right!..anyhow thanks for the comments and ill be posting pictures as I continue hat seems a never ending project..
post #10 of 23 Old 02-23-2008, 07:07 AM
threetwos
AirFuelEddie
Just make sure you get the tranmission bellhousing from the 413, it should bolt up to the tranny you have in the RC. You will also need the torque convertor.
post #11 of 23 Old 02-23-2008, 09:21 AM Thread Starter
POOLinstaller
bellhousing (don't forget the tourqe converter)
Thanks for the info that would be great if the bell housing fits the tranny in the RC. This is great It's like I have a Whole support Group to help me with this engine swap..Thanks again..
post #12 of 23 Old 02-26-2008, 11:19 AM Thread Starter
POOLinstaller
a-727
just found the tags on the rv they where in a pouch mounted to the frame next to the engine ..it says the tranny is an A-727
post #13 of 23 Old 03-18-2008, 07:29 AM Thread Starter
POOLinstaller
running gear
how do i find out what running gear I have in my truck?
post #14 of 23 Old 03-18-2008, 07:45 AM
threetwos
AirFuelEddie
On the passenger side of the engine block it will tell you the casting numbers and vin# of the vehicle to which it came in starting in 1965 I think,(Fed. Law) on small blocks. On big blocks there will be a 'pad' on the front of the block near the dizzy, it will have some info on that pad such as 440, 413 383 ect.. www.440source.com will give you all the info you need to 'find' out what block and what year you have. B engines are 383,400 or are low deck,(9.998), 413, 426 wedge, 426 Hemi, 440 are raised deck,(10.720) engines. the A-727 is a great small block tranny for Heavy Duty usage. Good swap bait for a B-727 which you will need for your big block. A-727 are becoming harder to find as most small blocks used a 904,(slipoh4)LOL! Very cool project you have poolinstaller!! My Dodge trucks, all Dodge, All manual shifted 4x4 Power! !
post #15 of 23 Old 03-18-2008, 08:08 AM Thread Starter
POOLinstaller
thanks
thanks for the info..and by the way the tranny that is in the rv with the 413 is an A-727 how do i tell if the tranny in my ramcharger is the same..I would like to keep the tranny thats in the truck so i dont have to mess with the transfercase as the ramcharger is is a 4x4? and on the pad on the front of the block is stamped 413 HT any idea what the HT stands for?
post #16 of 23 Old 03-18-2008, 08:19 AM
threetwos
AirFuelEddie
The A-727 is bolted to the 413? It should be a big block tranny not a "a727' for a small block. The bellhousing is different on smallblocks/bigblocks. Sometimes Chrysler made mistakes on the casting numbers. The HT on the engine pad of the 413 should have a HD instaed of the HT, maybe they stamped it HT for Heavy Duty truck Industrial? Check out the 440 source site they have a whole explanation on those casting numbers and Truck/RV blocks as well, pretty cool info on there!
post #17 of 23 Old 03-18-2008, 11:00 AM
fal308
To clarify what Eddie said, the RV tranny should be a B-727 not an A-727.
Your Ramcharger should have an A-727 in it. I don' believe you could get a four wheel drive Dodge with a 904.
Again, as Eddie said, the main difference between an A-727 and a B-727 is the bellhousing bolt pattern.
fal308 is offline
post #18 of 23 Old 03-18-2008, 09:57 PM Thread Starter
POOLinstaller
Equipment identification
Thanks ok here is the information i found on a paper in a plastic pouch mounted under the rv on the inside of the frame near the front driverside tire. It looks like the sticker you see on the inside of a door jam with info on it ..but this one is about6" x 8".
LOOKS LIKE PERHAPS INFO ON THE CHASIS BEFORE THE RV WAS BUILT ON IT.
MODEL----WHEEL BASE----VIN-----------------TON
M400------178-------------M4OCN3J000082---W3474626
CODE NO.....................DESCRIPTION
AG1.............................RR AXLE 10000 # SPICER 70 4.4
DC5.............................14 x 2.5 HYD FRT BRAKE
EE1.............................413-1 EIGHT CYL GAS ENGINE
HC5............................EMISSION REDUCTION SYSTEM
HE4............................60 AMP ALTERNATOR
RE2............................17X6.0 5 STUD DISC WHEELS
SL8.............................REAR SPRING 3800 # AT PAD
ZL2.............................BOXED PARTS
TL2F............................7.50X17 8 SUPER HIMILER GDY
CR1.............................FRONT AXLE 5000 #
DG7............................14.12 X 3 HYD REAR BRAKE
FA3.............................TRANS A-727 AUTOMATIC
HC7............................ELECTRONIC IGNITION SYSTEM
HF4............................90 AMP BATTERY
SC5............................FRONT SPRING 2500 # AT PAD
ZE2............................TEMPORARY SEAT & STRG WHEEL
TL2R...........................7.50X17 8 SUPER HIMILER GDY
ON ANOTHER STICKER
MFD BY CHRYSLER CANADA LTD
DATE OF MFG 8-14-72
This clearly states that the tranny attached to this 413 is code# FA3 AN A-727..? so it must be right? and if being the case,the bell housing must have the pattern to fit in my ramcharger right?..im not trying to be difficult i just want a little heads up before actually doing the swap..and im so glad you all are trying to help..thank you so much.
Well if anything if you ever need to prove that an A-727 did come stock bolted to a 413 ..heres your proof..lol
post #19 of 23 Old 03-19-2008, 07:52 AM
threetwos
AirFuelEddie
Regardless of what the paper or codes state, this tranny is currently attached to that 413 correct? If so, then yes it will fit that engine, and this combo of 413 and that tranny in question is going into the RC correct? If so, just make sure the transmission mounts are compatible with the mount and crossmember of your Ramcharger and that it has the 4x4 transfer case rear housing for your transfer case. I am not an auto tranny expert, but you may have a 'problem' with the transfer case rear of the auto tranny. The auto tranny attaches to the transfer case but I dont know for sure if the RV tranny is compatible with your transfer case you have in the RC. Maybe Barc would chime in and set us straight on that. There is also an option of a 'divorced' transfer case, Ive seen big block dudes use the div setup before.
post #20 of 23 Old 03-19-2008, 08:45 AM Thread Starter
POOLinstaller
transmission issues
Thanks threetwos for your reply
I want to only put the 413 in the ramcharger not the transmission so i dont have to mess with the transfer case. im guessing that the bell housing and torque converter may have to be takin off the tranny in the rv and put in the ramcharger.
i will keep you posted as i begin this process. for farther references i may take photo's.. Ok thanks
    Researching the lean burn igntion system 87Dodgeman 1972-1987 Dodge Ram Trucks (D, W-series) 22 05-17-2007 08:33 AM
    88 360 To 90 318 Swap bpblaes Dodge Ram Truck 1st Gen (88 - 93) Forum 4 02-28-2006 06:57 AM
    Slant Six to 318 swap? Snatcherchief30 Mopar Muscle Talk 7 11-29-2004 11:59 PM
