Malfunction Indicator Light - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 18 Old 02-10-2008, 08:14 PM Thread Starter
jwheeler205
Anyone have any issues with the malfunction indicator light. Mine came on this evening. The engine didn't seem to run any different than the last time I drove it. Could the cold have any affect? It's been in the mid teens and windy all day. I restarted the truck and no changes.
jwheeler205 is offline
post #2 of 18 Old 02-10-2008, 08:31 PM
JeffB2002
Member
JeffB2002's Avatar
What year truck do you have.
You could try the key trick
Off-on off-on off-on and the code should scroll where the mileage is. If you have an 04, go down to Advance Auto and have them read the code for you. They will do it for free for you. Just because you have a CEL on, does not mean that the engine will run different. Once you get the code, post it up here so we can help you.
Jeff
JeffB2002 is offline
post #3 of 18 Old 02-10-2008, 08:58 PM Thread Starter
jwheeler205
Thanks. I took the wifes car to work so i'll do it in the morning when I get home. It's a 2004 1500 Hemi
post #4 of 18 Old 02-10-2008, 09:00 PM
JeffB2002
Member
JeffB2002's Avatar
Well...Unfortunately, I have heard the key trick does not work on the 04's....Although some say it works....I say just take it in and have them read it. They can also reset it for free for you.
Jeff
post #5 of 18 Old 02-10-2008, 09:24 PM
piper18
Great View
piper18's Avatar
It can come on for many reasons and some you can't tell anything is wrong, it could be something that affects the emissions that would only affect mileage, it could just be a loose gas cap.
2008 Dodge Ram 1500 4x4 SLT, 5.7 Hemi MDS, Regular Cab, Long Box, 3.55 LS rear end ,17" cast wheels, Flame Red
Member of the Red Truck Club #231
Switch installed in chime circuit to turn off chime
Installed MDS indicator light on dash ---
Tools Box w/ lights inside tided to cargo light
Custom made deer guard 2" pipe
Sportsmaster Tonneau cover w/top gun fabric
Mopar rear wheel liners
Iron Cross stainless 3" step bars
Tailgate open indicator light
9005 fog light bulbs
piper18 is offline
post #6 of 18 Old 02-10-2008, 10:37 PM
kenihemi
kenihemi's Avatar
Yeah, you need to get the Pxxxx code and post it.
'04 Hemi Ram 1500 QC, 4X4, 4.56 gears, STS turbo = 450+RWHP, SCT Tuner, B&M MegaShifter.
kenihemi is offline
post #7 of 18 Old 02-11-2008, 07:44 AM Thread Starter
jwheeler205
The Off-On trick didn't work. I'll head to Advance Auto later today and post the code(s) this evening. Thanks for the help!
post #8 of 18 Old 02-11-2008, 06:48 PM Thread Starter
jwheeler205
The error code is P0406 "EGR Flow Sensor A Circuit High Input." While driving this evening I noticed the truck surging at low speeds (~20 mph) like it wanted to go but couldn't. The tach would jump from 1000 to 1500 rpm and then fall as low as 200 rpm and then jump back up to normal (600 rpms at idle not moving or normal between 1500-2000 at speed).
post #9 of 18 Old 02-11-2008, 07:05 PM
piper18
Great View
piper18's Avatar
EGR valve is bad or needs cleaning, they can carbon up and stick.
piper18 is offline
post #10 of 18 Old 02-11-2008, 07:26 PM Thread Starter
jwheeler205
pardon my ignorance but what does carbon up and stick mean?
post #11 of 18 Old 02-11-2008, 07:39 PM
piper18
Great View
piper18's Avatar
The EGR valve takes the exhaust gas and ports it to the intake. The EGR valve will build up with carbon and the valve will get sticky or it will not work all together.
piper18 is offline
post #12 of 18 Old 02-11-2008, 08:06 PM Thread Starter
jwheeler205
Is that common with 44,000 miles?
post #13 of 18 Old 02-11-2008, 10:41 PM
07quad
07quad's Avatar
replacing egr's is common on these trucks.
2007 Ram 1500 QC 4X4
Patriot Blue
325/60R20 BFG all terrains on mopar wheels
levelled with Bilsteins
3" PA body lift
Magnaflow exhaust
Hella's behind the grille
Blue Truck Club member #136
1998 ram 1500 4x4
318 auto
hole in lf fender
38's jammed in stock tearing fenders apart as I turn
waiting to be lifted,dovetailed,shortened and beaten
" having an import that can run 11's...is kinda like coming out of the closet....your going to suprise a lot of people....but in the end your still gay"
07quad is offline
post #14 of 18 Old 02-11-2008, 10:48 PM
piper18
Great View
piper18's Avatar
Without hooking up to a computer I'm guessing at the most common fix for that code and that the EGR valve.
piper18 is offline
post #15 of 18 Old 02-12-2008, 02:59 AM Thread Starter
jwheeler205
Thanks for all the help! Is an EGR easy to clean or replace? I work with a bunch of aircraft mechanics i was going to see if one of them may be able to help or is this something that may be covered under warranty? Bought the truck new in Dec. 2004
post #16 of 18 Old 02-12-2008, 10:43 AM
piper18
Great View
piper18's Avatar
I would think the EGR valve is covered under the emissions warranty which is 7year 70000 mile. Look in your warranty book. Any good A&P should have the right size hammer to fix any dodge.
piper18 is offline
post #17 of 18 Old 02-12-2008, 12:32 PM
LPGHemi
LPG Hemi
LPGHemi's Avatar
Quoted: 11 Post(s)
To clean an egr valve, remove it and douse it thorougly in brake cleaner.
Do not scratch any of the surfaces, use just a clean cloth/stiff brush and wipe out any/all chambers to rid it of carbon build up.
Do not get the cleaner into any palstic electrical parts.
Refit and test.
Al.
03 Dodge Ram 1500 Hemi SLT
5.7 ltr QC sb 4x4
Performance Mods
K&N air & oil filters.
NGK Iridiums. Detroit TruTrac. TMR delete.
Procomp ES9000 with torsion bar tweak.
EBC slotted rotors with Yellow stuff pads and Cooper Zeon LTZ275/60/R20.
3" T304 stainless steel custom exhaust with high flow cat side exit near rear tire with DMH Electric cutout and T304 custom muffler.
Prinz LPG VSI sequential gaseous injection system
with 2x70 litre siamesed fuel tanks.
Exterior Mods
Siege Engineering Kong Mk2 Train horns 200 psi Viair 480C compressor & 3 gallon tank.
6000K HID Twiggy hi/lo + fogs.
White front and red rear LED license plate bolt Skulls.
Rear view colour camera with infra red, hooked up to an LCD rear view mirror doubling up as a 7" monitor
Tints 20's & Westins.
Raider Low Rider solid tonneau.
Xenon wheel arches.
Billet Aluminium Rapid hitch.
EZ lift tailgate torsion bar.
Bug deflector.
Dodge valve caps.
Interior Mods
Black coin holder ha ha ha.
DVD head unit.
2xRockford Fosgate Punch 12" subs.
2 Kenwood 6x9's & 2 5.25's.
2x9inch DVD screens built into custom headrests.
Full custom black leather interior with red piping & custom stitched red Ram logo into front seat backs .
Toad Thatcham cat 1 alarm
LPGHemi is offline
post #18 of 18 Old 02-13-2008, 06:14 AM Thread Starter
jwheeler205
Thanks for all the help. I called Dodge and told them that I want them to extended the warranty and fix the EGR since I'm two months out side 3 years. They said a dealer needs to inspect and document and to call them back after the inspection. When I called the dealer they said it would be about $300 without looking at it. However to get it inspected it's going to cost about $100 and maybe Dodge will reimburse. I'm taking it in in about 2 hours. This truck has been a real pain in the a$$ lately. I just put $400 into repairs and two days later this mess started.
