P0725 Cel Code - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 02-06-2008, 10:29 AM Thread Starter
mrp
P0725 Cel Code
Can anyone walk me thru replacing an ENGINE SPEED SENSOR? NAPA doesn't carry them and I'm not finding anything in my Haynes manual. Thanks
mrp is offline
post #2 of 7 Old 02-06-2008, 04:40 PM
2000DurangoTech
Will Work for 3" Lift
2000DurangoTech's Avatar
If I'm not mistaken, it's your crankshaft position sensor that may need replacing. About $25 on rockauto.com. Call your local dodge dealership service department though and they're usually very helpful. Just tell them your code, ask what it could be and if replacing the crankshaft position sensor should fix it.
2000 Dodge Durango SLT
4x4 4.7L V8
K&N Drop-in Filter
Monroe Reflex Shock Absorbers
2" T/S Lift
Xenon headlights
32x11.5 BFG All-Terrain T/S KO x4
Black Leather Interior
Power Everything
Patriot Blue Exterior
2000DurangoTech is offline
post #3 of 7 Old 02-06-2008, 04:56 PM
2000DurangoTech
Just called the dealership for you, the guy said it could be simply that the cam or crankshaft sensor is going bad (depending on how many mileage. I told him 106,000 which is mine, he said that could be it) or something could be knocking around or out of alignment. But more often then not it's the sensor not putting out the right amount of ohms. So there ya go, you can probably take it to Big O Tires and Service Center and get it electrically tested (the whole vehicle) for $45 to see if it's the sensor, or take it to the dealership for a full diagnostic which they usually charge about $100 I believe.
4x4 4.7L V8
K&N Drop-in Filter
2" T/S Lift
Xenon headlights
Power Everything
post #4 of 7 Old 02-06-2008, 08:53 PM Thread Starter
mrp
I appreciate that, now check this out. The scanner code was P0725 ENGINE SPEED SENSOR CIRCUIT MALFUNCTION, but the guy at the parts store said that didn't make sense. He said to pull the IDLE AIR CONTROL VALVE, clean it with throttle body cleaner and reinstall. Did that and it ran perfect and the CEL went off after a little bit of driving. Total cost .50 worth of a can of cleaner and 30 min. max time
mrp is offline
post #5 of 7 Old 02-07-2008, 09:40 AM
2000DurangoTech
Nice, glad it got fixed cheap and quick!
4x4 4.7L V8
K&N Drop-in Filter
2" T/S Lift
Xenon headlights
Power Everything
post #6 of 7 Old 02-08-2008, 12:14 PM Thread Starter
mrp
Cleaning the IDLE AIR CONTROL VALVE worked for a day but now the cel is back on and it's acting up again( not wanting to start and when it doe's it won't idle properly and stall out). I hate to start installing parts blindly. Any thoughts?
mrp is offline
post #7 of 7 Old 02-08-2008, 01:09 PM Thread Starter
mrp
I'm going out to get a crankshaft sensor, I'll reply later as to weather it worked or not, keeping my fingers crossed.
mrp is offline
    Trouble codes for neons 95-99 dodgeneonACR98 Dodge Neon - General Talk 87 02-25-2008 12:15 PM
    cel - trouble code 21 bcflyfisher Dodge Caravan General Talk 3 02-05-2007 07:21 PM
    Trouble Codes for 96-97 Caravans Jmw132001 3rd Gen Caravan Talk (96-00) 0 05-18-2006 09:54 PM
    How to decode the VIN flattop 3G Dodge RAM Diesel Talk 9 03-23-2005 09:25 PM
