2002 4.7 Radiator Fan Relay code (P1491) - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 8 Old 01-08-2008, 11:57 PM Thread Starter
slamnnn
According to my 2002 Service Manual, this code comes up as Radiator Fan Relay Circuit. Under description of DTC, it has an open or shorted condition detected in the radiator fan control relay control circuit. This includes PWM solid state relays. I don't have a code reader. I did the ignition key on/off thing, so I'm not sure where to start. I can't find this relay to check it. Has anyone seen this before or knows where this relay is?
slamnnn is offline
post #2 of 8 Old 01-09-2008, 02:03 AM
bnii
Bill Newell
bnii's Avatar
I have seen it, twice. I just had the same thing this week. Its a 25amp mini fuse in the panel under the hood. second row on the left, first fuse. Pull it and you will see its blown. the fan got wet, and blew a fuse. Here is my story from this weekend.
http://www.dodgetalk.com/forums/showthread.php?t=187900
bnii is offline
post #3 of 8 Old 01-09-2008, 07:19 AM
MikeHTally
Got 2 Hemis
MikeHTally's Avatar
Quoted: 54 Post(s)
So the 4.7s have electric fans? Cool!
MikeHTally is offline
post #4 of 8 Old 01-09-2008, 08:58 AM
JeffB2002
Member
JeffB2002's Avatar
electric fans on the the A/C condensor not the radiator.
Jeff
JeffB2002 is offline
post #5 of 8 Old 01-10-2008, 01:17 AM Thread Starter
slamnnn
That was it. Thanks I replaced the fuse then had to remove the battery cable to get it to reset. It took it a while to idle but the light is now out and all is fine. Thanks again.
slamnnn is offline
post #6 of 8 Old 01-10-2008, 01:28 PM
bnii
Bill Newell
bnii's Avatar
Glad we could help.
bnii is offline
post #7 of 8 Old 01-12-2008, 12:03 AM
MikeHTally
Got 2 Hemis
MikeHTally's Avatar
Quoted: 54 Post(s)
Aha. I even looked at a friend's 4.7 today to find the electric fan. His cooling fan is ye olde conventional. I know the A/C fan is electric.
'03 1500 QCSB Hemi
Vent shades/15% tint
A.R.E. Tonneau/Bed Rug
Nerf step bars
Rear LED light bar/LED frt. turn signals
LED tails & 3d brake light/White Night backup lamps & LED interior lights
Halos/projector headlights KC HiLites Titanium Driving lights
Tailgate Easy Lift & EZ Down
E&G Classics mesh grill
WeatherTech Floor Liners
Overhead console with HomeLink
JVC KD-AR780 Receiver & CH-X1500 Changer
Jensen 6x9 3-way up frt., 5 1/4" 2-way rear
GenTex auto-dimming mirror & Towing mirrors
Fender liners & Ram splash guards
Silver Truck Club Member #140
S.N.A.T.C.H. Club Member 666-666
2 1/2" level kit
Jetstream Scoop/Power Wire
MagnaFlow Stainless Cat-back SI/DO
TrueFlow intake kit
Hellwig 7651 sway bar
Flex-a-lite Black Magic Extr. 180 Elect. Fan
Dick Cepek Chrome DC-1s/Bridgestone Revo2 285/70
post #8 of 8 Old 01-12-2008, 03:04 PM
bnii
Bill Newell
bnii's Avatar
If you guys want to put an electric fan fir the radiator on a 4.7, then look through the threads for viper fan install. I put a Lincoln Mark VIII fan on my 4.7, and it never even needed the high speed fan. I installed a 218 degree thermal fan switch that kicks the low side fan on, and it kicks off after less than a minute. It really is a worth while upgrade. Less drag on the engine, and anything helps when you go with 22's or more. Easy to do, but time consuming if you anal about how clean the install is like I am.
bnii is offline
    01 Durango 4.7 code P0352,P0353,P0354... sanghuutran 1G Dodge Durango Performance Talk 5 08-22-2006 12:16 AM
    Computer Codes 2nd Gen OBDII Afterfx Dodge Neon - General Talk 2 08-14-2005 08:58 PM
    UPDATES... 1996 Dodge Grand Caravan LE AC/Heater Blower, Relay and Resistor Block HeadlessHorsemn Dodge Caravan General Talk 0 01-06-2005 07:04 AM
