Gas Gauge Problems - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 01-08-2008, 12:25 PM Thread Starter
91ShelbyDaytona
Off Roader
91ShelbyDaytona's Avatar
Gas Gauge Problems
I have a problem with my gas gauge. Right after i start up my truck my gas gauge will move all around, like go all the way down to below E and then move around back and forth slowly and will never sit still whether i am driving or sitting in the driveway. I was wondering if the sending unit is bad or maybe something in the wiring, or that is just the way these are. That also makes me wonder about the rest of the gauges. Has anyone else had problems with any of the gauges on these trucks?
I plan on putting a tach on the dash since these never came with one and maybe a trans temp and any other ones i need. I was also wondering if anyone has mounted any gauges in these trucks and if they have, where and any pics.
1992 Dodge W150 5.2 magnum, 4" rough country lift, 33x12.50x15 mtz's, ultra alloys, 4.56 gears, borgeson steering shaft, Hooker headers, high-flow cat, custom cat-back, herculiner bed liner...
91ShelbyDaytona is offline
post #2 of 6 Old 01-10-2008, 10:44 PM
zerko
zerko's Avatar
Kinda sounds like you have a short somewhere. This isn't normal for these trucks.
I would look at the wires under the truck and at the top of the tank, for any rubbing and/or corrosion.
Here's some crappy pics of my gauges. Mechanical oil pressure, volts, and Tach.
The oil and volts go where the Message center was ( red light in between is the check engine light), and the tach is ty-rapped around the steering column. The Sirius sat radio is above the rearview mirror, with the antenna out the interrior and cargo lights.
If you can, use all "electric gauges" instead of the"manual" type.
If I could buy My truck as a Brand New unit today, I definately would!
zerko is offline
post #3 of 6 Old 01-11-2008, 11:17 AM Thread Starter
91ShelbyDaytona
Off Roader
thanks...i will try checking that. i see that auto meter makes a 2 gauge pillar pod for our trucks. I might put one of them in possibly. Does that tach affect your vision of the speedometer?
post #4 of 6 Old 01-11-2008, 12:51 PM
dizzyD
Registered MOPAR User
dizzyD's Avatar
Quoted: 24 Post(s)
If it was like my 93 Dak, I had my fuel pump and sensor changed 3 times. I finally gave up and kept track of miles, plus the low fuel light still worked right, Once it came on I had 30 mile to get gas.
BTW, the sensor should be part of the fuel pump which is located in the tank!
2012 Challenger SXT+ 220ci 5 speed, blackberry pearl, FM xxMM, diablo in-tune I1000, Carbon fiber pedal covers, 11% tint
1999 Durango SLT+ leather, 360ci 4x4, hughes plenum rebuild, superchips 3865, tow pkg, 3.55 LSD, rear tail light guard, K&N CAI, FM 50MM TB, crystal clear headlights, Torsion/shackle lift, Rancho RSX's, Pacesetter headers, dual trans & oil temp a-pillar pod, chrome deep trans pan, drilled & slotted rotors, 10 disc cd changer.
2004 Ram 1500 SLT 2WD QC LB 345ci, FM 84MM TB, slotted brake rotors, step bar, diamond plate pedals, locking gas door, tow package w/ 3.55 lsd, Hellwig LP-15, shell and carpet kit, 18% door window tint, Magnaflow 12641, Slammed1's 3" spindle lift and 2.5 coil spacer, rear lift shackles, Airraid MIT, superchips 3815, 6K front winch & custom Winch Plate, Autometer phantom trans gauge mounted in Mopar SRT A-Pillar single pod, lumber/roof rack, Rancho 9000X shocks, ATS fender flairs, 1" BL, gap guards, black grille, silver painted bezel
2005 Dodge Magnum RT- Midnight Blue -Vroom Lakewood front strut bar, K&N Filter
Gone but not forgotten 93 factory freak CC dakota lifted 4x4 318
dizzyD is offline
post #5 of 6 Old 01-11-2008, 04:00 PM Thread Starter
91ShelbyDaytona
Off Roader
yea i thought that it was in the tank. Does mine have a fuel light?...i have never even looked. That wouldn't be so bad if it did because then i wouldnt have to worry if i am going to run out or not. Or would that light be determined by where the gauge needle is at?
post #6 of 6 Old 01-14-2008, 09:27 PM
zerko
zerko's Avatar
No, you don't have the low fuel light, although, my wiring diagram says the sending unit has a "low fuel switch".
Yes, the tach blocks half of the speedo. But, I never go that fast anyways!
zerko is offline
    Fixing a Gas Gauge doesn’t work RAM MAN Mopar Muscle Talk 3 10-24-2007 09:31 AM
    Gas Gauge? BCM? 96 GC VannaWhite Dodge Caravan General Talk 4 08-19-2007 05:04 PM
    Gas Gauge? w100 360ci 1972-1987 Dodge Ram Trucks (D, W-series) 19 11-20-2006 05:10 PM
    Gas gauge strangeness dervari 3G Dodge RAM - General Talk 5 09-22-2006 11:17 PM
    Caravan Gas Gauge Rockytop Dodge Caravan General Talk 5 09-22-2005 08:43 PM
