Tsb 24-004-03 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 13 Old 01-21-2004, 08:41 AM Thread Starter
quadcab03
Tsb 24-004-03
Hello,
I was wondering if any has had the TSB 24-004-03 performed on their truck. It is for the defrost door being inoperative. The procedure for doing this requires the removal of the dash and just about everything else to remove the heater housing. I guess I'm concerned about the dealer putting it all back together without a bunch of rattles. Plus, the recharging of the A/C and refilling the cooling system.
quadcab03 is offline
post #2 of 13 Old 01-23-2004, 12:27 AM
Racer1_NC
Racer1_NC's Avatar
Yep....been there and done that......4 different times. Just got it back today. That TSB came out 2 weeks after the 3rd time it broke. This time the dealer put in the lower heater box and it works better now than it ever has. No sqeaks or rattles after all this. Will it last? I dang sure hope so....
Bill
Lewisville, NC
Racer1_NC is offline
post #3 of 13 Old 01-23-2004, 01:30 AM
bdcustoms
Are you talking about the recall?
2002 Dodge Ram 1500 Reg Cab
bdcustoms is offline
post #4 of 13 Old 01-23-2004, 05:21 AM
jrboatin
jrboatin's Avatar
when you talk it in, what are you saying to get this tsb done?
I want mine checked, I sometimes have to turn selector knob several times to get
the heat to go where I want. is this is ?
jrboatin is offline
post #5 of 13 Old 01-23-2004, 10:21 AM
Racer1_NC
Racer1_NC's Avatar
The TSB refers to the defroster blend door breaking. The door will break, and you will be unable to get airflow from the floor vents. If yours is having difficulty switching between modes, it will break sooner or later. You can wait until that happens, or start complaining about your problem now....the fix will probably be the same.
Bill
Lewisville, NC
post #6 of 13 Old 01-23-2004, 10:30 AM Thread Starter
quadcab03
Here are the symtoms taken from the TSB. So, if yours is doing this, then you need to print out a copy of the tsb and take it to the dealer.
Also, Racer!_NC, it's nice to hear that yours is working great and that you don't have any rattles. And, were they able to fix it in one day?
Symptom/Condition:
The defrost door may break at the pivot shaft causing inadequate travel. The system may not completely close causing a lack of air discharge out the floor vents and full discharge from the defrost outlet. This may be caused by a broken actuator stop on the heater A/C (HVAC) housing.
03 Graphite Gray 2500 Quadcab SLT, 2WD, CTD SO, 47RE, 373 LSD
Huntsville, Alabama
post #7 of 13 Old 01-23-2004, 10:36 AM
Racer1_NC
Racer1_NC's Avatar
Once they get the parts in, it can be done in a day. The book allows 3.2 hours to do it, they said it took the tech 5 to do mine, but he is a slow and carefull type.....
Bill
Lewisville, NC
post #8 of 13 Old 01-23-2004, 03:54 PM
Pitcru
With this problem, am I to assume that when you set the knob to floor only you get only a portion of the air blowing through and the air comes out the defrost as well?
How much air comes out of the floor vents when it does work correct? My feet have been a little nippy lately.
Thanks
Pitcru
Pitcru is offline
post #9 of 13 Old 01-23-2004, 05:20 PM
Racer1_NC
Racer1_NC's Avatar
Each time it broke on my truck, you could not get any air flow from the floor vents at all. When you selected floor, it would switch to the dash vents. If the blend door breaks, you'll know it.
post #10 of 13 Old 01-17-2005, 03:17 PM
mark s
Has anyone seen this problem with an 03? When I select floor for heat all I get is defrost, no heat to the floor. If I select vent and floor I get heat out of the vent only. With the blower set to high I will get some heat out of the floor vents, but less than 5% of what is comming out of the defrost or dash vents.
7 deg. out this morning and when I got to work my face was 125deg. and my feet 10 deg.
I called my dealer today and the service department ask for my VIN #. after checking they found no TSB's for my truck. They also stated that if they Recalibrated the system that it would fix this problem.
mark s is offline
post #11 of 13 Old 01-17-2005, 03:48 PM
Rah
2005 Power Wagon # 2550
Rah's Avatar
Been through this twice with my 03. Took them 2 days to do it last time, full day the time before. First time (pre TSB) all went smooth, this last time (post TSB) they did more work but it took care of it. It didn't blow warm air for the first 20 minutes and rattled a bit but that all went away.
The problem really sucks, especially in winter. They said no TSBs on my truck either, but they found this one eventually (two trips later) and all is well.
Got rid of her and the truck, which do you think I miss more?
2013 1500 Outdoorsman QC 2005 Power Wagon QC # 2550 (Traded in June 2013) 2003 Ram 2500 HEMI QC 4x4 (Traded for PW Aug 2005) 1994 Ram 1500 4x4 318 (Sold Sep 2004) 1993 Stealth R/T Twin Turbo (Crushed by tree June 2013) 1980 Plymouth TrailDuster 4x4 1999 Durango 4x4 (Sold Oct 2002)
Rah is offline
post #12 of 13 Old 01-18-2005, 07:29 AM
mark s
My dealer is now telling me that this is going to be an out of warranty repair. My truck is a 1 1/2 years old with 52000 miles. They also cannot tell me how much the repair will cost.
Isn’t it funny how the automobile manufactures could have a known 100% failure rate on something and don’t have to do a recall, because it is not related to safety. Not that my problem is a 100% failure, but you would think that the dealer would try to get the manufacture to help cover part of the repair with a known problem like this one.
mark s is offline
post #13 of 13 Old 01-18-2005, 09:29 AM
04 sit'n 24's
Detroit_Muscle
04 sit'n 24's's Avatar
Anybody having these problems with their 04's? Or is this just an '03 thing...i hope!
04 sit'n 24's is offline
