Stuck in park/ Recall? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 01-06-2008, 10:46 AM Thread Starter
griff531
My 2001 Durango R/T with 78k miles is stuck in park. For the past month I have noticed that it took at least two attempts to get in reverse. Tranny seems fine when driving. Parked the car the other day and now I cant get out of park. My mechanic contacted Dodge the other day and found out there was a recent recall on the shift interlock. Dodge has not seen the car yet but they said on the phone this may or may not be the problem. Anybody out there have any idea and is this a recent recall Thanks much
griff531 is offline
post #2 of 9 Old 01-08-2008, 05:12 PM
dodgefan360
Platinum 2K R/T
dodgefan360's Avatar
Quoted: 1 Post(s)
I haven't heard of a recall for this. The cable might just need an adjustment.
2011 RAM Quad Cab 4x4 SXT - Silver
63,000kms
2000 5.9 R/T - Platinum - SOLD - 18 DEC 2014
155,000m (251,000kms)
Amsoil in the diffs, transfer case and engine - Hughes Plenum - Fastman 52mm TB - K&N FIPK - SCT tuner currently set at 87 octane - Magnaflow 15659 exhaust
dodgefan360 is offline
post #3 of 9 Old 01-08-2008, 05:34 PM
dizzyD
Registered MOPAR User
dizzyD's Avatar
Quoted: 24 Post(s)
Do you turn your steering wheel just before you shut the engine off?
Next time try to turn the wheel (oneway will be tight, the other will give just a little) I'm guessing it the steer wheel lock not releasing due to a bind condition.
2012 Challenger SXT+ 220ci 5 speed, blackberry pearl, FM xxMM, diablo in-tune I1000, Carbon fiber pedal covers, 11% tint
1999 Durango SLT+ leather, 360ci 4x4, hughes plenum rebuild, superchips 3865, tow pkg, 3.55 LSD, rear tail light guard, K&N CAI, FM 50MM TB, crystal clear headlights, Torsion/shackle lift, Rancho RSX's, Pacesetter headers, dual trans & oil temp a-pillar pod, chrome deep trans pan, drilled & slotted rotors, 10 disc cd changer.
2004 Ram 1500 SLT 2WD QC LB 345ci, FM 84MM TB, slotted brake rotors, step bar, diamond plate pedals, locking gas door, tow package w/ 3.55 lsd, Hellwig LP-15, shell and carpet kit, 18% door window tint, Magnaflow 12641, Slammed1's 3" spindle lift and 2.5 coil spacer, rear lift shackles, Airraid MIT, superchips 3815, 6K front winch & custom Winch Plate, Autometer phantom trans gauge mounted in Mopar SRT A-Pillar single pod, lumber/roof rack, Rancho 9000X shocks, ATS fender flairs, 1" BL, gap guards, black grille, silver painted bezel
2005 Dodge Magnum RT- Midnight Blue -Vroom Lakewood front strut bar, K&N Filter
Gone but not forgotten 93 factory freak CC dakota lifted 4x4 318
dizzyD is offline
post #4 of 9 Old 01-08-2008, 11:06 PM Thread Starter
griff531
Stuck in park
Picked up my Durango today from Dodge. It was the Gear shift lever blocker. They fixed it for free under the recall. I had never heard of this recall but my nechanic did some research for me and found it . Said it just came out in December 07. Thanks for responding.
griff531 is offline
post #5 of 9 Old 01-11-2008, 01:52 AM
mitch138
haha that happened tp me a few years ago when my d was still under warranty. literally broke the end of the shift knob, dangled by wires there for like 2 days.
mitch138 is offline
post #6 of 9 Old 01-11-2008, 12:24 PM
dizzyD
dizzyD's Avatar
Quoted: 24 Post(s)
Can you dig up the recall # from your receipt?
dizzyD is offline
post #7 of 9 Old 01-11-2008, 07:42 PM Thread Starter
griff531
If Im reading this correct 99recall #g28 Gear Shift lever Bloker
CBXSG280 Hope this helps
griff531 is offline
post #8 of 9 Old 01-15-2008, 12:33 PM
tactransman
Transmission Man!
tactransman's Avatar
Check out the attached PDF file.
Terry aka tactransman
'99 Ram 1500 4X4 5.9 Automatic #110 in the White Truck Club
Aren't you tired of getting your parts for your Super Bee from a kid that thinks a Civic is a "hot rod"!
Mods:
MSD Blaster 3 Coil
Magna Flow Cat and "Y" pipe
46RE Built to the Hilt
Transgo TF OD JR Shift Kit (With Mods)
Billet Cover Converter
Upgraded to five direct clutch drum
Five Overdrive Brake Clutch pack
47RE STEEL front planetary
Sonnax Reverse servo parts
HD Kevlar Lined Rigid Int Band
Deep Pan w/cooling tubes
3.8 ratio Int lever
billet Int servo struts
tactransman is offline
post #9 of 9 Old 01-18-2008, 05:49 PM
01sltgrey
stuck in park
Hello,
I just went through this with my 01. My mechanic told me that the there is a springloaded pin in the column, that locks the column from coming out of park. When he got the cover off, he told me that the assembly was corroded, thus causing the pin to lock up. He cleaned everything and lubricated everything, and its been working great. He charged me 60.00, which I was pleased with. Good luck.
01sltgrey is offline
    Is This a Common Problem? DRANGOLUVR 2G Dodge Durango General Talk 11 11-20-2006 08:57 AM
    Help!! Can't get car out of park!!! (almost) hot4you713 2G Dodge Stratus - Performance Talk 6 12-02-2005 09:51 AM
    recall .. class action ?? rushesh 2G Dodge Intrepid - General Talk 8 12-19-2004 10:56 PM
    Raceway Park in Englishtown New Jersey Needs Our Help!!!! Transamcuda Show and Event Talk 0 11-15-2004 12:47 AM
    Possible recall jakblak 2G Dodge Durango General Talk 19 10-24-2004 11:56 AM
