lightning bolt symbol on dash? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 01-03-2008, 10:53 PM Thread Starter
jasonsdakota
jasonsdakota's Avatar
Quoted: 6 Post(s)
what does the lightning bolt symbol on the dash mean.
i tried to program a bully dog triple dog programmer and the truck now won't start. i can't reprogram it back to stock because it doesn't recognize the key on like it asks me to do. when i do try to start it, the little lightning bolt symbol comes on. is that the security system or something? what does it mean?
2004 slt blue quad cab 2wd hemi
4.10 gears on 17s
magnaflow si/so exhaust
superchips w/custom trans tune
retro solutions 55watt 4300k hids, stock reflectors, BEST MOD YET!!
trifecta tannoe cover covering 500lbs of pdr tools
4 dually spots
retro 5 watt led reverse lights
180 t-stat
coming soon to a transmission near you
edge 2700 stall converter
one ton cooler
dream mods
lt headers
sidewinder
6.4 stroker
sts turbo
jasonsdakota is offline
post #2 of 7 Old 01-03-2008, 11:01 PM
Gopher1320
It has to do with the Electronic Throttle Control. ( as per the owners manual)
12. Electronic Throttle Control (ETC) Light 5.7L
Engines Only
This light informs you of a problem with the
Electronic Throttle Control system. If a problem
is detected the light will come on while the
engine is running. If the light remains lit with
the engine running your vehicle will usually be drivable,
however, see your dealer for service as soon as possible.
If the light is flashing when the engine is running,
immediate service is required and you may experience
reduced performance, an elevated/rough idle or engine
stall and your vehicle may require towing. The light will
come on when the ignition is first turned on and remain
on briefly as a bulb check. If the light does not come on
during starting, have the system checked by an authorized
dealer.
Gopher1320 is offline
post #3 of 7 Old 01-03-2008, 11:26 PM
piper18
Great View
piper18's Avatar
It sounds like the PMC got scrambled, Try resetting the PMC and if that doesn't work, it might have to be replaced.
2008 Dodge Ram 1500 4x4 SLT, 5.7 Hemi MDS, Regular Cab, Long Box, 3.55 LS rear end ,17" cast wheels, Flame Red
Member of the Red Truck Club #231
Switch installed in chime circuit to turn off chime
Installed MDS indicator light on dash ---
Tools Box w/ lights inside tided to cargo light
Custom made deer guard 2" pipe
Sportsmaster Tonneau cover w/top gun fabric
Mopar rear wheel liners
Iron Cross stainless 3" step bars
Tailgate open indicator light
9005 fog light bulbs
piper18 is offline
post #4 of 7 Old 01-04-2008, 12:13 AM
05RamtoughHEMI
2012 Texas Ram Express
05RamtoughHEMI's Avatar
hey there, i used to have the bully dog aswell, had severall issues with it and sold it, but one of them at first, was it not reconizing the key was on, i'd recommend turning on the key on right before that point, and it should work, did for me.
2012 Ram Quad Cab Express
Flame Red
Stock Chrome Clad 20's
Chrome Handle covers
Spray-in Bed Liner
Westin Platinum Oval steps
WeatherTech 1 Piece Digital-Fit Front Floor Liner
05RamtoughHEMI is offline
post #5 of 7 Old 01-04-2008, 12:45 AM
CajunPW
Power Wagon #1605
CajunPW's Avatar
I agree, try turning the key on a little sooner......
2005 White Power Wagon #1605 aka Double Stuff
Current Mods:
CajunPW Locker Bypass Harness// CajunPW Winch Thermal Bypass// Warn 16.5ti Winch// Power Wagon Winch Accessory Kit// Blingy 20's with Interco M-16 Swampers
Coming Soon:
H2 Wheels// 315/70-17 Tires (Not sure which ones
)// Carli Extreme Duty Ball Joints (on order)// Carli Chromoly Control Arms// All Spicer U-Joints// Thuren Trackbar// 08.5+ Steering// Thuren Resi Shocks// Snorkle// DT Profab Steering Brace// Nerfed Rock Rails
and I am sure someone will help me spend more money
Contact me for your very own Power Wagon Locker Bypass and Winch Thermal Bypass
CajunPW is offline
post #6 of 7 Old 01-04-2008, 02:02 PM
kenihemi
kenihemi's Avatar
There are a lot of conditions that will light that light. Not just ETC. And it usually means the truck is in limp mode.
'04 Hemi Ram 1500 QC, 4X4, 4.56 gears, STS turbo = 450+RWHP, SCT Tuner, B&M MegaShifter.
kenihemi is offline
post #7 of 7 Old 01-04-2008, 03:30 PM
05RamtoughHEMI
yeah, one time my ETC and Engine light came on, and my truck wouldnt run good at all and it was hard to start, ended up need the throttle body replaced and the map sensor. all was good after that.
Flame Red
Spray-in Bed Liner
    Head Light Switch - Dash Lights ptannjr 1972-1987 Dodge Ram Trucks (D, W-series) 10 12-11-2007 07:49 AM
    Dash coverings - Aluminum? Stainless? Graphit? Hemi Dog 3G Dodge RAM - Interior/Exterior Talk 6 03-02-2005 05:44 AM
    Installed Brushed Aluminum Dash Kit (pics) BQRam04 3G Dodge RAM - Interior/Exterior Talk 21 02-06-2005 11:00 PM
    Lightning CLONE goes down! Scottcba1 Street and Strip Talk 14 02-04-2004 11:58 PM
    R/T vs. Lightning! Scottcba1 Street and Strip Talk 16 06-04-2003 11:51 PM
