Leaky Freeze Plug...Removing Motor Mount - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 12-28-2007, 06:41 PM Thread Starter
gun5l1ng3r
I am trying to help a friend fix a 2000 Durango SLT (2wd). The freeze plug behind the motor mount on the drivers side is leaking a good amount (about 2 drops per second w/ 18 PSI in the cooling system).
We were able to jack the engine a little bit and remove the long bolt that attachs the motor mount to the suspension, but the motor mount bolts will NOT budge, they almost strip because they are in there so tight.
Any suggestions on how to get the motor mount off of the block so I can replace the freeze plug?
Also, are there any tricks for removing and reinstalling the freeze plugs?
gun5l1ng3r is offline
post #2 of 9 Old 12-28-2007, 08:16 PM
MonsterStyleCom
MonsterStyleCom's Avatar
Spray everything really well with some lube, WD-40 or something, and let it set overnight..
Shawn Hancock
MonsterStyleCom is offline
post #3 of 9 Old 12-29-2007, 03:08 PM Thread Starter
gun5l1ng3r
Would it be worth the hassle to remove the exhaust manifold to get better access to the motor mount bolts?
BTW I forgot to mention that it is a 5.9L...
What about getting the old freeze plugs out?
post #4 of 9 Old 12-29-2007, 11:33 PM
tosterho
Todd O
tosterho's Avatar
Can you use a long chisel and knock the old freeze plug out?
tosterho is offline
post #5 of 9 Old 12-29-2007, 11:36 PM
sherdep
voo doo 1 I am buggin out
sherdep's Avatar
you might be able to get better access by taking the tire off, remove the plastic cover/ splash guard and going through there ....... I know the engine is tight so you may have to remove the maifold if you cant get room to work
04 Dodge Ram 1500 4x4
6" Fabtech Lift
305/70/18 Dick Cepek FC-II Tires on DC-1 Rims
Fram Boost CAI
Hellwig Rear sway Bar
Train Horns with a Viar420C and a 5 Gallon Air Tank
Dynatech Long Tube Headers - Great fit but Dynatech's support is lacking
DynoMax Part # 19413 Single Cat Back Exhaust
If you need to contact me - please send me an email due to not being on here as much as I used to.
Some get it and some will never get it
sherdep is offline
post #6 of 9 Old 12-30-2007, 02:01 PM Thread Starter
gun5l1ng3r
If I try to use a punch and 'twist' the freeze plug by tapping one edge, can the freeze plug fall completely into the motor?
post #7 of 9 Old 12-30-2007, 02:57 PM
sherdep
sherdep's Avatar
it could but go slow and watch it twist ............ if it falls in alls you have to do is get some needle nose plies or a flat head screw driver and pry it back out of the hole
6" Fabtech Lift
Fram Boost CAI
sherdep is offline
post #8 of 9 Old 12-30-2007, 05:16 PM
ying
dont let it go into the engine will be hard to remove. also put the new one in the freezer to shrink it so it will go in easier!!!!! then a little black RTV around the edge will help it stay in!
1968 Dodge Charger R/T
440 auto
2000 Durango 3" lift
33" BFG'S
1993 dodge stealth
3.0 V6
1995 Jeep wrangler
wifes daily driver
ying is offline
post #9 of 9 Old 12-30-2007, 05:48 PM Thread Starter
gun5l1ng3r
Thanks guys for all the pointers!
Hopefully I can get the motor mount bolts out and get the old leaky plug out. Good idea on the Black RTV as well!
    Autolite 3923 Plugs BigJohn82 1G Dodge Durango Performance Talk 13 08-20-2004 10:20 AM
    Anyone have feedback on Bosch +4? huh? 1G Dodge Durango General Talk 19 06-16-2004 01:19 PM
    Spark Plug Time!! Need Help!! LurcH 1G Dodge Durango Performance Talk 15 08-15-2003 09:02 AM
    How About some Q&A Tazz411 3G Dodge RAM - General Talk 7 12-29-2002 07:21 AM
    Freeze Plug Problems? gavilan 1G Dodge Durango General Talk 4 08-30-2002 05:32 AM
