How to set timing on 1987 D100 with 3.7L six? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 12-24-2007, 07:46 PM Thread Starter
dodgebros
My 1987 D100 has a slant six, 1 barrel carb and a computer. How does one set the timing since it is controlled by the computer? I know on some of the newer cars you have to unplug certain connectors, etc. What do I need to do to this one?
Thanks,
TD
dodgebros is offline
post #2 of 7 Old 12-25-2007, 11:20 AM
Speed Dragon
Aka Force Fed Mopar
Speed Dragon's Avatar
Get it warmed up, make sure it's running at normal idle speed, then throw the timing light on it. Adjust as necessary, should be a sticker under the hood saying what to set it at. My 80 says 12*.
Rob M.
'93 D150 RC SWB, 5.2 Magnum, NV4500 5-spd, 9.25" diff
'72 D100 RC LWB, PT project
Speed Dragon is offline
post #3 of 7 Old 12-26-2007, 06:15 PM
madracingalley
Moparisticist
madracingalley's Avatar
i dont beleive you can set the timing its a small uncontrollable computer and my 85 went through a ESC also it wouldnt time worh a s***. if it really out of wack, like very slow response "sputtering+jolting"(mine is a standard and it did that in 3rd and 4) check your vaccum lines one of mine was actually caved in! if that dosn't work advance auto sells them for $100.00
"The Leaning Tower of Power"
1985 Dodge Power Ram W-51
225 Slant-6 4-speed 4X4 Long Box
3/4Ton Dana 44 axle frnt
9.25 Corp. Rear+posi
"The Shame of Life"
1978 Chevrolet Chevette
(yes its brown)
1.6 L SOHC 4-cyl. 3-spd Automatic
Dana 25 Rear axle 3:10 ratio
I Support AMERICA
, I drive AMERICAN CARS
madracingalley is offline
post #4 of 7 Old 12-26-2007, 09:36 PM
76D100
sells vacuum lines for $100?
76D100 is offline
post #5 of 7 Old 12-27-2007, 10:37 AM
Speed Dragon
Aka Force Fed Mopar
Lol better be gold-plated vacuum line I think he meant the computer.
You can set the initial timing by turning the distributor, like most distributored engines.
Rob M.
post #6 of 7 Old 12-27-2007, 10:52 AM
madracingalley
Moparisticist
yeah ...gold-plated .....No even beter solid gold for $1000 . no I ment the computer...sorry
"The Shame of Life"
(yes its brown)
I Support AMERICA
post #7 of 7 Old 12-27-2007, 06:22 PM
bherder
Mopar Madness - Get it...
bherder's Avatar
Speed is correct.....
You can set the INITIAL timing on most anything that still has a distributor...
Even completely computerized/FI engines.... And the initial timing will have an effect, even after the computer takes over.... Mostly with starting/idle....
Of course, if you get the dist really out of wack, even the computer can't make up for it...
"There's been a DODGE in my garage since 1974"
bherder is offline
    What are symptoms of loose timing chain?? 2shus Dodge Ram Truck 1st Gen (88 - 93) Forum 8 03-12-2005 07:33 AM
    Question about using a timing light on a 88 model 2shus Dodge Ram Truck 1st Gen (88 - 93) Forum 5 02-17-2005 06:19 AM
    Erector Set helps design engineer RAM MAN Rumor Mill & Gossip Talk 1 01-05-2004 09:00 AM
