Hemi spark plug change - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 11 Old 12-22-2007, 08:11 AM Thread Starter
quiller303
Hey guys,
I would like to change the plugs in my 2004 Ram w/ Hemi after the dealer quoted me a $250 price. I've change plugs in many other vehicles, but am not sure if there are any access issues or things unique to this engine. I would also appreciate any recommendations on the plugs themselves with an eye towards performance. Thanks.
quiller303 is offline
post #2 of 11 Old 12-22-2007, 08:21 AM
Newbeme
Newbeme's Avatar
Here's a how to article that's on this site. http://www.dodgetalk.com/forums/showthread.php?t=93658
I haven't changed the plugs on my Ram yet, but it doesn't sound too complicated, just time consuming.
Atlantic Blue '03 Ram QC 1500 4x4
*5.7 Hemi & auto trans.
*K&N air filter
*Goodyear Wrangler SilentArmors (275/60R 20)
*Spray-in bed liner
Newbeme is offline
post #3 of 11 Old 12-22-2007, 09:32 AM
dale3fan3
There are a couple plugs tough to get at in the back but take your time and you will be fine. We were able to torque all mine to the proper spec without any issues as well.
dale3fan3 is offline
post #4 of 11 Old 12-22-2007, 09:58 AM
piper18
Great View
piper18's Avatar
if your a small thin person it helps but if you have fat fingers it will be a worse. expect some knuckle rash since gloves get in the way.
2008 Dodge Ram 1500 4x4 SLT, 5.7 Hemi MDS, Regular Cab, Long Box, 3.55 LS rear end ,17" cast wheels, Flame Red
Member of the Red Truck Club #231
Switch installed in chime circuit to turn off chime
Installed MDS indicator light on dash ---
Tools Box w/ lights inside tided to cargo light
Custom made deer guard 2" pipe
Sportsmaster Tonneau cover w/top gun fabric
Mopar rear wheel liners
Iron Cross stainless 3" step bars
Tailgate open indicator light
9005 fog light bulbs
piper18 is offline
post #5 of 11 Old 12-22-2007, 12:05 PM
DELTARAM
DELTARAM
DELTARAM's Avatar
pull fener well
HI
I changed plugs a couple of months ago and read on this forum to:
Jack up the left front of the truck and put a jack stand under for safety.
Remove the left front wheel
Remove the inner fender well = 10 minute job. there are a couple of wires clipped onto it.
After removal fasten wires elseware.
lean in and change the plugs they are now easy to get at and no more broken back problems cuz you are sitting down.
Don't forget that the air cleaner box on the right side lifts out of the way and makes the job on the right side easier.
When putting in the new plugs don't let them fall down as it can close the gap! I use a short length of rubber tubing pushed onto the plug to lower it and start threading.
Good luck and hope this helps.
don't forget the never seize and special grease.
Ron
2004 Dodge Ram 1500 Laramie / Atlantic Blue / Hemi / 4x4 / 20's / True Flow / 4:56 gears / Tailgate Lock / Air Bags /
DELTARAM is offline
post #6 of 11 Old 12-22-2007, 01:35 PM Thread Starter
quiller303
Hemi spark plug wires
Thanks for all the info! My next concern are the plug wires. I've seen some advertised with 0 resistance and claiming a performance boost. As they are pricey, I am a little skeptical. I've got about 33,000 miles on my truck. I am wondering what's out there and what works.
post #7 of 11 Old 12-22-2007, 01:41 PM
Blackbirdrider
Bosch Yttrium +2. They work great, and add a mild bit of performance. Also do not require gapping. Mine idled very smooth with the upgrade. I just changed them. Have fun!
http://www.dodgetalk.com/forums/showthread.php?t=185356
'07 1500 4x4 SLT
Leveling kit
Terra Grapplers
Alpine subs
Blackbirdrider is offline
post #8 of 11 Old 12-22-2007, 05:12 PM
jrsick
I love my MSD plug wires. They are bigger than stock though so they won't fit in the OEM plug wire tracks. I took the track out and organized the wires with cable ties. If you just set the wires on top of the OEM track then you won't be able to get the hemi hat back on. Great wires though, noticeable difference in idle and off the line acceleration. Watch out for the racing wires, they will interfere with your radio reception.
jrsick is offline
post #9 of 11 Old 12-22-2007, 08:43 PM
Hemi2500
I just changed mine today at the 59K mileage mark. It took me about 3 hours to do the job and that included pulling drivers front tire and wheel liner (the best way to get the back 4 plugs). I checked the gap of the NGK plugs I pulled out that I put in at 25K and it was at .055. That's .010 increase in gap. Hoping my gas mileage improves some. I ended up going back to the stock Champion copper plug. From what I've seen and a lot of the comments from others, there is no significant advantage in anything but the stock plug.
I still need to change the plug wires. I'm thinking about getting 8mm Taylor.
2004 Ram 2500 4X4 QC SB 5.7L Hemi Flame Red
Superchips 3815 Flashpaq Tuner
AAM 4.56 Gears TRAC-RITE Anti-spin; MAG-HYTEC Rear Differential Cover
Nitto Terra Grappler AT LT285/70R17
Trueflow CAI; JBA Shorty Headers; Magnaflow #12578 3" In/ 3" Out
Mopar Tonneau Cover & Nurf Bars
2011 Avenger LUX 3.6L Brilliant Black
Red Leather Interior
Hemi2500 is offline
post #10 of 11 Old 12-22-2007, 11:25 PM
Jake1050
Correct me if Im wrong but besides having half as many plugs the 4.7 is much easier isn't it?
07
Electric Blue
SXT
4X4
QC
4.7
Jake1050 is offline
post #11 of 11 Old 12-23-2007, 04:53 AM
dale3fan3
Get shorties and dont look back. the 8.2 mm will be jusyt fine the heavier 10.??? is stiff and guys had them pop off alot. You can order them from henson motorsports from Art and I thin Bob at Moes sells them too.
    1st Hemi Plug change!!! rollingon20s 2G Dodge Durango General Talk 34 07-28-2008 07:08 PM
    Spark plug change info for Derrick EddieHemi 3G Dodge RAM - General Talk 2 04-08-2007 01:55 PM
    About to do a Hemi Plug Change - need advice yeahitsgotahemi 3G Dodge Ram Performance Talk 11 11-30-2006 04:23 PM
    Spark Plug Removal 5.7 Hemi mntinman1 3G Dodge RAM - General Talk 29 01-26-2006 11:51 AM
    Spark Plug Time!! Need Help!! LurcH 1G Dodge Durango Performance Talk 15 08-15-2003 08:02 AM
