emission computer reset sequence - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 5 Old 11-18-2007, 09:29 AM Thread Starter
nursekdb
I just had the oxygen sensor replaced on my 98 caravan and need to pass emissions testing. The guy at the garage said I have to drive it 200 miles to reset the computer. A friend tells me there is an easier way that involves a driving sequence. Is this true? and what is the sequence?
nursekdb is offline
post #2 of 5 Old 11-18-2007, 12:11 PM
XDGT03
I've never heard of a driving sequence to accelerate the computer reading.
XDGT03 is offline
post #3 of 5 Old 11-18-2007, 01:07 PM
RickMN
RickMN's Avatar
You have to complete a "drive cycle" to get all the readiness monitors to "complete."'
Drive in stop and go traffic with at least 4 idle periods of at least 30 seconds each. Then drive on the highway at a constant speed over 40mph but less than 65 mpg for at least 15 mins. Avoid heavy acceleration, sudden deceleration, and wide open throttle.
I'm a retired ASE Master/L-1 Technician. I still keep current with the latest automotive technology. My blog now has over 1000 in-depth repair articles, TSB's, and wiring diagrams:
RickMN is offline
post #4 of 5 Old 11-18-2007, 03:01 PM
donald7150
donald7150's Avatar
just pull the IOD fuse for a few minutes, that should take care of it
2005 Chrysler 300 (DD): 6000K 50W HIDs, Niteshades, LED Interior light Conversion...
'99 Caravan: Work van. 6000K HID headlights and fogs
'92 Chrysler Daytona IROC R/T (2.2L DOHC Turbo-III)
donald7150 is offline
post #5 of 5 Old 11-18-2007, 05:26 PM
Rick99
This will not help. The computer runs a number of emissions tests called "monitors". Each test runs when certain operating criteria are met. For example, the torque converter clutch monitor will run when the transmission temperature is at the right level, the vehicle is traveling over 45 or so and the throttle is less than 10%. The computer will command lock up and then it will see if the difference between transmission engine rpm and transmission input rpm is within "specs" (in the case of the minivan, less than 60rpm difference). If the test shows that the vehicle is in spec, the computer will record that test as a "pass" in its memory. Then when you go for your emissions check, the technician will check all the test results-- they must all be "pass" for the vehicle to pass emissions.
This prevents someone that has a check engine light on from cheating by simply clearing the light before going in for the emissions test.
The trick for you is to allow the conditions for all of the monitors to run so that the car can pass emissions. What RickMN has written should do the trick.
2003 Durango SLT
AWD, 4.7l
Mods: Remote Start
Just got a new set of BFG All-Terrains
Planning retrofit to 4WABS
1999 Durango SLT+
4x4, 5.2l
Mods: B&M Supercooler, Ford OEM Remote Start/Keyless Entry/Alarm, Heated Seats
01 T&C Limited 3.8l
Rick99 is offline
    How long does it take a computer to fully reset it's parameters USMC5593 3G Dodge Ram Performance Talk 20 12-17-2006 04:23 PM
    how do i reset computer OklaHemi 3G Dodge RAM - General Talk 5 12-15-2006 12:20 AM
    Superchips and computer reset question? skaarew 3G Dodge Ram Performance Talk 6 12-31-2005 01:44 PM
    reset computer ozzy60107 Dodge Dakota 1st Gen (87 -96) Forum 2 12-16-2005 10:22 PM
    Any truth to this?? CPU reset question. lucky8926 3G Dodge RAM - General Talk 11 03-16-2005 08:52 PM
