Random Rough Idle - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 13 Old 11-17-2007, 10:05 PM Thread Starter
Laetus_Lupus
Laetus_Lupus's Avatar
Random Rough Idle
2004 ram 3.7 5sp 75k miles
I've read a lot of similar threads but nothing really hit my problem dead on
I've had the truck for about 6 months, about 2 months ago I came to a stop and the engine idle dropped to around 400 and was shaking hard, (normal cold idle is 1000 warm is approx 700) then it cleared up in a few seconds with out me doing anything before taking off, then a few weeks after that it did it again, if I gave it gas it would rev up fine but drop to 400 again with rough idle and then cleared up on takeoff. the last 2 times it did this, again weeks apart, it seemed worse, I thought it might die but never did, as I took off it run rough and barely accel. and the engine light was blinking but as soon as i got over 2500rpm it cleared up and took off like a bat out of hell.
The hesatation reminds me of a 86 ranger i had that got moisture in the fuel a lot but it had problems all the time, not intermittently. I have a short drive to work so it never acts up cold, only after it warms up.
This may not be connected, but when I got the truck, I noticed it started knocking a bit under 2000 rpms with moderate to heavy accel. engine code said misfire cyl 1, so I changed the plugs, probably the first tune up it had,fixed that problem. I'm the second owner, amazing the truck didn't act up until after I bought it.
I wonder why all the problems clear up at high rpms? I would think it would stutter all the way through the rpms if it had a real problem.
The truck has always had a slight rough Idle just enough to let you know its running, most vehicles do, the idle I'm talking about feels like its going to shake itself apart or something. The only thing I could compare it to is that ranger. One cold morning I started it, it didn't want to run, gave it gas to keep running but i swear it felt like it was running on 2 cylenders. or compare the shaking to an earthquake
back to the dodge
just did the key trick, no codes.
What could be causing this problem?
Laetus_Lupus is offline
post #2 of 13 Old 11-25-2007, 02:41 AM Thread Starter
Laetus_Lupus
I may have solved this. I filled up and add two bottles of stp fuel treatment due to the 30+ gallon tank I got. I guess it worked. that stuff cleans injectors, removes moisture etc. well, until next time.
post #3 of 13 Old 12-11-2007, 07:53 PM Thread Starter
Laetus_Lupus
Nope, did it again today, worse as ever. In about a 10 minute time span, I'm driving along and then it starts to bog down and run rough, engine light flashing. when I came to a stoplight it idles real low shaking truck but didn't die. then I take off and it runs real rough and then straightens up a few seconds and starts running rough again. about 2 minutes from my house it straightens up again all the way home it's fine like nothing ever happened. did the key trick, no codes. Confusing as hell. Could it be moisture in the fuel? I'd change the fuel filter if it wasn't in the tank. If I had a bad sensor somewhere wouldn't I get a code? Any one have this problem?
2004 Dodge Ram 1500 Quadcab
3.7L V6 5 speed manual,
2wd, 3.92 gears, 17 in. wheels
post #4 of 13 Old 12-11-2007, 08:01 PM
BlackSmoke1989
The Silver Bullet
BlackSmoke1989's Avatar
go to oriellys and find out what is causing the code to pop up
Member "The Red Truck Club" #245
2012 Dodge Ram 1500 Hemi 4X4
K&N Air Filter.
More mods to come soon!
BlackSmoke1989 is offline
post #5 of 13 Old 12-11-2007, 11:09 PM
piper18
Great View
piper18's Avatar
Sound like the throttle body needs to be cleaned or EGR valve.
2008 Dodge Ram 1500 4x4 SLT, 5.7 Hemi MDS, Regular Cab, Long Box, 3.55 LS rear end ,17" cast wheels, Flame Red
Member of the Red Truck Club #231
Switch installed in chime circuit to turn off chime
Installed MDS indicator light on dash ---
Tools Box w/ lights inside tided to cargo light
Custom made deer guard 2" pipe
Sportsmaster Tonneau cover w/top gun fabric
Mopar rear wheel liners
Iron Cross stainless 3" step bars
Tailgate open indicator light
9005 fog light bulbs
piper18 is offline
post #6 of 13 Old 12-12-2007, 07:07 AM
MikeHTally
Got 2 Hemis
MikeHTally's Avatar
Quoted: 54 Post(s)
TB was my first guess. Maybe it wants plugs? Is the air filter clean?
'03 1500 QCSB Hemi
Vent shades/15% tint
A.R.E. Tonneau/Bed Rug
Nerf step bars
Rear LED light bar/LED frt. turn signals
LED tails & 3d brake light/White Night backup lamps & LED interior lights
Halos/projector headlights KC HiLites Titanium Driving lights
Tailgate Easy Lift & EZ Down
E&G Classics mesh grill
WeatherTech Floor Liners
Overhead console with HomeLink
JVC KD-AR780 Receiver & CH-X1500 Changer
Jensen 6x9 3-way up frt., 5 1/4" 2-way rear
GenTex auto-dimming mirror & Towing mirrors
Fender liners & Ram splash guards
Silver Truck Club Member #140
S.N.A.T.C.H. Club Member 666-666
2 1/2" level kit
Jetstream Scoop/Power Wire
MagnaFlow Stainless Cat-back SI/DO
TrueFlow intake kit
Hellwig 7651 sway bar
Flex-a-lite Black Magic Extr. 180 Elect. Fan
Dick Cepek Chrome DC-1s/Bridgestone Revo2 285/70
MikeHTally is offline
post #7 of 13 Old 12-12-2007, 07:57 PM Thread Starter
Laetus_Lupus
OK, this morning, I started it up and the engine light stayed on. the whole trip to work was pretty good it only had slight hesitation a few times but barely noticable. When I got to work I did the key thing, it said P 0300, I looked up my haynes manual. It said misfire multiple cylinders.I put a bottle of gas line anti-freeze/water remover in to eliminate that variable(I hadn't added any this tank). I drove it a couple miles to get lunch. it seemed fine for the most part, just a little hesitation around 1400 rpm's. I stopped at the store on my way home afterwork. It drove fine except the engine light was on(I'm not extremely concerned because i know why) first and second gear are fine, third at about 1400 rpm's it hesitates and then fine in fourth cruising at 1500. I noticed if I baby it in third it won't hesitate but if I give it about half throttle it does. I wonder why?
I can't believe its the sparkplugs, they only have 2k miles on them. Its cold this time of year so I'm afraid it will have to wait til spring to clean a throttle body or egr valve unless I can do it in 15 minutes. How much would a shop charge?
post #8 of 13 Old 12-12-2007, 11:46 PM
BlackSmoke1989
The Silver Bullet
It's not really hard to clean those things, considering a shop around here charges 50 dollars an hour, i would rather do it myself for 10
K&N Air Filter.
post #9 of 13 Old 12-13-2007, 07:39 PM Thread Starter
Laetus_Lupus
Today I left early this morning. It was dark, rainning and cold. If a vehicle is going to act up, this is usually it. But it didn't. Drove all the way to walmart with the engine light on but it drove perfectly fine. when I left walmart the engine light when off. seem fine now. I guess the ISO-HEAT water remover/antifreeze worked. which leaves the question:
Why do I have moisture in my fuel?
if that is the correct conclusion.
post #10 of 13 Old 12-13-2007, 07:48 PM Thread Starter
Laetus_Lupus
I'm planning on continuing this thread here:
http://www.dodgetalk.com/forums/showthread.php?t=184616
post #11 of 13 Old 12-15-2007, 02:10 AM
siiturbo
So did you say you did a tune-up on it with new spark plugs and everything?
Dodge Ram 1500 QC 4.7L SWB AT
20x10" MB Gunner 5 wheels
305/55-R20 (33.21") Nitto Terra Grappler AT tires
Focal Component Speakers (Front)
Infinity Kappa (Rear)
Rockford Fosgate HX2 10" Sub (FOX Box)
Boss GT1500D Amp
Side-Steps (need modified)
OEM Fog lights
NGK 6987 Sparkplugs
Performance Accessories 3" Body Lift
Flowmaster 50 Series Exhaust 3"in, Dual 2.25"out
20% Tint so you can't see up in my window lol
Motive 4.56gears
Auburn LSD
Superchips
Future aspirations:
Rebuild motor nice and beefy
Add Supercharger or Turbo
siiturbo is offline
post #12 of 13 Old 12-15-2007, 04:49 PM Thread Starter
Laetus_Lupus
I changed the sparkplugs, air filter, and pcv valve. What else is there to a tune up on these modern trucks?
post #13 of 13 Old 12-16-2007, 01:18 AM
piper18
Great View
piper18's Avatar
check oil levels in the rear end and tranny.
piper18 is offline
    Rough Idle Help Please mwcop1 2G Dodge RAM - General Talk 5 04-18-2007 08:32 AM
    '89 Ram Rough Idle Question Ram_Angel Dodge Ram Truck 1st Gen (88 - 93) Forum 4 02-05-2007 09:23 AM
    Help Needed: Durango Hesitation rough idle and loud air sucking sound random spudsdude 1G Dodge Durango General Talk 1 03-23-2006 09:45 PM
    02 rough idle Help obbie02 2G Dodge Dakota General Talk 1 10-06-2005 04:02 PM
    rough idle, random acceleration, stalling majorprofit 1G Dodge Durango General Talk 10 02-20-2005 11:44 PM
