Passenger side front parking light doesn't work - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 8 Old 11-17-2007, 12:45 PM Thread Starter
LoudRam
Redneck Yankee
LoudRam's Avatar
Ok guys here's one for you.
My wife's '01 GC Sport's front parking light doesn't work. There is no power to the light. ALL exterior lights work including brake lights and turn signals (all four). It's just this one parking light. There is no power at the light socket or in the wire going in to the socket. All fuses are good. I know about the left side/right side fuses. They're fine. I switched out the parking light relay with the horn too. I'm going to try to trace out the wires. Does anyone know where that wire starts? Any help would be appreciated. Thanks guys.
-Todd
Desert Storm Vet/ US Navy
'01 Ram 1500 SLT Laramie 4x4 Quad Cab Debadged, 360 cubic inches of pure American muscle.
Performance Mods:Hypertech Power Programmer III, TB: Fins cut, ported and polished Intake: Ported and polished, runners cut down 5/8", 180 T-stat, Edelbrock Pro-Flo 1002, Magnaflow high flow cat and 3"SI/2.5"DO exhaust w/ 3" polished stainless tips, Plenum repaired w/ Hughes kit
Appearance Mods: Eagle wheels 16x8, 33" Toyo Open Country AT's (285/75), Diamond Back headlights w/Silverstar lamps, Aluminum billet grill, Lund moonvisor, Black tube step bars, Bulldog keyless entry, Westin ultimate bull bar w/2 Baja 55w off road lights w/HID lamps
We contribute nothing to our salvation except the sin from which we need to be redeemed. – William Temple (English diplomat & author)
Proud Member of the God Squad 1992
LoudRam is offline
post #2 of 8 Old 11-17-2007, 01:53 PM Thread Starter
LoudRam
Redneck Yankee
LoudRam's Avatar
Quick update....
I have the engine fuse box pulled. There are quite a few plugs going into the fuse box. If someone could tell me which one is for the lights, that would be great. Until then I guess I'll pull every plug and check every wire for continuity. I don't think getting a Haynes or Chiltons will help at this point, this is too in depth for those books. Thanks again guys.
-Todd
LoudRam is offline
post #3 of 8 Old 11-17-2007, 05:37 PM
vipergg
park lamp
For the right side park lamp it looks like it is a wh/or wire that goes the fuse 3 in the IPM or if its the other side it looks like a wt/br wire going into the IPM to fuse #2 . Not sure if this is what you are asking or not .
vipergg is offline
post #4 of 8 Old 11-17-2007, 07:06 PM Thread Starter
LoudRam
Redneck Yankee
LoudRam's Avatar
I found the fuse. And it is a wht/or wire at the light so we're on the right track. On the bottom of the IPM there is a bunch of wire harness connectors. Does your wiring diagram say which connector has that wire in it? Or maybe how many wires are in the connector so I can narrow it down a little? Thank you for your help.
-Todd
LoudRam is offline
post #5 of 8 Old 11-17-2007, 10:41 PM
donald7150
donald7150's Avatar
The white/orange wire is in connector 1 pin 15
connector 1 is a 20 way green connector
the white/brown for the other side should be right next to it in pin 16
use the diagram below
2005 Chrysler 300 (DD): 6000K 50W HIDs, Niteshades, LED Interior light Conversion...
'99 Caravan: Work van. 6000K HID headlights and fogs
'92 Chrysler Daytona IROC R/T (2.2L DOHC Turbo-III)
donald7150 is offline
post #6 of 8 Old 11-18-2007, 07:54 AM
Rick99
Make sure the ground at the light is good too (check for continuity to the body)-- you might not notice that if you just check for 12v between the two wires at the light.
2003 Durango SLT
AWD, 4.7l
Mods: Remote Start
Just got a new set of BFG All-Terrains
Planning retrofit to 4WABS
1999 Durango SLT+
4x4, 5.2l
Mods: B&M Supercooler, Ford OEM Remote Start/Keyless Entry/Alarm, Heated Seats
01 T&C Limited 3.8l
Rick99 is offline
post #7 of 8 Old 11-18-2007, 06:35 PM Thread Starter
LoudRam
Redneck Yankee
LoudRam's Avatar
Thanks Donald. That connector diagram is exactly what I was looking for.
Thanks for the advice Rick. When I checked it I was going to a screw in the frame but I'm going to check continuity with ground as well now.
I'll let you guys know what the problem is when I find out.
-Todd
LoudRam is offline
post #8 of 8 Old 02-03-2008, 04:39 PM Thread Starter
LoudRam
Redneck Yankee
LoudRam's Avatar
It took me a while but I finally got back to this problem. Just fixed it today. It was a break in the wire. I don't know where. I just ran a new piece of wire and tied it in. Everything works. Now on to my next problem in a new thread. I'm beginning not to like this van.
-Todd
LoudRam is offline
    Houston Meet September 29th at 10 am keven West South Central 46 10-01-2007 06:31 PM
    Help leaking coolant from front passenger side intake MissingLink 2G Dodge RAM - General Talk 1 03-26-2007 01:12 AM
    2007 Chrysler Crossfire RAM MAN Rumor Mill & Gossip Talk 0 09-21-2006 09:28 AM
    Read YOUR Fender Tag: RAM MAN Mopar Muscle Talk 3 10-07-2005 11:03 AM
    Chrysler Crossfire Arrives to World Markets RAM MAN Rumor Mill & Gossip Talk 3 07-27-2003 05:49 PM
