1996 Dakota window wind noise - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 11-07-2007, 07:17 PM Thread Starter
havanail
I have a 1996 Dakota club cab. At speeds 60 mph and above and running in winds it develops a high pitched howl at the door windows, also does this when passing or meeting a large truck. When it is making this noise you can feel a very rapid vibration when touching the window. Even lowering the window a little does not stop the noise, the window must be lowered by half to three quarters of an inch or more to stop the noise, and by then you have normal wind noise for an open window. All weather stripping and seals appear intact and in good condition. Thanks for any help.
havanail is offline
post #2 of 7 Old 11-07-2007, 07:43 PM
Autoglass
Autoglass
Autoglass's Avatar
Quoted: 99 Post(s)
Have your doors realigned / adjusted, They are probably out of proper settings. Is the top of the doors able to move accessively? This is a idea from an old friend who ran a bodyshop.
Home Depot And Loving It!!!!
Is Your Veteran Listed?
Autoglass is offline
post #3 of 7 Old 11-09-2007, 02:39 AM
RPMRamFury
Cant see me
RPMRamFury's Avatar
Quoted: 10 Post(s)
All the 1g dakota's I've ridden in have that wind noise from the factory.
2003 Ram 4x4 Sport QC Auto 5.7
1998 Dakota R/T RC Auto 5.9
2000 Wrangler 2.5 5 speed
(All black)
RPMRamFury is offline
post #4 of 7 Old 11-11-2007, 09:43 PM
Dakotah18
Troubleshooter
my '95 and '93 don't have this noise, but my guess would be a bad door seal or misaligned door
To the victims and their families of the shooting at Northern Illinois University, my heart and prayers go out to you. 02-14-08 Will not be forgotten.
'08 Chevy Impala SS 5.3L - 122,000 miles, all factory options, 20% Tint rear and 45% tint front, police horn
'92 Dodge Ramcharger Canyon Sport 4x4 5.2L - 169,000 miles on body, egr and cat delete, rebuilt engine and transmission, windshield visor with marker lights and ram head with lighted eyes----sold
'95 Dakota 4X4 SLT 318 - 245,000 miles, Duals, CAI, 2 Toolboxes, amber lightbar, side mounted lights, 12V outlets in bed, 150W power inverter, fogs and secondary reverse lights, strobes, all factory options, 31" tires, drop-in bedliner, bedlined lower panels, 2nd gen rear bumper, several aftermarket mods. Planning to add more strobes and lights----sold
Dakotah18 is offline
post #5 of 7 Old 11-14-2007, 11:52 PM
Bandit22
well there are no adjusting the doors all hinges welded. I learned this by hitting a deer buyin a door and having a nitemare with getting it to line up and not howl had to crank the top of the door in to adjust it but after we were done all is good. The wind will howl if only a fraction out so crankin the top of the door helps
Bandit22 is offline
post #6 of 7 Old 11-15-2007, 09:26 AM Thread Starter
havanail
Yes, I forgot to mention that I had a body shop look at it and they told me that the hinges were welded from the factory and were not adjustable. They checked the fit of the door seals and the window seals were in good shape and they seemed to be properly adjusted. I have the factory service manual and under wind noises they said to check to see if it had all the plugs in engine compartment and door hinges in place and sealed to keep air from entering the cab as that could cause the noise (the noise is very annoying) but I find no problems that I can see. They caution that adjustments to door and window seals could cause other problems such as premature wear on seals and problems latching the doors. They also said that some window noises can occur when running in high crosswinds, but I have noticed that noise also always occurs at higher speeds even without crosswinds. I love this truck, but I can't stand those noises (happens with both windows.)
havanail is offline
post #7 of 7 Old 11-15-2007, 10:30 AM
dizzyD
Registered MOPAR User
dizzyD's Avatar
Quoted: 24 Post(s)
I had a hinge pin go bad on my old 93 Dak, but b4 it broke, i had a door alignment issue. I never had wind noises b4, also the door side of the striker could be loose not allowing the door to close correctly, This is just input to look at. How does the weather stripping looK?
2012 Challenger SXT+ 220ci 5 speed, blackberry pearl, FM xxMM, diablo in-tune I1000, Carbon fiber pedal covers, 11% tint
1999 Durango SLT+ leather, 360ci 4x4, hughes plenum rebuild, superchips 3865, tow pkg, 3.55 LSD, rear tail light guard, K&N CAI, FM 50MM TB, crystal clear headlights, Torsion/shackle lift, Rancho RSX's, Pacesetter headers, dual trans & oil temp a-pillar pod, chrome deep trans pan, drilled & slotted rotors, 10 disc cd changer.
2004 Ram 1500 SLT 2WD QC LB 345ci, FM 84MM TB, slotted brake rotors, step bar, diamond plate pedals, locking gas door, tow package w/ 3.55 lsd, Hellwig LP-15, shell and carpet kit, 18% door window tint, Magnaflow 12641, Slammed1's 3" spindle lift and 2.5 coil spacer, rear lift shackles, Airraid MIT, superchips 3815, 6K front winch & custom Winch Plate, Autometer phantom trans gauge mounted in Mopar SRT A-Pillar single pod, lumber/roof rack, Rancho 9000X shocks, ATS fender flairs, 1" BL, gap guards, black grille, silver painted bezel
2005 Dodge Magnum RT- Midnight Blue -Vroom Lakewood front strut bar, K&N Filter
Gone but not forgotten 93 factory freak CC dakota lifted 4x4 318
dizzyD is offline
    Factory Stock 1/4 mile and 0-60 times. dodgeneonACR98 Street and Strip Talk 8 05-05-2009 08:53 PM
    Just Bought 04 Chrsyler Town and Country: Noise in Transmission? and Window problems. bankcardrep1 Dodge Caravan General Talk 2 07-18-2006 10:43 PM
    Front passenger door making wind noise Asmodaus 2G Dodge Durango - Interior/Exterior 8 05-30-2005 12:04 PM
    Wind noise mileshuff 2G Dodge Durango General Talk 6 08-16-2004 09:19 AM
    Drive Train noise in 98 dakota Joe Foster 2G Dodge Dakota General Talk 1 12-27-2002 07:25 PM
