1999 5.9 4x4 D Not getting to Operating Temperature? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 10-23-2007, 02:57 PM Thread Starter
chriscorliss
Chris w/1999 5.9L D
Gentlemen,
If you could help me out I would greatly appreciate it. I read all 926 threads and learned a lot, but I am still unable to diagnose why my
1999 4x4 5.9L D of 89,000 miles will not get to operating temperature. It began doing this about 6 months ago, I replaced the thermostat with a 195, and it continues to run cold. IT WILL GET TO OPERATING TEMP with the A/C on, so I know the gauge is good, but the needle barely enters the "white brackets" on the temp gauge with the A/C off. And the engine fan turns freely when I move it. Any ideas?
I have been losing oil and coolant with no puddles on the ground. From this forum I understand I am losing oil because the intank manifold gasket is failing and losing coolant due to evaporation since I live in Arizona and the reservoir is not pressurized. Do you guys concur?
chriscorliss is offline
post #2 of 7 Old 10-23-2007, 03:58 PM
qtipextra
^BIG D^
qtipextra's Avatar
Quoted: 2 Post(s)
is this at idle, or will it barley warm up when you drive it around? Mine seems to take a while to warm up idling, I have to drive a little for it to warm up. But the less heat your engine has, the better. Why worry about it? I could understand it's it's not warming up to the point where it runs smooth, but if it runs smooth, why worry about it?
"Big D" - SOM Feb '10
Black 2003 Dodge Durango Sport 4.7L 4X4 4.56:1 Auburn LSD
Interior: Double DIN Pioneer HU - 141.7 dB Sound System - Dash Mat - Blue L.E.D Interior Lighting - Blue Gauge Backlighting - Audiovox 2-Way Remote Start - 6 Gauge Cluster Swap
Exterior: Black 1 Piece DEPO headlights - 55W DDM 5000K HID 9007 BiXenon - Hella Optilux 2500 Driving lights - 55W DDM 5000K HID H3 - 3rd Brake light decal "BIG D" - Dodge Hitch/Cover - Dodge Logo on Tinted Tails - Stainless Steel Bar Grill Inserts - Gibson 4" Exhaust Tip
Performance: Dynomax Bullet Muffler - Flowmonster High Flow Catalytic Converter - Chrome Intakes CAI - Superchips 3715 at 91 Octane - NGK V-Power Plugs
Tires/Wheels/Lift: 3" PA Body Lift - 2" T/S Lift - 33 X 11.5 X 16 Firestone Destination M/T Tires - MB Gunner 6 Gun metal gray 16X8 rims
Drivetrain: Rebuilt 545RFE Trans with Transgo Shift Kit - 4.56:1 R/P Motive gears - Auburn High Performance LSD
qtipextra is offline
post #3 of 7 Old 10-23-2007, 07:16 PM Thread Starter
chriscorliss
Chris w/1999 5.9L D
Both. It doesn't get to Operating Temp in either Idle or after driving around unless I have the A/C on. I guess the only draw back is that I don't have any heat when I need it--it only comes out luke warm. So you are saying that there are no negative side-effects to having the engine run cold all the time?
post #4 of 7 Old 10-23-2007, 07:29 PM
gramol
for the money put another thermostat in...... test drive with scan tool to verify proper operating temp......190 to 205 ish.
2000 dodge durango,5.9 L,4wd,cold air intake,clear corners,mechanic from canada(spend my days diagnosing and finding broken wires/bad modules),onboard laptop loaded with mitchell, alldata,autoenginuity among others
gramol is offline
post #5 of 7 Old 10-23-2007, 08:36 PM
HemiDak
New name, same taste!
HemiDak's Avatar
Sounds like a stuck thermostat to me as well.
HemiDak is offline
post #6 of 7 Old 10-24-2007, 07:48 PM
bentcrank
Chris, I currently have the same problem with my 99 5.9. surprising since you live in AZ. I live in IL so need to address this problem immediately. I have a few ideas and will let you know what i come up with. keep us posted. thanks
bentcrank is offline
post #7 of 7 Old 10-24-2007, 08:16 PM
bentcrank
Uh OH
Chris, I Meant i have the operating Temp problem, not the others, From what you describe you should see if under the RAD cap you see a milkshake like foam-funk goin on. sure sign of a head - manifold gasket problem. funny thing is your oil level should go up. otherwise it's dumping in a cylinder or two and being burned up. check your plugs for fouling. or get a compression test.
    1999 durango 360 4x4 slt+ So california dizzyD For Sale - Dodge Trucks 1 07-12-2007 10:28 AM
    1999 Dodge Ram 1500 5.9l 4x4 Quad Cab w/ 6" Skyjacker moparrtguy For Sale - Dodge Trucks 0 06-22-2007 02:06 PM
    1996 mopar performance pcm 5.9 4x4 kevo2k6 Wanted - Dodge Truck Parts 1 11-12-2006 11:41 PM
    1999 4x4 ext cab probs. hellion 2G Dodge RAM - General Talk 3 12-31-2005 06:03 PM
    1999 Ram 1500 4x4 brakes at 51,000 BAMARAM 2G Dodge RAM - 4X4 Talk 13 11-01-2004 07:00 PM
