How-To: Relocate Your Grill - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 4 Old 09-08-2007, 02:18 PM Thread Starter
bwdakrt
Smoke 'Em If Ya Got 'Em!!
bwdakrt's Avatar
How To Relocate Your Grill With Pics
I decided I would give you guys your own "How To" instead of having to follow a link to another site on how to make your grill seperate from your hood.
How To Make Your Grill Seperate From Your Hood
Before you remove anything and with the hood closed and latched, use a piece of tape to mark it on the fenders for up and down and side to side location of the grill.
The first thing you do is remove the grill from the grill brace and then remove the brace from the hood. Once the grill is removed, you have to remove the studs that holds the grill to the hood by simply unscrewing them. There are 3 hollow plastic line-up pins that you will have to cut off or simply grab them with pliers and give them a twist.
The grill has to be supported on the bottom. This is the part that took me so long to figure out. I used a small eye-bolt from one end of a 3/16" turn buckle. Drill a 1/4" hole in the inside veritical flat piece of the front bumper brace (the one with the 2 bolts that the bumper fastens to) approximately 1/2" down from the top and 1" from the top back edge of the bumper. It's a little tight so start with a small drill bit for a lead hole and then drill with the 1/4" bit. Use 1/4" x 1" bolt through the eye bolt and sandwich it between two 1/4" flat washers and then a 1/4" nut against the last washer. Stick the bolt in the drilled 1/4" hole on the bumper brace and use a nylon lock nut to fasten it. You will have to do some adjusting on the inside nut so it's not to tight against eye bolt. The eye bolt needs to swivel freely but not wobble side to side. After the eye bolt is fastened to the brace rotate the eye bolt toward the front so the bottom of the grill will rest on the bolt. Center up the grill and mark the center of the eye bolt on the front bottom edge of the grill. Another piece of tape will work good for marking. Transfer your mark to the bottom of the flat surface of the grill and make another mark about 3/4" from the back edge of the grill and drill a hole for the eye bolt. You will need 2 nuts on each eye bolt, 1 for the grill to rest on and the other to secure it to the bottom of the grill. If you need to, you can raise or lower the grill using these nuts.
I used two 5/16" x 2" springs and 2 small cotter keys for the top. On the inside of the fender and above the headlight, you will see a thin flat piece of metal that lays horizonal. Now this is a bitch, but you will need to drill a small hole about 1/2" from the outside edge and just behind the small offset in the flat piece of metal. If you have access to a 90 deg drill it won't be so bad but just a regular hand drill is a REAL BITCH but take your time and it will happen. Drill a small hole in the corner of the top edge of the upper opening of the grill about 1/4" in from the back edge. Attach one end of the spring in this small hole and the other to the eye of the cotter pin. Once the spring is attached to the grill stick the cotter pin through the small hole you drilled in the flat piece of metal and spread it open to lock it in. This should hold the grill back against the rubber on the headlights but still be loose enough tilt the grill out at the top.
Leave the safety latch on the hood. When you want to open the hood, simply unlatch it from inside the cab, put your fingers between the grill and hood and gentley tilt the grill forward. With one hand reach under the front lip of the hood and pick it up a little bit and with the other hand reach in and release the safty latch then open your hood.
When closing the hood, be sure to tilt the grill out before the hood is all the way down. Once it is latched on the safety latch, close it completely. The springs allows you the room to get to the safetly latch and also keeps the grill pulled back against the hood.
Everyone enjoy!!
bwdakrt
bwdakrt is offline
post #2 of 4 Old 10-17-2007, 11:41 PM
KB112
KB112's Avatar
Quoted: 1 Post(s)
Sweet.
KB
2004 5.7L Quad Cab
1/8: 9.113@70.814 --- 1/4: 14.365@95.470
Exterior: Blacked Out 06-20"s, 295/50-20 Falkens, 2/4 Drop - Hotchkis coils/DJM Flip, Sport Conversion, Mopar Air Dam, Good Hood, ARE Cover, Rollpan, Mopar fuel door, LED 3rd Brakelight, Black Headlights, HID Fogs, Powdercoated Black SS Grille, Homebrew Powdercoated bumper grill with smoked turn signals
Interior: Infinity pkg, Slammed1 Bezel, BedRug, SRT Pillar
Performance: Hotchkis F/R SwayBars, Bilsteins, MIT tube, AEM Wideband, Comp 260, 6.1L Pushrods, 6.1L Exhaust Springs, QTP Cutout, Super Chips, NGK 4306s, Taylor Wires, TransGo Shift Kit, AT3030, CalTracs.
Awaiting Install:Thorley Mid's
KB112 is offline
post #3 of 4 Old 10-18-2007, 06:46 AM
BRUISER QUAD
MUDDY AFFAIR
BRUISER QUAD's Avatar
Originally Posted by KB112
Sweet.
KB
UH OHHH! KB saw this... I deffinitally see this as a great mod for anyone who shows thier trucks... who wants to look at a radiator, tranny cooler, and oil cooler?
bwdakrt- just a thought.. what about a small strip of some kind of weatherstripping or such on either the grille or front edge on hood to cut out any vibrating or paint to paint rubbing?
2004 Dakota Quad- 4.7L 4x4
9.25" 3.55 posi rear, open front
Blue Truck Club #87 287 Enthusiast Club #666 NEKID Truck Club #666
Yellow/ Amber Foglight Club #666 Don't Fear the Drone #666
20% tint, vent shades, Blacked out between front and rear windows
de-badged, Mopar Billet Fuel Door/ body color matched!
NiteShaded rear brake lights w/ led bulbs
Yellow headlights, Yellow foglights
HELLA 500 driving lights on bumper
w/ 100w hella bulbs & custom Hella Grilles
clear turn signals w/ silverstar ambers
Xtang Saber tonneau, Line-X under the rail
POWER WIRE
FastMan 68.5 Throttle Body w/ K&N FIPK
Clutch fan removed, 180* T-stat
Bosch Platinum+4 plugs
Flowmaster Super44 Dumped
Clarion head, polk components
Torsion bars cranked, 2" blocks
285/75/16 Nitto Terra Grapplers on BLACK Cragar's
MAG-LIGHT- Magcharger hardwired
R/T- Heated, Power Leather Seats w/ full console
Blacked out interior top to bottom
BRUISER QUAD is offline
post #4 of 4 Old 10-18-2007, 07:00 AM Thread Starter
bwdakrt
bwdakrt's Avatar
It's already there. There is a thin stripe of weatherstripping on the grill shell that the factory puts there to elimate the rubbing between the hood and grill. No need to add anymore.
bwdakrt
bwdakrt is offline
    Street Scene Speed Grill pics..chrome, satin or black chrome adamsredlines 3G Dodge RAM - General Talk 7 05-06-2007 02:10 PM
    02-05 BLACK SPORT BUMPERS, CHROME GRILL SHELL, BILLET LOOK GRILL INSERTS in PA drtrox For Sale - Truck Parts 17 12-12-2006 07:23 PM
    Allright guys... pics of my grill are up. Harms Way 3G Dodge RAM - General Talk 44 02-24-2006 03:06 AM
    Pics of SRT-10 Hood with chrome grill? 57HEMIhoney 3G Dodge RAM - General Talk 10 11-26-2005 03:38 PM
    finished sniper hood grill bumper pics DROPT_98_DAKOTA 2G Dodge Dakota General Talk 1 03-21-2003 02:00 PM
    You may not post new threads
    You may not post replies
    HTML code is On
