Park lights won't shut off until fuse pulled. - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 10-15-2007, 10:25 AM Thread Starter
budman-mo
budman-mo's Avatar
This is my first Dodge so unsure if this is a "typical - easy fix" or a real pain.
It's a 95 2500.
First day I own it, on the way home it gets dark and I turn on the headlights and I have no dash lights. I am smart enough to go check the tail lights, sure enough no tail or park lights, head lights on ok.
I stop at my brothers and start looking, I find a fuse (under the hood) that is pulled out and laying in the fuse box. Sure enough I put it in and the lights work. I then joke to my brother that when I wake up tomorrow and see the lights on or find the battery dead I will know someone pulled it out.
So now the lights work, I turn the lights off and they are still on?
I pull the fuse and they go out.
Does this sound familiar to anyone?
Please let me know if you have any good suggestions before I start digging.
budman-mo is offline
post #2 of 9 Old 10-18-2007, 11:21 PM Thread Starter
budman-mo
budman-mo's Avatar
Surely someone has a suggestion...
I am thinking a screwy headlight switch?
post #3 of 9 Old 10-19-2007, 06:32 AM
Dave3825
Dave3825's Avatar
If you pull the fuse and the lights go of then the fuse is good..lol
Seriously it sounds like the headlight switch is fried or if there is a relay in the headlight circuit,it is stuck in the energized position (on) .
Usually the relay carries the heavy amperage load to the headlights and the switch just triggers the relay...
Hopefully someone with a 95 can advise if there is a relay and where its located.
2001 Dodge Ram 1500 5.9 8 ' bed
34000 Front u joint blows apart $20.00
38000 Lights blow out on radio Got Kenwood
39000 Tailgate cable snaps $8.00
40000 Ignition wire in column breaks $2.00
42000 Auto window rolldown stops working not fixed
51000 Power steering pump blows $35.00
52000 Multifunction switch blows $87.00
54000 Overdrive in tranny blows $1200.00
60000 Gas steady @ 3.13 a gallon
60106 Plenum repair
61380 Master cyclinder 140.00 (dealer)
61398 Gas down to 2.99
80000 steering box fails
100232 2nd trans dies
100102 ac clutch bearing failed
123256 Fuel pump fails
124562 2nd steering box failed
Dave3825 is offline
post #4 of 9 Old 10-19-2007, 07:23 AM
Shortyg
First thing that I would check is the headlight switch. If it is turned off and the lights stay on, it may be bad. Just unplug it. If the lights go off, you know that the switch is bad. If the lights stay on, it must be further down the line. I would try the parking light relay next.
Shortyg is offline
post #5 of 9 Old 10-19-2007, 07:34 AM
KTS
BoJivin'
KTS's Avatar
Heck I think it may be easier to switch the relay with the headlight realy instead of trying to get to the switch, should be the same realy, just pull the parking lights ne, and the headlights one, and then put the headlight one in the parking lights, shouldn't need to mess witht he parking lights one after you pull it since when you put the headlight one in the parking light spot if the lights stay off, you know it's the relay.
It might also be a wire problem somewhere if somebody wired the extra lights or something.
If Darth Vader drove a truck, he would be driving mine.
Modded in the memory of my Uncle, Mike "Bubba" Shortt.
Black Truck Club Member # 88
Black '04 2500 HEMI QC SWB SLT 4x4
Mods:
3'x5' U.S. Flag flying proud.
3'x5' MIA/POW Flag flying to never forget.
Black Gizzly Double-Single Rollbar
Black 3-5"x9" eagle eye off-road lights
2 KC HLites 130watt each
Black
Deluxe front replacement
Black Superlift 6" Lift
Superlift Dual Steering Stabalizer w/ Black boots
Black lettered 37x13.50x17 Toyo Open Country Mud Terrains
Black 17x9 AWI Daytona's w/ 5" BS
Black Deezee tube steps
Black Coin holder
Black AVS Headlight covers
K&N drop in air filter
Future Mods:
Stats:
1/4 Time: 17.351 seconds @ 78.78 mph
216Hp @ 4500 rpm & 266.3 Tq @ 3800 rpm
COIN HOLDER ASSOCIATION MEMBER #4 S.N.A.T.C.H. SpecOps -- Major Killer Turtle
KTS is offline
post #6 of 9 Old 10-25-2007, 10:54 PM Thread Starter
budman-mo
budman-mo's Avatar
Update.
I found the headlight switch and plug melted.
I replaced both, still have the problem.
I don't see any park / headlight relays?
They aren't in the box under the hood, where else?
The fuse I am pulling to turn them off is the trailer lights fuse.
I am thinking bad trailer plug wiring but if there are relays I will try that first.
Give me your thoughts.
post #7 of 9 Old 10-28-2007, 10:42 PM Thread Starter
budman-mo
budman-mo's Avatar
I finally got the time to figure this mess out.
It was a combination of problems.
First the headlight switch pigtail was melted, and the switch was cooked too.
I replaced both.
The second problem was (for reasons that I can only guess) someone had installed trailer adapter plugs /tee's into the stop/tail plugs behind the lights.
These were not hooked to any trailer plug but one tail wire was ran down to the factory trailer wiring into the tail light circuit. This created the "loop" that when energized would keep the lights on.
After finding this and removing it I had no tail lights at all.
Found the fuse (in the inside fuse box) was blown.
I had checked it with a test light and thought it was good but now realize it was showing good because of the loop effect.
Now it all works ok.
I also removed a bunch of old crappy wiring for fog lights and other impossible to understand wires while I was poking around.
Some people shouldn't be allowed to wire on anything
post #8 of 9 Old 10-28-2007, 10:58 PM
Shortyg
Great...a little patience and some common sense can get you far! Thanks for the update. It's hard to help very much without seeing what's going on.
Shortyg is offline
post #9 of 9 Old 10-29-2007, 12:55 AM
Ateup2damax
ppl, really need to start checking fuses first, instead of some po'dunk redneck engineering to fix electrical problems
'01 1500 QC 318 Blue Stock but not for long
Ateup2damax is offline
    98 Ram Trailer Brake Box, Now parking lights won't turn off? shuzmon 2G Dodge RAM - General Talk 10 08-27-2007 11:50 PM
    fog and park lights keep coming on highteckmohawk 3G Dodge RAM - General Talk 1 08-20-2007 08:56 PM
    1994 Caravan Dash lights fuse blows after radio installed. GEDaley Dodge Caravan General Talk 1 05-06-2004 05:42 PM
    Lights shut off on their own. Josh Brown 3G Dodge RAM - General Talk 1 03-22-2004 11:43 AM
