Brake Lights won't turn off - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 09-20-2007, 06:04 PM Thread Starter
TampaLinc
2005 Dodge 3500 SLT Cummins 6-sp
I am still beating my head against a wall trying to figure out why the brake lights won't turn off.
Replaced the brake switch (on the pedal).
Replaced the fuse box and the front control module.
Disconnected the trailer wiring.
Does anyone have any idea what else might be causing the rear brake lights to stay on?
TampaLinc is offline
post #2 of 7 Old 09-20-2007, 06:09 PM
siiturbo
The standards have a switch on the clutch and a switch on the brake pedal. I hear they look very similar and its easy to get them confused. I'm guessing you replaced the right switch, but just wanted to make sure. You might have a short somewhere in the wiring. Do you also have a trailer brake controller? I read that you disconnected the trailer wiring but wasn't too sure on what you meant by this.
ok to test to see if its a clearance issue with the switch or not, locate the switch on your brake pedal and get someone or something to either depress the brake light switch or sandwhich something inbetween the brake light switch and the actually brake pedal. Then check to see if they have turned off. You might need a brake light switch stopper. Your brake light switch might not be getting depressed far enough to turn off the brake lights for some reason. I'm still putting money on your problem being the switch. You might have bought a lemon switch even, its possible.
Dodge Ram 1500 QC 4.7L SWB AT
20x10" MB Gunner 5 wheels
305/55-R20 (33.21") Nitto Terra Grappler AT tires
Focal Component Speakers (Front)
Infinity Kappa (Rear)
Rockford Fosgate HX2 10" Sub (FOX Box)
Boss GT1500D Amp
Side-Steps (need modified)
OEM Fog lights
NGK 6987 Sparkplugs
Performance Accessories 3" Body Lift
Flowmaster 50 Series Exhaust 3"in, Dual 2.25"out
20% Tint so you can't see up in my window lol
Motive 4.56gears
Auburn LSD
Superchips
Future aspirations:
Rebuild motor nice and beefy
Add Supercharger or Turbo
siiturbo is offline
post #3 of 7 Old 09-20-2007, 07:04 PM
duso02
duso02's Avatar
Quoted: 14 Post(s)
True that, I've seen switchs replaced but not adjusted properly.
LOU
2011 Blue Ram Sport QC HEMI 4x4
Military Truck Club Member #16
"The Marines I have seen around the world have the cleanest bodies,
the filthiest minds, the highest morale, and the lowest morals of any
group of animals I have ever seen. Thank God for the United States
Marine Corps!"-- Eleanor Roosevelt
duso02 is offline
post #4 of 7 Old 09-20-2007, 07:23 PM
williboone
(_)& (_)& (_)&
williboone's Avatar
mines not a diesil but about once every other month mine stay on. i jiggle the pedal and it goes away. its so rare that i dont bother with it, but consider me subscribed to find out
2004 RC/SB 2WD HEMI 1500
BUILT @ HOME IN ST. LOUIS
EBAY CAI (WORTH EVERY PENNY)
HOMEBREW IAT VARIABLE RESISTOR
JET STREAM SCOOP BY AIRRAM
SUPERCHIPS
FLOWMASTER 40 DUMPED
PIONEER DECK
2 SONY XPLODE 1200W AMPS
2 SONY 6X9's
2 ALPINE 6X9's
2 SONY XPLODE 12's
(SO LOUD IT'LL MELT YOUR FACE
williboone is offline
post #5 of 7 Old 09-20-2007, 07:36 PM
duso02
duso02's Avatar
Quoted: 14 Post(s)
Actually, I don't think our switches are adjustable. Willibone--with you moving the pedal causing it them to go out, I'd start right there. Maybe the plunger is sticking or the connector is loose?
LOU
duso02 is offline
post #6 of 7 Old 09-20-2007, 08:05 PM
williboone
(_)& (_)& (_)&
williboone's Avatar
yeah with temp fix that easy i cant belive i havent done it yet. guess i dont really think of it till it happens, and so rare it does.
also maybe the peddal just a bit to heavy....just a thought
SUPERCHIPS
PIONEER DECK
2 SONY 6X9's
2 ALPINE 6X9's
2 SONY XPLODE 12's
post #7 of 7 Old 09-21-2007, 01:45 AM
siiturbo
no the switches arent adjustable
Boss GT1500D Amp
OEM Fog lights
NGK 6987 Sparkplugs
Motive 4.56gears
Auburn LSD
Superchips
Future aspirations:
siiturbo is offline
    98 Ram Trailer Brake Box, Now parking lights won't turn off? shuzmon 2G Dodge RAM - General Talk 10 08-28-2007 12:50 AM
    No brake lights or turn signals joshso Dodge Dakota 1st Gen (87 -96) Forum 3 07-14-2007 04:39 PM
    ABS and Brake lights are on in my Dash!!! Bocc68 2G Dodge RAM - General Talk 17 12-31-2005 12:03 PM
    Brake Lights Don't Work 98DodgeGuy 2G Dodge RAM - General Talk 1 08-30-2005 09:27 AM
