Front drive shaft removal - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 3 Old 09-15-2007, 11:08 PM Thread Starter
rgwetz
How do you remove the front drive shaft? I removed the 4 bolts on the front U-Joint and the 6 bolts on the rear bracket but the shaft did not come out. I didn't want to pound on anything until I asked the question. I've read other people post about 3 u-joint on the front drive shaft. Mine only has the one on the front and has a round bracket with 6 bolts at the tranfer case end.
rgwetz is offline
post #2 of 3 Old 09-16-2007, 09:29 AM
HemiDak
New name, same taste!
HemiDak's Avatar
Compress it and wiggle it around.
HemiDak is offline
post #3 of 3 Old 09-17-2007, 03:46 PM
Ryan Griffin
You should be able to grab it at the front Diff and push it back toward the trans case. It should compress......dont be afraid to wack it with a hammer handle or something to break it loose. The flanges could be rusted together and will need a little encouragement to separate.
Ryan Griffin is offline
    New TSB for Seat Trim Breaking Big3 2G Dodge Durango - Interior/Exterior 26 02-05-2008 09:47 PM
    2007 Dodge Ram 1500 RAM MAN Rumor Mill & Gossip Talk 1 11-29-2007 09:54 AM
    2007 Chrysler Pacifica RAM MAN Rumor Mill & Gossip Talk 2 01-04-2007 09:25 PM
    Front diff leaking...from axle shaft hole MqtMatt 2G Dodge RAM - Drivetrain Talk 2 08-30-2005 04:47 PM
    2005 Dodge Magnum Engineering Press Releases RAM MAN Rumor Mill & Gossip Talk 0 03-03-2004 09:55 AM
