Rear door hinge pin - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 38 Old 09-07-2007, 08:31 PM Thread Starter
landyacht318
Off the Grid
landyacht318's Avatar
Rear door hinge pin
The hinge pin on my 89 b250 rear door on the bottom is broken. I know the best thing to do would be to visit a J/Y and replace the whole hinge. Knowing I could be opening a can of worms with this, I decided to try to loosen the bolts on the body and door side. The Pb blasted bolts didn't care to budge and I was not in the mood to force / strip and bend the door/ body pillar.
I want to just somehow manage to extract the old hingepin and replace it with a stainless clevis pin or similar.
From what I can see the bottom of the current broken pin is tapered. Is it also threaded or have any other method of keeping it in place other than years of corrosion?
Anybody have experience with these hinges/hingepins and some advice? The way murphy's law has been treating me lately I can just imagine the possibility of another embarassing severe temper tantrum that has the neighbors calling the cops.
landyacht318 is offline
post #2 of 38 Old 09-07-2007, 08:40 PM
alloro
Elder User
Quoted: 17 Post(s)
It will take a good punch and a heavy hammer to drive that pin out. A press is out of the question since you can't get the hinge assembly off. One mis-swing and you're going to smash your hand or the body of the van, then of course the cops will show up.
Know anyone with air tools or a breaker bar that you can use on those bolts? If you chose to disclose your approximate location, maybe someone on this board with the tools can help out.
alloro is offline
post #3 of 38 Old 09-07-2007, 09:23 PM Thread Starter
landyacht318
Off the Grid
I have not really tried to hard yet to get the bolts off. I put about 3/4 of my body weight (220#) on the rachet and said the heck with it. I got a so many other things on my list. I knew 2 years ago this pin was busted, and just tied the hinge together with some rope and hammered a wooden wedge in between the rope and hinge, and it worked pretty well.
Part of the reason I'm looking to just replace the hinge pin is that I have not found any junk yards within 50 miles. (Sarasota, Florida) and I got a quote from some used auto parts place for 65+ dollars + 15 dollars shipping. I can get a nice 304 stainless clevis pin for 7 $ at the local ACE hware.
I was thinking I could grind off the top rounded part of the pin and Either hammer out the broken pieces from the top, or use a gear puller to push the pin out. If the pin has to come out from the bottom then It complicates things, and I'll just look for another piece of rope and an oak wedge
and call it macaroni.
post #4 of 38 Old 09-07-2007, 10:30 PM
alloro
Elder User
Quoted: 17 Post(s)
I don't believe it's a tapered pin, if it was there would be no need to have a head on it. If you were to grind the head off, you could probably hammer it downward.
alloro is offline
post #5 of 38 Old 09-07-2007, 10:56 PM
van-nut
'98 B2500 Ram Cargo Van
van-nut's Avatar
Quoted: 6 Post(s)
I've never messed with one, but I believe the pins are just a press fit into the hinges. How much of a press I'm not sure. I believe that somewhere once I saw a tool made specifically for door hinge pins. Maybe if you have a large enough "C" clamp you might be able to rig up a make shift press. A hammer and punch might work, but don't go too crazy with the hammer.
Pete
Experience is something you don't get until just after you need it - Steven Wright
van-nut is online now
post #6 of 38 Old 09-07-2007, 11:19 PM Thread Starter
landyacht318
Off the Grid
Thanks for the replies.
I'm gonna grind the head off and take a whack at it, or a gear puller/ c clamp type of pusher, or a cobalt drill bit. Failing that, another rope with an oak wedge.
post #7 of 38 Old 09-08-2007, 12:10 PM
stev
Seating for 12
stev's Avatar
Quoted: 3 Post(s)
Do you know what is WORSE than getting those door hinge pins out?
Well ...
Having to remove any of the tail lamp lenses and the head to the screw breaks off! Talk about it being a real pain! Even more so since the bulb needs to be changed to pass vehicle inspection!
So, I do feel for you changing out that pin.
I'm surprised that Nate and the other guys havn't chimmed in yet. They have removed doors and a few put in gull-wing side doors on too. They have to know the tricks to get that pin out without damaging anything.
71 Duster 340, 74 T&C 440-Interceptor, 74 Duster /6 225, 76 Aspen /6 225, 79 Volare S/6 225, 81 Pacer I6 258, 88 Colt I4, 85 Caravan 2.6L, 94 Caravan 3.0L, 96 Caravan 3.3L, 00 Ram Van B1500 3.9L, 01 Ram Van B2500 5.2L, 05 Caravan SXT 3.8L, 03 Ram 2500 5.7L HEMI
stev is offline
post #8 of 38 Old 09-09-2007, 01:09 AM Thread Starter
landyacht318
Off the Grid
I managed to find a photo of some 70-77 plymouth cargo door hinge pins. I would like to know if anyone knows if the hinges are the same up through the '89 model year.
Here's the link:
http://cgi.ebay.com/ebaymotors/70-77...QQcmdZViewItem
post #9 of 38 Old 09-09-2007, 03:37 AM Thread Starter
landyacht318
Off the Grid
Found the answer to my own question.
Chrysler 2-3/4" x 17/64"(.266") x 9/16" (.56")
- Dodge, Plymouth Vans
- 1970-up Cargo doors, side or rear
The above photo makes it look like the head of the broken pin would rather be pushed up from the bottom. I also noted that my 3rd and most used door has fallen badly out of alignment over the last few months and could probably use new pins and bushings.
I'm gonna make my own removal tool with a large c clamp, a large enough socket and a # 12 or 1/4 inch machine bolt. Bet I still turn the neighborhood black with curses.
post #10 of 38 Old 09-09-2007, 12:10 PM
van-nut
van-nut's Avatar
Quoted: 6 Post(s)
It looks like if you can push the pin upwards enough to get the splined section out you'll be home free at that point.
Pete
post #11 of 38 Old 09-09-2007, 01:28 PM
Dodgevanman
Do It In A Van
Dodgevanman's Avatar
If you could only get the old hinge off, it would save a lot of headaches. Those pins get so rusted in that you'll never get them out. My father-in-laws 85 Dodge has both pins broken on one of the rear doors. I went to my local pick-n-pull and got both hinges for 10 bucks. It tooks us a total of 15 minutes to change both hinges. Of course we already had the interior panel removed so we could get to the bolt heads.
Nate Breece
5.2L Magnum
2008 Grand Caravan SXT
3.8L
Member of:
Dodgevanman is offline
post #12 of 38 Old 09-09-2007, 06:44 PM Thread Starter
landyacht318
Off the Grid
Nate,
I'm sure your right about the difficulty in removing the hinge pins, but I can't find any junkyards within 50 miles, and those that I've called that are farther away have quoted $20+ per hinge, and that was for a chevy van. They were trying to tell me they were identical.
I put some torque on all my hinges today and found significant slop in all but one. Suprisingly, I can find very little rust around any of them (at least on the exterior. I'm going with the replacement hinge pins, and I'm gonna soak em all in pb blaster every day for a week, and make the proper tool.
post #13 of 38 Old 09-09-2007, 10:17 PM
stev
Seating for 12
stev's Avatar
Quoted: 3 Post(s)
As for the door being badly out of alignment, I've used a floor jack and a few 2x4's to gently and slowly push them up until the doors sprung bad into the proper alignment. Most of the time you'll need to overtravel the jack so as the door will spring into alignment. Doing it in increments works the best.
stev is offline
post #14 of 38 Old 09-09-2007, 10:38 PM Thread Starter
landyacht318
Off the Grid
The doors are sagging just because of the hinge pin/ bushing slop. My 3rd door top hinge has about 7 mm of play back and forth. I bet that pin is about ready to shear
You have given me an Idea. I might rig up some sort of system using a small bottle jack to push the hinge pins up and out through the top. The one C clamp I have will be inadequate. I do have access to a giant gear puller which should work on the top hinges
post #15 of 38 Old 09-09-2007, 11:33 PM Thread Starter
landyacht318
Off the Grid
Here is the tool I was envisioning. Others envisioned it first.
I need a bigger C clamp.
post #16 of 38 Old 09-10-2007, 10:04 PM
stev
Seating for 12
stev's Avatar
Quoted: 3 Post(s)
Wow, we have a great artist here! I could never drawing something up that good in Paint!
stev is offline
post #17 of 38 Old 09-10-2007, 10:22 PM Thread Starter
landyacht318
Off the Grid
I didn't create that illustration, I copied it from some site when searching for hinge pin removal tools.
I tried my HD gear puller tool on my third door hinges today, The nipple on the drive pusher basically dug into the hinge pin without budging it.
There is no way the illustrated tool could put out more force than the gear puller.
Maybee with a weeks worth of penetrant and some heat it would move.
I think I'm gonna make another effort to find a local junkyard and replace the whole damn hinge. I was able to bust the bolts loose on the broken one. The only real bad door is the third, and it might just stay that way.
post #18 of 38 Old 09-11-2007, 07:19 AM
Dodgevanman
Do It In A Van
Tell you what...how many hinges do you need?
I can go down to my local pick n pull and pull some hinges and send them to you. I can't guarantee color match, but I can get you some good hinges.
Nate Breece
5.2L Magnum
3.8L
Member of:
post #19 of 38 Old 09-11-2007, 08:13 PM Thread Starter
landyacht318
Off the Grid
Nate,
Incredibly kind offer! I just might take you up on it. However, I've already ordered the hinge pin kit(for 4 hinges) for $15.50 delivered, and really want to try to get the old pins out first.
The broken hinge I was able to remove from van and door but am still unable to budge the pin in 2 of the 3 holes. I tried the gear puller, propane torch, and a BFH. I'm thinking machine shop or a 17/64 colbalt drill bit on my old man's drill press. So far I've even managed to keep my temper in check. I guess whalin on something with a BFH is a pretty good outlet even when accomplishes nothing.
What would a machine shop do If I showed up with the hinge? Hydraulic press? Drill? How much you think they'd charge?
post #20 of 38 Old 09-11-2007, 08:59 PM
alloro
Elder User
Quoted: 17 Post(s)
A shop will press them out, you cannot drill them since the pins are hardened steel. I suspect you'd be looking at $5 per hinge, which is pretty fair.
alloro is offline
    New look for 07 Durango RAM MAN Rumor Mill & Gossip Talk 4 03-19-2007 04:11 PM
    '07 Charger SRT-8 RAM MAN Rumor Mill & Gossip Talk 1 09-02-2006 12:47 PM
    2005 Ram Pickups Press Release FreeLantz Rumor Mill & Gossip Talk 7 10-10-2005 12:48 AM
    magnum audio wireing color scheme ericaperez Dodge Magnum - General Talk 1 06-18-2005 10:05 PM
    2004 Dodge Truck Highlights RAM MAN Rumor Mill & Gossip Talk 0 09-03-2003 05:27 PM
