Correcting Error Code P0137 For 04 Durango - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 5 Old 09-03-2007, 11:34 AM Thread Starter
ILIKEMOPAR
Hello,
My 2004 Dodge Durango 5.7L 4X4 Limited has an error code P0137 (02 Sensor Circuit, Low Voltage Bank 1 Sensor 2). I currently have 35,072 miles on it.
The D is running fine. Gas milage appears to be normal 13.5 - 15 local and 18-19 highway.
I've cleared the error code in the past by disconnecting the neg battery cable and about every 3 - 4 weeks, the error code will return.
My question is do I replace the O2 sensor? If not, what do you recommend?
I prefer doing my own maintenance as much as possible.
Thank you.
CWO5 USN
2004 Durango 4X4 LTD 5.7L[/B]
99,000 miles and running strong
-K&N drop-in filter
2004 Neon SXT 2.0L[/B]
125,000 miles and running strong
-K&N drop-in filter
1996 Ram 5.2L 1500 sold
1999 Durango 4X4 5.2L sold
ILIKEMOPAR is offline
post #2 of 5 Old 09-04-2007, 07:14 AM
Beach Assault
Beach Assault's Avatar
Quoted: 12 Post(s)
I would replace it if not under warranty...
BTW: How did you read your codes? My aftermarket reader (~4 years old) can't, and i can't get the odometer to display it...
Big Black Limited w/Hemi and 20" Chrome Ram Wheels
Roof Carrier for 20" Spare
Removed Front Spoiler
Tinted Front Windows
Blackened Tail Lights
SmittyBilt Grill Guard
Blacked out the grill
1 1/2" Torsion Lift
Westin Sidebars
OEM Mudflaps
Rancho RSX Series Shocks
Red Brake Calipers
Slotted Rotors
Hawk Pads
MOPAR/Magnaflow CAT-Back exhaust
SuperChips[tm] Tuned 93 Octane
Taylor "Shorty" Sparkplug wires
Home-built PVC SRI
DodgeTalk.com Durango Club Member #41
Beach Assault is offline
post #3 of 5 Old 09-04-2007, 08:24 PM Thread Starter
ILIKEMOPAR
Thanks for the reply - I can send you the error codes
Send an e-mail to me at hkycards@aol.com and I'll send you the error codes.
I also have a maint manual for the 2004 Durango which has the error codes listed.
CWO5 USN
-K&N drop-in filter
-K&N drop-in filter
post #4 of 5 Old 09-05-2007, 07:16 AM
Beach Assault
Quoted: 12 Post(s)
My problem is that I can't get the truck to tell me the codes...
1 1/2" Torsion Lift
Westin Sidebars
OEM Mudflaps
Red Brake Calipers
Slotted Rotors
Hawk Pads
Home-built PVC SRI
post #5 of 5 Old 09-05-2007, 06:31 PM Thread Starter
ILIKEMOPAR
Reading The Error Codes
After you have inserted your key into the ignition; turned the key to the acc (without starting the D) then off then on, then off, the stop at on (acc without starting your engine).
You turn your key to on three times (on, off, On off, on) then look at your odometer reading, if your Durango detects an error, the error code will appear.
I just learned that if your Durango doesn't detect the same error after 3 starts, the check engine light will automatically disappear.
This happened to me two times with my P0137 error code. However, my concern is, since the error has appears and disappeared two times, my O2 sensor may be starting to fail.
CWO5 USN
-K&N drop-in filter
-K&N drop-in filter
    All-New 2004 Dodge Durango RAM MAN Rumor Mill & Gossip Talk 4 10-10-2003 08:48 AM
    2004 Dodge Truck Highlights RAM MAN Rumor Mill & Gossip Talk 0 09-03-2003 05:27 PM
    Reducing Expense in Prep for 04 Durango RAM MAN Rumor Mill & Gossip Talk 0 08-04-2003 04:21 PM
    The all new 04 Durango (PICS) Ron Wilson 1G Dodge Durango General Talk 12 01-09-2003 01:41 AM
    '03 GO SLT pics from DC RAM MAN 1G Dodge Durango General Talk 2 09-07-2002 02:18 PM
