'97 Caravan 3.3 dies when put in gear - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 08-29-2007, 09:46 AM Thread Starter
OrangeEXS
The Caravan stalls as soon as I put the automatic transmission in gear. If I gas it a lot as I put it in gear, I usually get going, but it it chugs and learches until up to speed - where it seems to run normally. Stop and it stalls again - but re-starts perfect everytime, just stalls when I move the shift lever to drive (drive, L, or 3, same result).
I did the trouble code trick, and read a 1-2 (battery disconnected in last 50 starts), which I believe is because I pulled the battery cable overnight to reset the computer.
Any help on this would be greatly appreciated! thanks, john c.
OrangeEXS is offline
post #2 of 6 Old 08-29-2007, 12:02 PM
tactransman
Transmission Man!
tactransman's Avatar
It sounds like your torque converter is going bad and staying engaged.(locked) Is the fluid dark and smelly?
Terry aka tactransman
'99 Ram 1500 4X4 5.9 Automatic #110 in the White Truck Club
Aren't you tired of getting your parts for your Super Bee from a kid that thinks a Civic is a "hot rod"!
Mods:
MSD Blaster 3 Coil
Magna Flow Cat and "Y" pipe
46RE Built to the Hilt
Transgo TF OD JR Shift Kit (With Mods)
Billet Cover Converter
Upgraded to five direct clutch drum
Five Overdrive Brake Clutch pack
47RE STEEL front planetary
Sonnax Reverse servo parts
HD Kevlar Lined Rigid Int Band
Deep Pan w/cooling tubes
3.8 ratio Int lever
billet Int servo struts
tactransman is offline
post #3 of 6 Old 08-30-2007, 11:56 AM Thread Starter
OrangeEXS
Fluid looks good. Changed about 7k miles ago. There is no "bump" on putting it in gear, the engine just instantly dies or cuts off (unless I gas it pretty good at the same time, then it does bump and move forward). I'm not an expert, but if the TC was engaged, wouldn't I get a "bump" just before the engine dies even without gassing it?
I borrowed a loaner code reader from Auto Zone and will try that tonight - see if it gives any more detail than the ignition on-off-on-off-on code test.
thanks, john c.
post #4 of 6 Old 08-30-2007, 12:04 PM
tactransman
Transmission Man!
No bump,just instant kill of the engine like you dumped a clutch at idle.
Mods:
MSD Blaster 3 Coil
3.8 ratio Int lever
post #5 of 6 Old 08-30-2007, 01:38 PM
vabear
Loss of Power
I would be suspicious of the idle control valve, the code scan is an excellent idea, I get mine done at Advance for free.
vabear is offline
post #6 of 6 Old 08-31-2007, 12:22 AM Thread Starter
OrangeEXS
OK, I take that back. There is a "bump" when I put it in gear, and it is fairly substantial, I must have missed that in all the excitement. Perhaps your original diagnosis is correct. The code reader comes up empty - no codes to report. Anything else I can do to test or otherwise firmly diagnose this problem?
thanks, john c.
    1995 3.3 engine, dodge caravan, with a problem of running great at idle but Champ1962 Dodge Caravan General Talk 4 08-19-2007 09:07 AM
    3.3 Caravan Speedometer tsc325 Dodge Caravan General Talk 0 07-09-2006 10:06 PM
    99 Gr Caravan 3.3 V6 - Voltage Issues - Help! grafixjoe Dodge Caravan General Talk 1 04-16-2006 11:42 PM
    1996 Grand Caravan SE 3.3 /Belt Tensioner Pulley lugnut003 Dodge Caravan General Talk 3 08-08-2005 11:57 AM
    98 Grand Caravan 3.3 fxpm Dodge Caravan General Talk 3 03-12-2005 10:30 PM
