Help me diagnose a stumble on a 3.8 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 68 Old 08-28-2007, 02:47 PM Thread Starter
Rick99
My wife's '01 T&C with the 3.8l v-6 has an occasional "stumble" or what seems like a miss during idle. It doesn't happen rythmically, but if you let it sit and idle long enough it will occasionally stumble hard enough to shake the van-- not back and forth, but just one thump, then it just continues idling smoothly until the next time. This seems to happen whether the engine is cool or warm-- at home after starting it in the morning or at a stop light after driving for a while. Sometimes, but not always, it will happen when accelerating from a stoplight.
Oh, I should add that once in a blue moon-- not often enough to even be annoying, the van will be very hard to start-- it will crank, but not start for several attempts. Don't know if that's related, but I thought I'd throw it out there.
The plugs and ignition wires were old enough that I just replaced them rather than test them and the problem did not go away. The PCV valve is fine too. Also, there are no PCM codes-- none stored, none pending.
So any ideas on what I should check next?
2003 Durango SLT
AWD, 4.7l
Mods: Remote Start
Just got a new set of BFG All-Terrains
Planning retrofit to 4WABS
1999 Durango SLT+
4x4, 5.2l
Mods: B&M Supercooler, Ford OEM Remote Start/Keyless Entry/Alarm, Heated Seats
01 T&C Limited 3.8l
Rick99 is offline
post #2 of 68 Old 08-28-2007, 04:25 PM
Merit
Throttle body/Throttle positioning sensor? Ever notice any RPM jumps while in cruise? I had something similar happen to another Chrysler product. Cleaned the throttle body and replaced the TPS. Worked like a dream.
Merit is offline
post #3 of 68 Old 08-28-2007, 04:53 PM
sgillett
Love my 66 monaco 500
sgillett's Avatar
Quoted: 1 Post(s)
Is it possibly the air conditioning clutch cycling?
My $.02
Scott
V10 Ram truck club member #3
Toys:
'96 Ram 2500 V10 4X4 extended cab, long bed for towing my 28-foot 5th wheel Alfa toy house.
1966 Monaco 500 with a 365 horse power 440 and almost all options, my project car.
'07 Nitro R/T
My son has a '69 Dodge Coronet 440 with a warmed up 318 4bbl
Economy vehicle: Yamaha FJ1200
sgillett is offline
post #4 of 68 Old 08-28-2007, 05:12 PM Thread Starter
Rick99
Thanks for the thoughts. It's definately not the A/C clutch cycling. The TPS is a thought-- could that cause a miss/stumble at idle though? This is happening only when you aren't pushing the throttle at all.
2003 Durango SLT
AWD, 4.7l
Mods: Remote Start
1999 Durango SLT+
4x4, 5.2l
01 T&C Limited 3.8l
Rick99 is offline
post #5 of 68 Old 08-28-2007, 07:34 PM
XDGT03
I think it could cause it. Does it idle perfectly smoothly otherwise. Does it hunt around at all?
How about the map or maf (I don't know which it has). Possibly need cleaning/replacement? Crank position sensor? If the crank is walking at all it could cause it to stumble.
XDGT03 is offline
post #6 of 68 Old 08-28-2007, 08:14 PM Thread Starter
Rick99
I hadn't really noticed if it was hunting, so I went outside to give it a test. I used the scan tool to watch RPM rather than just watching the tach. The van was cooperating with me a bit as it was missing constantly as I was testing it and the RPM was fluctuating from about 800 to 680. That was after letting it run a couple minutes to stabilize.
I also checked out the TPS voltage readings and with the engine off, it seems to move smoothly from .78 volts to about 3.88 volts. I think that's in spec as far as the voltage ranges, but the strange thing is that the scan tool is reporting TPS % at only 85% with full throttle. I checked it by pushing the throttle lever under the hood with the same result, so no linkage problem.
The TPS seems to fluctuate about .02 volts with the stumble and the MAP about .10 volts. Not sure if that's significant.
So does anyone know how I can test some of this stuff out without just replacing parts?
2003 Durango SLT
AWD, 4.7l
Mods: Remote Start
1999 Durango SLT+
4x4, 5.2l
01 T&C Limited 3.8l
Rick99 is offline
post #7 of 68 Old 08-29-2007, 10:59 AM
donald7150
donald7150's Avatar
my '98 has the same problem and it happens under just about all driving conditions. cold, warm, idling, highway speeds. it happens when the a/c cuts in and its like a hard bump when it does
there is a TSB on this issue that reprograms the PCM to dump a bit more fuel into the engine to allow the engine to absorb some of the bump when the compressor cuts in
but take note that the A/C WILL cycle in the defrost or defrost/floor setting no matter if the snowflake button is on or off
2005 Chrysler 300 (DD): 6000K 50W HIDs, Niteshades, LED Interior light Conversion...
'99 Caravan: Work van. 6000K HID headlights and fogs
'92 Chrysler Daytona IROC R/T (2.2L DOHC Turbo-III)
donald7150 is offline
post #8 of 68 Old 08-29-2007, 12:31 PM
XDGT03
The PCM supplies approximately 5 volts to the TPS. The TPS output voltage (input signal to the powertrain control module) represents throttle blade position. The TPS output voltage to the PCM varies from approximately 0.6 volt at minimum throttle opening (idle) to a maximum of 4.5 volts at wide open throttle.
Along with inputs from other sensors, the PCM uses the TPS input to determine current engine operating conditions. The PCM also adjusts fuel injector pulse width and ignition timing based on these inputs.
Also like the cam and crank sensors, a 5 volt reference is supplied from the PCM and returns a voltage signal to the PCM that reflects manifold pressure. The zero pressure reading is 0.5V and full scale is 4.5V . For a pressure swing of 0 - 15 psi the voltage changes 4.0V . The sensor is supplied a regulated 4.8 to 5.1 volts to operate the sensor. Like the cam and crank sensors ground is provided through the sensor return circuit.
XDGT03 is offline
post #9 of 68 Old 08-29-2007, 01:04 PM Thread Starter
Rick99
Donald-- Good thought-- I just flashed the PCM and the TCM up to the latest software two weeks ago and unfortunately, it didn't fix the problem.
XDGT03-- Thanks for the info on the TPS and MAP sensor. I think I read some factory materials that showed 0.78 volts at closed and 3.88 volts at WOT was within spec, but the fact that it should be as high as 4.5volts and that the PCM is reading it as only 85% makes me think that spec is off and something is wrong with the TPS in any case. I may replace that, since it seems to be messed up whether it is causing this problem or not. When I'm in there, I'll see if the throttle body and IAC are dirty.
Does anyone know what the MAP should be reading at idle? Maybe that's a way to test it.
2003 Durango SLT
AWD, 4.7l
Mods: Remote Start
1999 Durango SLT+
4x4, 5.2l
01 T&C Limited 3.8l
Rick99 is offline
post #10 of 68 Old 08-29-2007, 08:00 PM
XDGT03
Well, I think you would actually want to monitor it at the stumble to see if its reading varies prior to or after it. My guess would be something around 1.5 v at idle.
XDGT03 is offline
post #11 of 68 Old 08-29-2007, 09:07 PM
vipergg
miss
Could be a flakey or partially gummed up egr valve even if it doesn't throw a code .
vipergg is offline
post #12 of 68 Old 08-30-2007, 10:36 AM Thread Starter
Rick99
I'm going to have to take back some of the information I provided above. Last night I took off the EGR valve and it did have plenty of carbon in it but seemed to be opening and closing smoothly with a vacuum pump. I cleaned it up a bit anyway and put it back on. When I started the engine and let it idle it was smooth as silk-- great right?
Well, I realized the A/C was off and tried turning it on. With the A/C on, the stumble came back. The strange thing is that the stumble does not happen at the time that the A/C compressor engages or disengages (I can hear the click and watch it on my scan tool), which is why I said this wasn't related, but it definately happens while the A/C compressor is already engaged and it does not appear to happen when the A/C is off. I may run it a little more to verify this, but it seems to be what's going on.
2003 Durango SLT
AWD, 4.7l
Mods: Remote Start
1999 Durango SLT+
4x4, 5.2l
01 T&C Limited 3.8l
Rick99 is offline
post #13 of 68 Old 08-30-2007, 10:49 AM
donald7150
donald7150's Avatar
IAC motor maybe? the PCM will open it up some at the same time as the A/C compressor to take up the extra load that the compressor puts on the engine
post #14 of 68 Old 08-30-2007, 08:06 PM
STEAMFITTER
Im having the same problem with my 99 3.8 caravan. This thread was helpful. Thanks
STEAMFITTER is offline
post #15 of 68 Old 08-31-2007, 06:19 AM Thread Starter
Rick99
Yes, it's been helpful for me too-- just to think through what may be causing this-- so thanks to all that are responding. My next step is to clean up the TB and IAC and I'll report back with results.
2003 Durango SLT
AWD, 4.7l
Mods: Remote Start
1999 Durango SLT+
4x4, 5.2l
01 T&C Limited 3.8l
Rick99 is offline
post #16 of 68 Old 08-31-2007, 06:21 PM
XDGT03
I found this TSB
NUMBER: 18-008-02
GROUP: Vehicle Performance
DATE: Feb. 11, 2002
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 18-008-01, DATED MARCH 16, 2001, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDE ADDITIONAL MODELS.
SUBJECT:
Engine Sag/Hesitation And/Or Closed Throttle Start Stall
OVERVIEW:
This bulletin involves replacing the Throttle Position Sensor (TPS).
MODELS:
2001 - **2002** (RS) Caravan/Voyager/Town & Country
2001 - **2002** (RG) Chrysler Voyager (International Market)
NOTE :**THIS BULLETIN APPLIES TO VEHICLES EQUIPPED WITH A 3.3L OR 3.8L ENGINE AND BUILT BEFORE OCTOBER 01, 2001 (MDH 1001XX).**
SYMPTOM/CONDITION:
Engine hesitation/sag, closed throttle start/stall, and/or Diagnostic Trouble Code (DTC) P0123 - "Throttle Position Sensor Voltage High". May be more prevalent in cold temperatures below 0C. (32F).
DIAGNOSIS:
If no DTC's are present or DTC P0123 is present, perform the Repair Procedure.
If other DTC's are present further diagnosis is required.
PARTS REQUIRED:
REPAIR PROCEDURE:
1. Disconnect the negative battery cable.
2. Remove the electrical connector from the Inlet Air Temperature Sensor.
3. Remove the air cleaner box lid. Remove hose from throttle body.
4. Disconnect the electrical connector at the TPS.
5. Disconnect the electrical connector at the Idle Air Control (IAC).
6. Remove the three (3) TPS mounting bolts and TPS.
7. Reverse the previous steps to install new TPS, p/n 04686360.
POLICY:
Reimbursable within the provisions of the warranty.
XDGT03 is offline
post #17 of 68 Old 08-31-2007, 09:05 PM Thread Starter
Rick99
Hey, nice find! I guess I will replace the TPS as well as cleaning the IAC then.
2003 Durango SLT
AWD, 4.7l
Mods: Remote Start
1999 Durango SLT+
4x4, 5.2l
01 T&C Limited 3.8l
Rick99 is offline
post #18 of 68 Old 09-04-2007, 06:23 PM
STEAMFITTER
Post #16
I found this TSB
NUMBER: 18-008-02
DATE: Feb. 11, 2002
SUBJECT:
OVERVIEW:
MODELS:
SYMPTOM/CONDITION:
DIAGNOSIS:
PARTS REQUIRED:
REPAIR PROCEDURE:
POLICY:
post #19 of 68 Old 09-04-2007, 06:25 PM
STEAMFITTER
Thanks to the person who sent this to me. Much appreciated.
post #20 of 68 Old 10-13-2007, 04:47 PM
STEAMFITTER
this did not work for me. ill try a reset
    cold air intake for 06 GC 3.8 fishcarr2001 Dodge Caravan General Talk 7 05-16-2007 10:10 AM
    97 gc 3.8 over heating fatguy Dodge Caravan General Talk 0 05-09-2007 02:05 PM
    97 3.3L engine stumble at 1500 rpm CBP ENGINEER Dodge Caravan General Talk 13 08-01-2006 08:00 AM
    changing rear rocker arm cover gasket on 92 3.8 porcelien Dodge Caravan General Talk 3 01-28-2006 04:37 PM
    3.8 Engine swap thinkvideo Dodge Caravan General Talk 2 09-10-2004 10:33 PM
