Dealer said transfer case needs replaced because of one failed bearing? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 08-23-2007, 10:43 AM Thread Starter
klfeck
So I took my 2001 Durango into the dealer for what I thought was a wheel bearing replacement. The truck makes a womp womp womp sound when turning at low speeds. The dealer calls me back and says the wheel bearings are fine but that the vibration is coming from a bad bearing in the transfer case. . That failed bearing is causing the front driveshaft to vibrate. The service manager said that Dodge recomends replacing the entire transfer case. It seems very odd to me that they want to replace the entire tranfer case for a failed bearing. By the way the cost is $1600. I have been living with this noise for a few years and it does not seem to be getting any worse. I tend to believe that since the truck already has 105,000 miles I should just let it go until it fails then replace it myself with a used unit from a salvage yard. Why would they not just replace the failed bearing? Any thoughts?
klfeck is offline
post #2 of 9 Old 08-23-2007, 10:50 AM
hemimech
hemimech's Avatar
I'd remove the front prop shaft, put the lever or switch in 4X4 high range and drive it for a while. Don't worry you won't hurt it. If the sound is still there its not likely its the transfer case. Does it sound like it is coming from the front of the truck or underneath you?
hemimech is offline
post #3 of 9 Old 08-23-2007, 11:09 AM Thread Starter
klfeck
Funny thing is that I only hear it when I am making slow speed turns. Now the dealer did say that my tires are cupped and I do hear a hum while on the highway, so that hum could be the cupped tires or the front shaft from the transfer case vibrating. What is the worst that can happen if that bearing totally fails? Will it just get louder and louder and make the 4x4 worthless or could it cause damage to the front axle or transmission?
klfeck is offline
post #4 of 9 Old 08-23-2007, 02:53 PM
hemimech
hemimech's Avatar
A failing bearing in the t-case will slowly get louder then eventually spin its outer shell in the case. At that point the aluminum case will be junk. A reputable 4X4 or gear shop would do a rebuild on the t-case for a lot less than your dealer quote. Slow turns would cause the spider gear asmy. in the front axle to rotate rapidly...possible source of noise. So check the fluid level in the front diff. My 2000 DN RT has a front prop shaft with a double cardian u-joint set up(at the back of the front prop shaft) The pivot ball in the center of the joint went bad on mine, causing a light thump at slow speeds. I'm not sure if your 01 has that style joint or not, sometime in 01-02 they went to a CV type of coupling at the rear of the front shaft. Take a friend for a ride to try and isolate the location of the noise before you spend big money on something you might not need.
hemimech is offline
post #5 of 9 Old 08-23-2007, 03:28 PM
Kinjirra
I learned a long time ago that dealers will always try and get you to spend the most money you can even if they can fix it for cheaper.
Example...Took a chevy 2-10 into the dealer for a low RPM missfire. Mech told me the engine was shot and I needed a replacement asap or I should buy a new Truck. I drove that truck for 3 more years with no problems.
Example Two: My Ex had an old model Dodge car(late 80's) that she was having tons of problems with. After she spent 1500 bucks in repairs the dealership told her to buy a new car because they couldnt fix the problem, the car was just too old. I replaced the TPS and did a tune-up, Car is still running fine and its been 5 years now.
Now I dont know your dealer but be very leery about them since INMO they are just out to screw you.
1998 Dodge Durango SLT 5.2L 4x4
Bone stock for now.....
Kinjirra is offline
post #6 of 9 Old 08-23-2007, 05:59 PM
Don Fox
Don Fox's Avatar
Quoted: 2 Post(s)
klfeck:
What T case do you have (NV233 or 244), and where are you located? I happen to have a 100% good NV233 with 56K that I need to find a home for. This was removed only because I installed an NV244 case to have the AWD option.
I want $249 + UPS shipping from 45056 to your door or if you are close we will meet somewhere in between .
Let me know if you are interested.
Don
2014 Charger R/T Hemi AWD in Billet Silver
w/ 3.07 gears 10.27.14
2004 Durango SLT Hemi AWD Flame Red
w/ 3.55 gears. Mine since 03.26.10.
2011 Hyundai Santa Fe GLS AWD V6
Mineral Gray. Hers since 8.21.14
Don Fox is offline
post #7 of 9 Old 08-23-2007, 06:10 PM
Dakotah18
Troubleshooter
dealers always try to get more, especially now when the car market is not at its best, they gotta make it up somewhere.
To the victims and their families of the shooting at Northern Illinois University, my heart and prayers go out to you. 02-14-08 Will not be forgotten.
'08 Chevy Impala SS 5.3L - 122,000 miles, all factory options, 20% Tint rear and 45% tint front, police horn
'92 Dodge Ramcharger Canyon Sport 4x4 5.2L - 169,000 miles on body, egr and cat delete, rebuilt engine and transmission, windshield visor with marker lights and ram head with lighted eyes----sold
'95 Dakota 4X4 SLT 318 - 245,000 miles, Duals, CAI, 2 Toolboxes, amber lightbar, side mounted lights, 12V outlets in bed, 150W power inverter, fogs and secondary reverse lights, strobes, all factory options, 31" tires, drop-in bedliner, bedlined lower panels, 2nd gen rear bumper, several aftermarket mods. Planning to add more strobes and lights----sold
Dakotah18 is offline
post #8 of 9 Old 09-03-2007, 08:51 PM Thread Starter
klfeck
Transfer Case
I have a 233D. I live in Cincinnati and from what I can tell you are near Oxford. I may be interested in your T case.
klfeck is offline
post #9 of 9 Old 09-03-2007, 09:07 PM
Don Fox
Don Fox's Avatar
Quoted: 2 Post(s)
kfleck:
If you want, email me at taurusshoguy@yahoo.com. I would enjoy finding a new home for this T case. You are close enough that we could meet in between for some lunch or coffee near Colerain or Tri County.
If you are looking for a good NV-233 T case, this is the one.
Don.
Don Fox is offline
    Transfer case issues Lox 2G Dodge RAM - 4X4 Talk 2 09-07-2006 08:48 PM
    found a jeep transfer case for cheap. blakdak91 Dodge Dakota 1st Gen (87 -96) Forum 0 01-19-2006 12:50 PM
    Transfer Case Loc 'light' prob.... B. Herder 1972-1987 Dodge Ram Trucks (D, W-series) 7 02-28-2005 01:23 PM
    transfer case leaking mikeumkc 2G Dodge RAM - General Talk 2 06-08-2002 11:49 AM
    Transfer case rebuild!! medic3720 2G Dodge RAM - Drivetrain Talk 0 05-25-2002 08:56 PM
