1994 Caravan 3.3, starts and dies - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 13 Old 08-22-2007, 11:05 PM Thread Starter
bigjdog
Hi Everyone, new to the site. I've got a problem with my Grand Caravan. I just received it from the previous owners who gave up on attempting to find it's problem. Here's the specifics 1994, 3.3, 150,000, with fresh
plugs, wires, coil pack runs on an Intrepid, crank sensor is still
magnetic and cleaned (but I don't know how to check it correctly), compression is 150 across the board, fuel
pressure is 50 cranking and running (if you can call it running), air
filter is new. Now the bad. Van cranks and fires right up, but
immediately dies (within a second or 2). If you pump the accelerator
it'll keep running for awhile, cycling up and down as you pump. Smells
flooded and dies as soon as you let off or if you hold it to the floor
or you get out of rhythm. I pulled up the rail with injectors still on
it and none of them leak and all seem to be firing as they should (to
the naked untrained eye) when you crank it over. There are no codes.
Everything else seems to be operating normally, all fuses and relays
are good. I'm hoping to try a new camshaft sensor tomorrow, and
hopefully find an engine computer at the bone yard. If neither of those
is the fix, I'm at a loss. The only other thing I could think of is the
timing chain slipping, but I figured it'd still run, just poorly or the
compression would be down. Anyone have any ideas or know how to check
the timing chain w/o disassembling the entire front of the engine? On a side note, the second it runs by itself it sounds perfectly fine.
Thank you very much for reading.
bigjdog is offline
post #2 of 13 Old 08-23-2007, 02:01 PM
mfahey
Quoted: 1 Post(s)
I was going to suggest checking for vacuum leaks but that would require keeping the engine going long enough to get a meaningful reading. Will it run at higher rpms, say 2000?
At 150,000 miles, you would almost certainly be ready for a new O2 sensor if the previous owner hadn't replaced it. Another possibility would be exhaust related if the converter has plugged up and is creating back pressure.
2001 GC ES 207,000 miles
2015 Volvo V-60
2012 Camry Hybrid
1970 Camaro, original owner
mfahey is offline
post #3 of 13 Old 08-23-2007, 03:22 PM Thread Starter
bigjdog
I can't keep it going at any steady rpms because it just dies. It'll only idle for a second or if I keep revving it at a specific rhythm it'll rev up to 2000 or so in cycles and right back down. If I hold it on the floor it dies in a second. I never thought about the cat being clogged, maybe i'll try disconnecting the exhaust or have someone hold their hand over the pipe next time I get it running. The odd thing is that it always starts right up, then shuts right off. I'll try the exhaust check. That's the one area I never considered. It's nice to have a second opinion.
bigjdog is offline
post #4 of 13 Old 08-23-2007, 07:42 PM
XDGT03
That cat seems like a good thing to check. Does it have a map or maf on this year? Most of the sensors can be checked via a ohm/volt meter. What does the oil smell like? If it smells of fuel then it might be that the fuel pressure valve is stuck open and flooding too much fuel into the cylinders.
XDGT03 is offline
post #5 of 13 Old 08-23-2007, 11:12 PM Thread Starter
bigjdog
Update time-
Tonight I disconnected the exhaust at the head pipe (just before the cat), no change. Tried 2 different junkyard cam sensors, no change. The van has a MAP sensor, didn't read your post before I went to the yard or I would've grabbed one or 2 of those also. I also picked up a PCM (engine computer) today at the yard, going to try that in the morning. If it solves my problem, I'll post back immediately, otherwise I'm going to drown my sorrows in a case of beer or 2 up north over the weekend. I thought if the MAP was bad, the car wouldn't start, either way, I'm going give her a couple of taps after I find out that the computer change didn't solve the problem. Thanks again for the replies.
BTW, oil's free of gas and I took out the fuel pressure regulator tonight (it's new) just to make sure it was installed correctly.
bigjdog is offline
post #6 of 13 Old 08-24-2007, 05:10 AM
BobReeves
Quoted: 1 Post(s)
Don't see where your located but if you are close to Tulsa maybe we could work out a deal. My 94 has 226,000 on the clock and is getting a little tired. Between the two of them I could have plenty of spare parts
BobReeves is offline
post #7 of 13 Old 08-26-2007, 03:02 PM Thread Starter
bigjdog
Not too close to tulsa, SE Minnesota. I'm about ready to run it off a cliff though. Anyway, swapped out the engine computer for the one I got at the yard, no change. I banged on the map sensor for awhile, no change. Tomorrow I'm going to stop at the yard again and get a crank sensor and a map sensor. Otherwise I'm completely lost.
bigjdog is offline
post #8 of 13 Old 08-26-2007, 06:37 PM Thread Starter
bigjdog
Unplugged MAP sensor, now van runs, and finally the CES light is on. Picking up a new sensor tonight. Thank you very much for your ideas, I really appreciate it.
bigjdog is offline
post #9 of 13 Old 08-26-2007, 09:31 PM Thread Starter
bigjdog
New MAP sensor installed, runs like a top.
bigjdog is offline
post #10 of 13 Old 08-27-2007, 07:43 PM
bw03
Glad to hear things worked out. I hope you didn't spend too much on all those used parts to diagnose.
bw03 is offline
post #11 of 13 Old 01-12-2008, 09:17 PM
edmost
Question
could anyone advise if a 1990 Caravan 3.3 has the MAP sensor ?
I'm having intermittent fuel delivery problems on this vehicle also.
Have reconditioned the fuel pump, cleaned tank, filter ect...
and still the vehicle doesn't start.
Thanks for any help and advice
edmost is offline
post #12 of 13 Old 01-13-2008, 07:50 PM Thread Starter
bigjdog
Yes it does. It's located in the middle of the engine (side to sidewise that is) and screws into the back (firewall side) of the upper intake plenum. That MAP sensor fits 90 - 95 Caravans/Voyagers/etc with a 3.3 (some 94&95s with 3.8) and also 93-97 Intrepids/etc. with a 3.5.
bigjdog is offline
post #13 of 13 Old 01-23-2008, 11:00 AM
edmost
Thanks for the above info. I suspected the MAP sensor but found that wasn't the problem.
This is 1990 3.3 L Caravan w/ 130,000 miles so understandbly its had its share of work done on it. What we found is a wire that was rubbed raw from presumbly the serpentine belt or one of the pullies. It is connected to the Crankshaft reference sensor, I think. It was causing intermittent voltage shorting and thus lieing to the system. Its just a thin yellow wire (down by the serpentine belt). My man by-passed it with a loop of wire connected to a couple of alligator clips and V-ROOM! A splice of the wire to make a permant fix and the vehicle is starting and running.
It was hard to see (this raw wire) and I think the Dodge gods must have been on are side. This time. Just some backyard guys trying to keep 4 wheels on the ground. Good luck to all with this sort of problems...
edmost is offline
    1990 starts but dies pump works ASR? armchair Dodge Caravan General Talk 7 03-31-2006 09:27 AM
    Starts and then dies after replacing fuel pump. david30 1973-1993 Dodge RamCharger 3 03-26-2006 03:20 AM
    02 Grand Caravan engine dies boiler87 Dodge Caravan General Talk 7 03-17-2006 02:04 PM
    1997 Grand Caravan SE starts, runs for 2 sec then dies matrush Dodge Caravan General Talk 9 11-17-2005 04:20 PM
    96 Gr Caravan starts but dies when put in gear tedell Dodge Caravan General Talk 0 10-10-2004 09:16 PM
