Squeaky Suspension!!!! - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 8 Old 07-19-2007, 08:58 PM Thread Starter
Prsguitarse
I have a 01' dakota 4.7 V8 with about 69K miles and i need some serious help or advice. Every bump or just uneven paved roads makes my front end squeak nasty and its about to drive me crazy. Im pretty sure i just need to get new shocks and struts, but how much you think that will cost me. DOnt need the best, but some good ones. Or does anyone know some ghetto remedies that i could do to just reduce the SQUEAK!?
Dumped Magnaflow Exhaust
Alpine 9855 Head Unit
Memphis Door Speakers
Infinity Amp
12" Infinity Sub
Superchip Tuner
Airaid Cold Air Intake
Viper Alarm System
Soon to come:
- Power Wire
- Clear Corners
Prsguitarse is offline
post #2 of 8 Old 07-20-2007, 11:38 AM
sjonnie
The source of squeek in the front suspension can be almost everything, like you I had the car squeeking like crazy whenever I went round a turn. In order of what's easiest to replace I replaced sway bar bushings, shocks, upper-ball joints and lower ball joints. I haven't replaced the control arm bushings simply because I can't find anywhere that sells them. My squeek problem is pretty much gone. An easy cost-free job is just to remove the sway bar, clean and grease the bushings and then reinstall. That might help. Shocks should probably be next on your list. Oh and ball-joints if you've never done them.
sjonnie is offline
post #3 of 8 Old 07-21-2007, 11:34 AM
hemi dave
The Cherry Express
hemi dave's Avatar
"Summit" sells a nice "Energy Suspension" poly bushing kit, that would be my choice!
hemi dave is offline
post #4 of 8 Old 07-21-2007, 11:57 AM
BRUISER QUAD
MUDDY AFFAIR
BRUISER QUAD's Avatar
for the "ghetto remedy" i would get some white lithium grease in a spray can, attach the "straw thingy" to the sprayer so you can pinpoint where you want it and go around and hit all the bushings, joints or anything else that moves.
I did this on my 01 Dakota just before going on a road trip, didn't have time to correctly replace anything, also didn't want it to cut into my vacation $.... This cured it long enough that I forgot about it and then it was sold....
2004 Dakota Quad- 4.7L 4x4
9.25" 3.55 posi rear, open front
Blue Truck Club #87 287 Enthusiast Club #666 NEKID Truck Club #666
Yellow/ Amber Foglight Club #666 Don't Fear the Drone #666
20% tint, vent shades, Blacked out between front and rear windows
de-badged, Mopar Billet Fuel Door/ body color matched!
NiteShaded rear brake lights w/ led bulbs
Yellow headlights, Yellow foglights
HELLA 500 driving lights on bumper
w/ 100w hella bulbs & custom Hella Grilles
clear turn signals w/ silverstar ambers
Xtang Saber tonneau, Line-X under the rail
POWER WIRE
FastMan 68.5 Throttle Body w/ K&N FIPK
Clutch fan removed, 180* T-stat
Bosch Platinum+4 plugs
Flowmaster Super44 Dumped
Clarion head, polk components
Torsion bars cranked, 2" blocks
285/75/16 Nitto Terra Grapplers on BLACK Cragar's
MAG-LIGHT- Magcharger hardwired
R/T- Heated, Power Leather Seats w/ full console
Blacked out interior top to bottom
BRUISER QUAD is offline
post #5 of 8 Old 07-23-2007, 11:26 PM
silvrbeastjr.
um......howdy?
silvrbeastjr.'s Avatar
yup! some WD-40 or some silicone will do wonders....for a while..
or do only a few parts first to see if it fixes it. if it doesn't then try another bushing or something. when you find it, replace it..
silvrbeastjr. is offline
post #6 of 8 Old 07-24-2007, 04:25 PM
2005blue4x4dak
lets go 'wheelin!
on my '04 it turned out to be the swaybar bushings.
Next time i'm gonna get the Energy Suspension kit....this last time wound up having it done at a shop, since i was short of time!
2007 PT Cruiser-too much to list, and still more to come!
1991 Dodge Dakota- 3.9, auto, longbox, buckets, new cluster w/tach, fresh timing chain....69k orig. miles.
2005blue4x4dak is offline
post #7 of 8 Old 08-15-2007, 06:18 AM
jmacii
Lithium Grease!
My 01' 4.7L QC 4x4 front end started squeeking and I just bought some spray white lithium grease and sparyed front struts and arms and it all went away!
jmacii is offline
post #8 of 8 Old 08-19-2007, 10:18 PM
ethanwatters85
ethanwatters85's Avatar
I had Bad front end squeaking, and it was Balljoints at about 75K miles. I replaced them with Moog Balljoints, then had to replace those again under warranty at about 120K. So far so good.
97 Dakota, Quad Cab 2WD Green 318ci, 5.2l
Current Mods:
K&N Cold air Intake
180 Thermostat
Hypertech Power Programmer III on the way
Straight Pipes from the Cat
Edelbrock Shocks
Moog Balljoints
Tinted Windows
PIAA SuperSilicone Wiper Blades
6 Hella Supertones Horns
Hella FF1000 Driving Lights
Alpine Head Unit, Polk components, and Polk 10" Subs in MTX Thunderform box, powered by 500W Bazooka amp.
ethanwatters85 is offline
    3 link or 4 link, 2:1 ratio or bridge? bnii 3G Dodge RAM - Sport Truck Talk 20 02-09-2007 07:56 AM
    Press Release: 2007 Dodge Nitro FreeLantz Rumor Mill & Gossip Talk 0 09-01-2006 05:55 PM
    2001 R/T coupe squeaky suspension poor mr rich 2G Dodge Stratus - General Talk 1 08-24-2005 03:45 PM
    '01 Quad cab squeaky suspension? Ranger690 2G Dodge Dakota - Tire/Wheel/Susp Talk 2 03-20-2004 05:25 PM
    2005 Dodge Magnum Engineering Press Releases RAM MAN Rumor Mill & Gossip Talk 0 03-03-2004 09:55 AM
