Changing dash lights/colors - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 07-15-2007, 01:30 AM Thread Starter
Blakdak00
Blakdak00's Avatar
Lightbulb Changing dash lights/colors
I was wondering if anyone had changed the lights in the dash before or if it could even be done. I want to get rid of the old green in favor of maybe red/orange. Already have red neons under seats, going to put some under truck, and a few other places inside, but I have these ugly bluish-green lights in my dash. I think it would look sweet with some red LED's instead. Just want to know if anyone else has some input on the idea before I tear my dash apart to find theres nothing I can do. Thanx.
2000 Black Dodge Dakota Sport 4x4
4.7L V-8 with dual strait pipes, dual cone filter high flow intake intake. Pioneer deck, Audiobahn amp., and a Kicker sub. Factory Infinity system (loud an' proud). Set of 32-11.5 ProComp MudTerrains. Mods to continue....
Blakdak00 is offline
post #2 of 7 Old 07-15-2007, 06:41 AM
mopar fan
mopar fan's Avatar
Here's a *How To* in the Ram forums. It should be pretty much the same for you.
http://www.dodgetalk.com/forums/show...ht=dash+lights
Name's
AL
Proud Member of the Original WCPW Club
If you don't stand behind our troops, PLEASE feel free to stand in front of them.
Official Dodgetalk Facebook Page:
mopar fan is offline
post #3 of 7 Old 07-15-2007, 02:44 PM
pirahnah3
Official qwerty thief
pirahnah3's Avatar
thanks to Yellowkota2k for this writeup that i asaved form a while ago
First off, I know this looks a little weird. Me writing a stupid little how-to, on turning your gauges different colors. Well, of the many things I've done, this is the only one that could apply to EVERY Dakota and Durango out there. Well, if I think of it, it really applies to every vehicle. This is a pretty universal modification. So many people were interested to see how easily they can do it, and what to use. Though I know I could write a how-to on many other different things, this was the one people wanted to see...
1. The bulbs:
They look a little fuzzy, but they're 5-LED Wide Angle 194 LEDs. They can be pruchased below for the different prices listed:
http://www.superbrightleds.com/1157.htm
(scroll down about 3/4 and look for "WLED-x5 LED Wedge Base Bulbs")
Red - $2.79
Green - $4.04
Blue - $4.14
White - $4.29
2. The bases:
In order to use these LEDs on the gauges, you MUST buy new bases for them to go in the gauges. They are 1/2" instrument cluster gauge bases, which can be found at any local auto store which would have this type of stuff. I got mine at Autozone, because it was 9:00 at night, and didn't know where else I could get them quickly. Bad thing is, they cost a whopping $3 each.
3. Now before you track down these parts, you need to know how many to get. If you want to do JUST the gauges, get 5 of each. If you also want the turnsignal lights to be the same color, get 7 of them. I did the turnsignals also, so they would flash bright blue in the daytime instead of standard green. In the end you should end up with either 5 or 7 of these:
4. The rest should be fairly easy. It's just putting them in. Start by removing the dash. If you don't know how to do this, I honestly suggest you to stop, and let someone else do it, because it's the easiest thing do remove in your truck, besides your seatbelt when it's buckled.
5. Remove the gauge cluster. There are 4 screws that hold it in. Once they're out, just pull it away from the dash.
6. On the backside you'll see the stock bulbs. You may need to get a set of pliers to twist them. It really doesn't matter if you break them or not, since you won't be using them anymore. The top two in the center are the turnsignals, the rest are for the gauge lights.
The stock bulbs you will remove look like this:
7. After that, put everything back in. It was that simple. Now your gauges should have went from this:
To this!
This can also be applied to the red LEDs. I'm not sure what color will end up if you use the green or white, since the stock gauges are green, and lighted by white (dim white) bulbs. I know the blue and red will turn then to the exact color of the LEDs you use.
Jim
PROUD MEMBER WCPW (the origional thread)
1955 1/2 Dodge Town Panel Truck Buildup happeneing
pirahnah3 is offline
post #4 of 7 Old 07-15-2007, 05:17 PM Thread Starter
Blakdak00
Blakdak00's Avatar
Sweet, I was hoping someone had done something like this and could explain it all, thanks guys.
post #5 of 7 Old 11-09-2007, 05:55 PM
w9awx
What about losing all the needles? Is there something that could be done about them?
Gregg
Waukesha, WI
2000 Dodge Dakota SLT Plus, Regular Cab, Short Bed, 3.9L V6, Auto, 4x4
w9awx is offline
post #6 of 7 Old 12-01-2007, 05:04 PM
zzzz'r
zzzz'r's Avatar
ditto, if the needles are gone all the cool green you saved by doing it yourself goes to the state for speeding tickets
ZZZZ'r 03' QCSB
Sound: Kenwood Headunit, Infinity Kappa Ref on the 4 corners, 10" Alpine Type R in center console, powered bye Alpine 500.1 and Alpine 400.4 amps Motivation: A freaking HEMI!!! with f/m 70 series, AEM cold air, throttle body spacer (I know... bite me), Super Chips tuner, and aux battery installed under back seat Curbside: 6" skyjacker lift, black shorty antenna, spray on bed liner rockers, 15% tint on front to match back, 35" Yoko tires, KC Day-lighters behind the grill, all metal billet grill insert, and one "bad mf'ing i'll cram it up your tail pipe" ranch hand bull nose bumper
zzzz'r is offline
post #7 of 7 Old 12-03-2007, 10:08 PM
zzzz'r
zzzz'r's Avatar
OK i just watched "Trucks" on Spike TV and he installed a new dash cluster kit that included clear needles that show any color light! If i can find the brand I'll post it for all.
ZZZZ'r 03' QCSB
zzzz'r is offline
    Dash upgrade *or* 'Gauge options for 72-80 Trucks!' bherder 1972-1987 Dodge Ram Trucks (D, W-series) 49 11-18-2007 06:40 PM
    Gen 1 Dash changes AudioNutz 1G Dodge Durango - Interior/Exterior 4 02-06-2007 05:39 PM
    Hissing behind driver side of dash and vent selector problem chrisd0729 1G Dodge Durango General Talk 6 01-12-2007 07:18 AM
    Installed Brushed Aluminum Dash Kit (pics) BQRam04 3G Dodge RAM - Interior/Exterior Talk 21 02-06-2005 11:00 PM
