Dodge Ram Overheating - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 65 Old 07-08-2007, 07:33 PM Thread Starter
Dodgedrvr
Unhappy Dodge Ram Overheating
Hello, I have a 2004 Dodge Ram which keeps overheating at highway speeds. I have had the water pump and the thermostat replaced, but it continues to overheat. Can anyone help me?
Dodgedrvr is offline
post #2 of 65 Old 07-08-2007, 07:42 PM
stickshiftsrule
what's your left leg doin
stickshiftsrule's Avatar
Have you had the radiator checked? Could it be plugged/clogged?
Also Have you added coolant recently? Could it have been the wrong kind?
Member krs just went through something similar, but he also had a body-lift in his truck.
-Used to own
2005 RAM 1500 4x4 R/C S/B Flame Red
4.7L V8, 6-speed manual, 3.92 LS
stickshiftsrule is offline
post #3 of 65 Old 07-08-2007, 07:47 PM Thread Starter
Dodgedrvr
I just had the radiator flushed on Friday at the dealership. The vehicle only has 35,000 miles. No coolant in the oil, no smoke, no leaks. Running temps on scanner are 250 degrees.
post #4 of 65 Old 07-22-2007, 04:58 PM
shemp0091
Did you try removing your t-stat to see if the spring is broken?
Flowmaster American Thunder Exhaust
Transgo shiftkit
3715 Superchip Programmer
American Racing 17x8 sidewinder wheels
Airlift rear air bag suspension
Gibbs electric fan (clutch fan removed)
180 dergree thermostat
7 lb Radiator cap
shemp0091 is offline
post #5 of 65 Old 07-22-2007, 05:11 PM Thread Starter
Dodgedrvr
t-stat has been replaced,along with water pump,ipc,and ect
just out of curiousity why do all of you guys run a 180 t-stat, instead of the factory 195,,,are your trucks running hot too?
post #6 of 65 Old 07-22-2007, 08:11 PM
shemp0091
The superchip programmer advances the ignition timing which can make your
engine run a tick warmer. The 180 t-stat helps keep the engine cool. Not to mention that a slightly cooler engine makes more power.
I run a 7lb radiator cap to reduce the chances of blowing out a head gasket,
radiator hose, etc.....
Transgo shiftkit
7 lb Radiator cap
post #7 of 65 Old 07-22-2007, 08:16 PM Thread Starter
Dodgedrvr
shemp0091, i see that you live in PA as well,so we share some of the same driving conditions,,where did your gauge run before you installed your programmer, mine goes up pretty far,,on my scanner its hitting the 250-258 range on the highway, which is way warmer than the normal 210 i am accustomed to
post #8 of 65 Old 07-22-2007, 08:24 PM
shemp0091
my temp gauge use to run just a hair over 1/2 way. Now it's just a hair beneath the halfway mark.
Transgo shiftkit
7 lb Radiator cap
post #9 of 65 Old 07-24-2007, 06:38 PM
gix4kix
I have the same problem on my 04 QC 1500 4.7.... Please keep me posted on your findings. I'm no longer under warranty, so I don't want to throw away money if I don't have to. Mine can Idle all day long without any problems, but as soon as I try to drive 70-75 for any length of time, BAM 3/4 or higher
gix4kix is offline
post #10 of 65 Old 07-26-2007, 11:33 PM
krs
This is with the 180 t-stat?
stickshiftsrule, this post has me thinking maybe the bodylift is not fully to blame.
2002 Ram 4.7L 2wd Sold
Performance: 4.56 Gears, H/O Cams, 2008 Intake Manifold, 70mm TB, 4" Custom MIT Tube, Gibson SS Headers, ATI Pulley, SCT Tuned by FlyinRyan,2.5" Custom Y-Pipe With Magnaflow High Flow Cat and Muffler (12580) SI/DO Turn Down After Axel, Jeep Grand Cherokee TCM,
Suspension 4" CST Spindles, 1" Body Lift, 2" Lift Shackles, Doetsch Shocks
Others Srt-10 Pillar With Tranny Gauge, 16 Row Tranny Cooler, Color Matched Grill Shell
krs is offline
post #11 of 65 Old 07-26-2007, 11:38 PM
krs
Let me try to help you out since I am in the same boat as the rest.. Try touching the radiator in different spots after you have driven it for a while. What you are looking for is hot and cold spots througout the different areas. Another thing is to bleed the system you might have some air bubbles. I have been bleeding mine twice a week to see if thats going to help. This weekend I am going to check the heater core to see if that is faulty.
krs is offline
post #12 of 65 Old 07-27-2007, 05:34 PM Thread Starter
Dodgedrvr
well after yet another trip to the dealer today,, and they have replaced the fan clutch,,,and sure enough...it still "overheats", but atleast this time it was a different dealer and they actually sided with me stating that the temps on their scanner are at 250,
post #13 of 65 Old 07-28-2007, 06:08 PM
4getful2
Quoted: 1 Post(s)
all truth be told ,you really don't need a fan going down the interstate doin' 70 (it's the ram air effect)unless you are towing. a lower pressure rad.cap decreases the boiling point of your coolant.you only use those if your radiator is junk. since you have a scanner ,i wonder what the operating temperature is supposed to be?? did the dealer say?? it just seems so new to have a plugged up radiator since chrysler has changed designs(plastic tanks and larger tubes)but stranger things have happened. hopefully you don't have anything in front of the radiator blocking the air flow, like a bra or bugs from last year.gotta hose those fins out once in awhile(not high pressure either the garden hose will do. is it really running hot ??i mean after you drive it with it being that high on the guage .does the hot light come on ??it should have one of those also. is the radiator making funny noises,( like it needs to puke but can't ,THAT'S DAMM HOT)is coolant coming spewing out of the resevoir
4getful2 is offline
post #14 of 65 Old 07-29-2007, 06:17 PM Thread Starter
Dodgedrvr
my scanner shows me temps as high as 252-255 ish...normal operating temps are supposed to be at 210, i have flushed rad with my wynns flush machine, tested cap etc..., there is nothing in front of the rad, rad is clean, coolant is not bubbling out, and needle isnt hitting the red,, it hits the white part in between the red, and last black line, there is definately no restriction that i can find, the dealer is arguing with me that the temps are only going to 230, and that is normal, they know that i am a tech, so i dont know who they think they are trying to buffalo here
post #15 of 65 Old 07-30-2007, 12:21 AM
krs
Dodgedrvr, are you saying yours goes this high?(green line is yours) My highest gets what the blue indication is showing then comes back down.
krs is offline
post #16 of 65 Old 07-30-2007, 12:39 AM
krs
and next time the dealer tells you its normal tell them you want them to come with you on a test drive with one of their 4.7s from the lot and ask them why this does not overheat? I would like hear their answer..lol
krs is offline
post #17 of 65 Old 08-09-2007, 07:17 PM Thread Starter
Dodgedrvr
yep..the green line would be me,,,,i have now gone as far of taking a 2 minute snapshot with my scanner and showing them...now i am awaiting for the 13th of august so the dealer can pull my engine, and tear it apart according to dodge, so they can see what is wrong,,when asked what they might be looking for, they told me they havent a clue, but its what dodge wants them to do,,i have made the suggestion that the hot exhaust gases are entering the coolant system and that is why the coolant jumps up so high and fast once the temps reach 230,,but for some odd reason they give me strange looks? i guess a gm tech doesnt know how to work on any other engines??
post #18 of 65 Old 08-09-2007, 09:06 PM
charlie1935
charlie1935's Avatar
Quoted: 6 Post(s)
If exhaust or combustion gases were getting into the cooling system wouldn't you be blowing coolant out?
Grouchy Old Man
Sport short bed
R&S Automotive cat back duals
SSBC slotted rotors
Tri wing tonneau cover
Ultra 50/51 16x10 wheels
265 70x16 Firestone Destination LE tires
3.55 rear
99-01 sport headlights with Silverstar bulbs
MSD coil
Fram Boost intake -Freebie. I won it
Edelbrock shocks
Yes, grandpas like toys too
87 D100 318 auto. stock
Calling an illegal alien an 'undocumented immigrant' is like calling a drug dealer an 'unlicensed pharmacist'
charlie1935 is offline
post #19 of 65 Old 08-09-2007, 10:13 PM
krs
Dodgrvr, let us know how it goes. I am not sure if I emailed you on this before but here is a update on my situation. I had bled my system for a week straight and now everything is running under normal operating temperatures. I do hope the best for you and good luck
krs is offline
post #20 of 65 Old 08-18-2007, 04:17 PM
Double T
I am having the same problem with my 04 1500 QC 4.7 running hot only at highway speeds, so far I have changed t-stat, Flushed the radiator, and today I am changing the water pump and hoping that is the fix.
Double T is offline
    Dodge Reveals New 2006 Ram 1500 FreeLantz Rumor Mill & Gossip Talk 60 06-08-2006 08:58 PM
    All-new 2007 Dodge Caliber SRT4 to Dominate Sport-compact Market FreeLantz Rumor Mill & Gossip Talk 13 02-17-2006 08:10 PM
    Dodge Dominates at Daytona-Even Before the Race Begins coupster Rumor Mill & Gossip Talk 0 02-19-2005 01:04 AM
    Legendary Dodge Ram Power Wagon Returns RAM MAN Rumor Mill & Gossip Talk 4 10-02-2004 05:44 PM
    2004 and Select 2005 New Vehicle Pricing RAM MAN Rumor Mill & Gossip Talk 1 01-14-2004 10:29 AM
    You may not post new threads
    You may not post replies
