ashtray wont close 2005 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 15 Old 06-22-2007, 11:52 AM Thread Starter
usmarinekurt
usmarinekurt's Avatar
my bad too- I overfilled it with quartes for the car wash and some fell behind -how can i remove the whole door without breaking it
usmarinekurt is offline
post #2 of 15 Old 06-22-2007, 12:16 PM
04Ram2500Hemi
Same Name, Different Game
04Ram2500Hemi's Avatar
Quoted: 29 Post(s)
Not sure if an 05 is the same as an 04, but if it is, there is a screw behind the "garbage hook" on the right side of the dash. Unscrew that and the dash should pop right off, giving you access to the ash tray.
Truxedo Deuce Bed Cover with Bed Lights, Black Line-X Rocker Panel, Custom Built Rock Rails Sprayed with Line-X, Front & Rear Bumper and Grill sprayed with Line-X, Husky Mud Flaps, Husky Floor Mats, Four VisionX Xmitter Low Pro Prime XP LED Light Bars Behind the Grill, LED Lights Mounted in the Rear Bumper, Heated Seats, Interior LED Lighting, NAV-TV, Camera Mounted in Front Grill, Custom Headache Rack, AEV Raised Air Intake, 285/75/17 Toyo A/T II Tires
Gone But Never Forgotten!
2004 Ram 2500 4X4 SLT Quad Cab Hemi Silver Metallic, Black Line-X Rocker Panel, Westin Nerf Bars Sprayed with Line-X, Bushwacker Extend A Fender Sprayed with Line-X, Rhino Lining in the Bed and Over the Rails, Truxedo Low Profile Tonneau Cover, Hell 500's Behind the Grill, Warn Front Receiver, KC Backup Lights, Custom Mounted Bumper Backup Lights, V-7 V Force Muffler, Auto Meter Transmission Temperature Gauge, SRT-10 Pillar Grab Handle, Kore Recon Suspension System, Kore Race Steering Damper, Kore Chase Control Arms, Kore Coil Spring Isolator, Kore End Links, 35x12.50 Mud Terrain SXT Tires, SRT-10 Hood, AEM Brute Force Intake, Wet Okole Seat Covers, Smoked Recon Cab Lights, Tuff Stuff 12,500 Pound Multi Point Winch
04Ram2500Hemi is offline
post #3 of 15 Old 06-22-2007, 12:50 PM
05pwrwgn
05pwrwgn's Avatar
The whole ashtray assembly can be pulled out, there is a little plastic lip that holds it in, right at the top of where the door closes you can get a little screwdriver and press down and it will pop out, it does take a little bit of moving the screwdriver around a bit, but it will come out. I've had them same problem many times. Good Luck
2005 Dodge power Wagon #1232
RED TRUCK CLUB MEMBER #159
Power Wagon Owners Club #2
Superchips 3815
MODS:4" BDS suspension, 35/12.5/17 Pro Comp MT's, BDS Dual Steering Stab., Purple Cranium rock gaurds front and rear, Billet Grill, Locker Bypass, Train Horns w/dual 350 Viair comp. 17gal air cap., Tool Box with L.E.D. lights mounted in, Back Rack with L.E.D. lights(stop,tail,turn), Hella 500's behind grill, Line of Fire, E-Z Down(for Tailgate), Black aluminum gas door, XM satilite radio, Flowmaster dual exit out corners, Altezza L.E.D. tails, Smoked 3rd L.E.D., K&N aif filter and oil filter, POWER WIRE, Air Pressure gauge in SRT-10 A pillar, wheel well liners, Rhino Lining.
05pwrwgn is offline
post #4 of 15 Old 06-22-2007, 03:01 PM Thread Starter
usmarinekurt
you guys rock
post #5 of 15 Old 06-22-2007, 03:02 PM
bpunk360
bpunk360's Avatar
yea i had a penny go behind mine and it wouldnt stay shut... i got the penny out the whole ashtray had to come out for me to get the penny out
2005 Dodge Ram 2500 HEMI
Quad Cab 4x4 (BLACK) 3.73 gears
MODS:
Rhino Liner
Rear Molded Floor Mat
Rear Tail Light Guards (Yea i know they serve no purpose but i like they way they look)
Rear Wheel Well Liners
Silverstar headlight and fog bulbs (9007 and modded 9005)
Jet Stream Air Scoop
Flowmaster 50 HD 3" SI/SO<
THANKS lpfan4life85
Flowmaster Y-pipe Dual 2.5" INLET / 3" OUTLET
Superchips 3815
285/70R17 Cooper Discoverer ATR
bpunk360 is offline
post #6 of 15 Old 06-22-2007, 03:10 PM Thread Starter
usmarinekurt
can you explain in more detail exactly where the lever is ?
post #7 of 15 Old 06-22-2007, 03:25 PM
Sprocket
MORE! MORE! MORE!
Sprocket's Avatar
No lever. Just open the ash tray and feel at the top. You just need to give a pull there and the top will pop out, then pull the ashtray up and out. Hope this helped.
"Off-Road" Package Club Member #1
2004 Quad Cab "Off Road" Edition HEMI
Under Construction.......AGAIN
Sprocket is offline
post #8 of 15 Old 06-24-2007, 10:12 PM Thread Starter
usmarinekurt
yup I found 2.75 back there!
Trying to figure out where I will spend it
post #9 of 15 Old 06-25-2007, 08:43 AM
mikereidjr
Technology Handyman
mikereidjr's Avatar
Not on a gallon of gas!
Mine = 2010 Dodge Ram 1500 TRX QC 4x4 HEMI
Hers = 2010 Jeep Grand Cherokee Limited 4x4 HEMI
mikereidjr is offline
post #10 of 15 Old 06-25-2007, 02:37 PM
highbl00d
are you guys talkin bout the entire assembly coming out? I had this happen once and took off the plastic cover, popped out the tray but didnt do anything about that frame piece. all I had in the truck was a roll of tape and a shirt on a hanger. put the tape on the end of the hanger, held the frame slightly open, slid the hanger thru the underneath and started retrieving coins...lol
highbl00d is offline
post #11 of 15 Old 06-26-2007, 01:23 PM
Ram3500Dually
Ram3500Dually's Avatar
Quoted: 38 Post(s)
There are 4 holes at the top with a clip in each hole. A small flathead screwdriver works best.
2013 Ram 3500 CTD 6.7L 6 Speed Aisin, 4:10 LSD
2005 Jeep Liberty Sport
1991 Shadow ES Turbo Convertible
1984 Mini-Ram Van (Show Van) **TOTM April 2007** In museum now
73 Pro Street Duster.**VOTM July 2008/ April 2011**
1951 Dodge 3 Window Business Coupe **VOTM Feb 2011**
1992 Custom Built Harley FXSTC Show Bike
2008 Harley FLHTCU Ultra Classic
DodgeTalk Administrator
Names Carl, if you cut me I bleed Mopar Blue
Past Trucks: 90 CC Dually CTD, 94 RC LB CTD, 95 CC SB 5.2L gas, 98 QC Dually CTD, 00 QC Dually CTD, 01 QC Off Road, 03 QC Dually CTD, 05 QC Dually CTD, 08 Dually CTD **ROTM April 2008**,10 CC Dually CTD,
Ram3500Dually is offline
post #12 of 15 Old 06-26-2007, 03:14 PM
Dskirtech
Dskirtech's Avatar
Carl to the Rescue yet AGAIN!!!!!!
.......................What HE said!
MadDawg
Proud Member of WCPW Parts 1-3,432
2010 TRX Quad
/...Not Stock
.....Political Correctness is a doctrine fostered by a delusional, illogical liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end..........
Dskirtech is offline
post #13 of 15 Old 06-27-2007, 09:48 AM
Ram3500Dually
Quoted: 38 Post(s)
Mine wouldn't close on my 03 so the dealer ordered a new one and when they replaced it they found a cigarette butt in the bottom. They gave me the old one and this was brought up in an old thread so I already had the pictures saved
post #14 of 15 Old 09-30-2007, 09:54 PM
zsracing
do you happen to have your old one? the spring in mine broke.
zsracing is offline
post #15 of 15 Old 10-01-2007, 10:34 AM
Ram3500Dually
Quoted: 38 Post(s)
I still have it but the shipping from Canada to the US would probably be more than the thing is worth at the dealer
    Factory Stock 1/4 mile and 0-60 times. dodgeneonACR98 Street and Strip Talk 8 05-05-2009 07:53 PM
    Replace Ashtray and Drink Holder on 2005 Ram? Limedust 3G Dodge RAM - General Talk 1 06-13-2007 11:26 AM
    2005 Dodgetalk TOTM Winner's Circle hemi_dakota94 DodgeTalk Vehicle Award Winners Circle (2005-2012) 0 01-02-2007 10:29 PM
    Chrysler 300 Celebrates 50th Anniversary at the 2005 Goodwood Revival FreeLantz Rumor Mill & Gossip Talk 0 09-20-2005 10:41 AM
    Chrysler Offers 2005 Limited Edition Signature Series dodge_R/T13 Rumor Mill & Gossip Talk 1 10-14-2004 03:24 PM
