98 Durango ABS / Brake Light Problems Continue - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 06-18-2007, 02:34 PM Thread Starter
tloftus82
Alright guys, I've been lurking around these forums for quite a while trying to figure out to do with my brake problem on the Durango.
Almost every post on this forum regarding the ABS and Brake lights coming on is related to a wheel speed sensor. I'm not so sure that's what my problem is.
The problem - my 98 Durango (5.2 V8) randomly illuminates the ABS and Brake lights, always together. ABS then quits working until I restart the truck. Sometimes they will stay off other times they come right back on. Regardless they always come back on, it's just a matter of when. Something that may or may not be related - when I turn the truck to the on position (not started) I hear a quick "grind" noise coming from near the ABS modules under the hood. From what I read it performs a test at startup, this may or may not be related to my problem but thought it worth mentioning. This happens on every start up regardless of whether or not the dash lights come on.
Rear speed sensor - My speedometer is working fine. Most reports I read state that the speedo will quit working under 20MPH and that is in fact what happens when I disconnect this sensor. I have not checked the resistance in the sensor as I have no specs to compare it to.
Front speed sensors - I checked each of these individually. They both read approximately the same resistance (I don't have that number here with me but can get it if it will help). Also with my multimeter hooked up and I can spin each tire and get AC voltage coming from the sensors.
CAB Module - Not much I can check here on my own I don't think. I wiggle the wires, tap it with a screwdriver and nothing I do can make the lights come on.
I pulled the OBD-II codes with the scanner at Advance Auto Parts, and it comes back clear. However my understanding is that the brake codes are stored in the CAB controller and can't be accessed with a standard scan tool.
Thus is my dilemma. Ever since I took my first car (1988 Chevy Beretta) to the stealership for them diagnose and fix a miss problem and charge me $800 to replace an injector to still have the problem, I have vowed to stay as far away from these places as possible. (Ended up being a coil pack which I found myself by checking resistances, one of my first car repair endeavors.)
But I don't know what else to check / do. I need to get this problem fixed. My wife drives this truck and I don't feel it is safe for her to be driving with the ABS randomly shutting off. I could handle it, she can't.
Any ideas would be appreciated. I guess if I can't come up with anything I will have to go to Dodge where they are going to charge me $75 just to hook it up to the computer and tell me what MIGHT be wrong. If the sensors weren't so stinking expensive I would just replace all of them.
Anyway, sorry for being so long winded. Thanks in advance.
Tom
tloftus82 is offline
post #2 of 6 Old 06-18-2007, 03:02 PM
mpm32
My abs and brake lights were on with no speedo issues. Replaced the rear wheel speed sensor and the lights went off. I think the part is only $40 or so. I'd replace that first.
99 Durango SLT
It has 4-wheels and a third row seat.
5.2 liter
105,000 miles oh wait, I drove to work a lot since then - 120,040- 1,000 miles on new engine, 126,000 miles on the rest of the truck.
Mods - New nerf bars to replace the rotted out running boards. Factory brushguard, used to be the same color as the truck, I took it off and painted it black.
Hughes plenum pan. Done!
mpm32 is offline
post #3 of 6 Old 06-18-2007, 03:25 PM Thread Starter
tloftus82
I guess because of your post and all the documented problems with the rear speed sensor and because it isn't very expensive I think I am going to go ahead and swap it out. It is pretty easy and Dodge has it in stock. I will update everyone on what happens!
Thanks again,
Tom
post #4 of 6 Old 06-18-2007, 03:54 PM
Neil F.
Neil F.'s Avatar
The speedo may or may not be affected. When my sensor went bad, the speedo stayed working.
99 Durango 5.9, FT 4x4, IP stage III w/ K&N air hat, M1, MOPAR PCM, Fastman TB, 1.7 RR, JBA headers, Borla cat back, Martin Saine valve body, Hotchkis swaybars, Blistein shocks, lowered 2" Black Rhino Kenya wheels, 246. 7 RWHP, 319 TQ
Neil F. is offline
post #5 of 6 Old 06-19-2007, 01:34 PM
dizzyD
Registered MOPAR User
dizzyD's Avatar
Quoted: 24 Post(s)
But it is a hit or miss, I had this problem people on these forums said to change rear wheel Speed sensor, I did, it worked for, maybe, a week. light came back on at random time, eventually the lights stayed on. Finally came down to changing the ABS module (a year or so later) out, no light since. Driving w/out abs is no biggie, cars of years past never had abs. just understand that in a skid, you will skid. with ABS you have a pulsing skid.
2012 Challenger SXT+ 220ci 5 speed, blackberry pearl, FM xxMM, diablo in-tune I1000, Carbon fiber pedal covers, 11% tint
1999 Durango SLT+ leather, 360ci 4x4, hughes plenum rebuild, superchips 3865, tow pkg, 3.55 LSD, rear tail light guard, K&N CAI, FM 50MM TB, crystal clear headlights, Torsion/shackle lift, Rancho RSX's, Pacesetter headers, dual trans & oil temp a-pillar pod, chrome deep trans pan, drilled & slotted rotors, 10 disc cd changer.
2004 Ram 1500 SLT 2WD QC LB 345ci, FM 84MM TB, slotted brake rotors, step bar, diamond plate pedals, locking gas door, tow package w/ 3.55 lsd, Hellwig LP-15, shell and carpet kit, 18% door window tint, Magnaflow 12641, Slammed1's 3" spindle lift and 2.5 coil spacer, rear lift shackles, Airraid MIT, superchips 3815, 6K front winch & custom Winch Plate, Autometer phantom trans gauge mounted in Mopar SRT A-Pillar single pod, lumber/roof rack, Rancho 9000X shocks, ATS fender flairs, 1" BL, gap guards, black grille, silver painted bezel
2005 Dodge Magnum RT- Midnight Blue -Vroom Lakewood front strut bar, K&N Filter
Gone but not forgotten 93 factory freak CC dakota lifted 4x4 318
dizzyD is offline
post #6 of 6 Old 06-19-2007, 10:34 PM
99surangoslt
99surangoslt's Avatar
I replaced the RearSpeedWheelSensor and then reseted the computer, and lights went off, then came back again, I reseted again over and over until lights went off permanently. I think I finally deleted the code, and also the ABS works perfect.
I reseted this way: with the key on the off position, press and hold the odometer button and turn power to the on position without starting the engine, keep holding the button for 5 seconds approx. and the instruments will start to move like crazy, then disconnect the battery -and leave the key on the on position- for a minute. then turn off and reconnect the battery.
this procedure will reset the computer and ABS light will go off for a couple of startups, then will came back again and repeat this procedure again, and do it over and over again until the lights go off 4 ever.
ζΞΔ
**White1999DurangoSLT**
*75.000 miles*
*SonyHeadunit*
*Pionner400wAmp & 80wBazooka*
*Borla XR-1 Sportman Muffler and 3"tip*
*MSD/Accel ignition*
*Safari Light Bar with Hella 500īs*
*2" T/S lift*
99surangoslt is offline
    Brake light and abs brake light problems hemipower3315 3G Dodge RAM - General Talk 14 06-15-2006 11:35 AM
    ABS and Brake light Lunytoon95 1G Dodge Durango - Tire/Wheel/Susp Talk 9 03-07-2006 09:56 AM
    ABS and Brake Light on. willy1947 3G Dodge RAM - General Talk 3 12-29-2005 03:18 PM
    ABS and Brake Light jmrussell2003 1G Dodge Durango General Talk 38 01-07-2005 07:16 AM
